Excel/VBA feilmelding: Compile error in hidden module: MiscFun
Bare la det være sagt, jeg har ikke kunnskaper innen Visual Basic, så jeg er helt grønn her.
Jeg har problemer med en macro i Excel. Når jeg trykker på macro-knappen får jeg opp følgende feilmelding.
Jeg bruker Office 2007, og har funnet modulen i Visual Basic-editoren. Ser dere noe som kan forårsake denne feilmeldingen?
Sub CovarMat()
Application.ScreenUpdating = False
Worksheets("Asset Stats").Range("Ay6:CL45").ClearContents
Dim NumAssets As Integer
Dim i As Integer
Dim j As Integer
NumAssets = Sheets("Data Input").Range("D2")
ReDim CorrMat(NumAssets, NumAssets) As Single
'Reset all numbers to zero first
Worksheets("Asset Stats").Range("Ay6:CL45").Value = 0
For i = 1 To NumAssets
For j = 1 To NumAssets
CorrMat(i, j) = Sheets("Asset Stats").Cells(i + 5, j + 8)
Worksheets("Asset Stats").Cells(i + 5, j + 50).Value = CorrMat(i, j) * Worksheets("Asset Stats").Cells(i + 5, 6) * Worksheets("Asset Stats").Cells(j + 5, 6)
Next j
Next i
Application.ScreenUpdating = True
End Sub
Public Sub country_class()
Worksheets("Data Input").Range("I51:AV91").Value = ""
Dim num_clusters As Integer
num_clusters = Worksheets("Data Input").Range("D2")
Dim country_name(1 To 40) As String
Dim i As Integer
For i = 1 To num_clusters
country_name(i) = Worksheets("Data Input").Cells(5 + i, 3)
Next i
Dim unique_country(1 To 40) As String
Dim count As Integer
'Initialise
unique_country(1) = country_name(1)
count = 2
For i = 2 To num_clusters
If country_name(i) <> country_name(i - 1) Then
unique_country(count) = country_name(i)
count = count + 1
End If
Next i
Worksheets("Data Input").Cells(1, 4) = count - 1
For i = 1 To count
Worksheets("Data Input").Cells(51, 8 + i) = unique_country(i)
Next i
Dim j As Integer
'Get country binary codes
For i = 1 To count - 1
For j = 1 To num_clusters
If Worksheets("Data Input").Cells(5 + j, 3) = Worksheets("Data Input").Cells(51, 8 + i) Then
Worksheets("Data Input").Cells(51 + j, 8 + i) = 1
Else
Worksheets("Data Input").Cells(51 + j, 8 + i) = ""
End If
Next j
Next i
End Sub
Endret av darkness|
