svingstang2 Skrevet 24. august 2009 Del Skrevet 24. august 2009 (endret) Heisann Har en Intel X-25M som jeg synes har blitt veldig treg. Installerte først windows 7 og synes alt gikk lynkjapt. Brukte den noen dager før jeg måtte ta en reinstallasjon av windows 7 (etter noen hw justeringer). Under reinstallasjonen så formmaterte jeg disken, men selv med en 'ren' installasjon så virker den mye tregere. Ved første installasjon startet f.eks office og firefox umiddelbart, mens nå tar det flere sekunder å starte firefox. Den eneste endringen hardwaremessig er strengt tatt at nå kjører maskina på 3.5 GHz, mens ved den første installasjonen kjørte den på 2.4 GHz. Synes det virker litt rart om det skulle ha noe å si i negativ forstand (og ja, temperaturene er under kontroll). Noen som har noen ideèr? edit: typo Endret 24. august 2009 av svingstang2 Lenke til kommentar
Ravusy Skrevet 24. august 2009 Del Skrevet 24. august 2009 The first being that Legit Reviews was the first and only site to point out that Intel had a performance degradation issue with their drive. The second was the fact that it is hard to endorse a product that costs nearly $1000 knowing that it would not support the features our readers would want once Windows 7 comes out. Intel addressed our first concern by released firmware version 8820, which fixed the performance degradation and fragmentation issue that was common with normal use. Lenge siden du oppdaterte firmware? Intel® SATA SSD Firmware Update Tool Lenke til kommentar
svingstang2 Skrevet 26. august 2009 Forfatter Del Skrevet 26. august 2009 The first being that Legit Reviews was the first and only site to point out that Intel had a performance degradation issue with their drive. The second was the fact that it is hard to endorse a product that costs nearly $1000 knowing that it would not support the features our readers would want once Windows 7 comes out. Intel addressed our first concern by released firmware version 8820, which fixed the performance degradation and fragmentation issue that was common with normal use. Lenge siden du oppdaterte firmware? Intel® SATA SSD Firmware Update Tool trengtes ingen oppdatering, var siste versjon Lenke til kommentar
johome Skrevet 26. august 2009 Del Skrevet 26. august 2009 Under reinstallasjonen så formmaterte jeg disken, men selv med en 'ren' installasjon så virker den mye tregere. Det nytter ikke å formattere SSD'en. Det korrekte er å bruke HDDErase 3.3 Da skal SSD'en bli like rask som den var som helt ny. Alle data blir da borte, og du må da reinstallere OS'et (Hvis du ikke har G2 bør du i tillegg flashe med firmware 8820) HDDErase 3.3 finner du her. Bla litt nedover på siden, så finner du linken. Hvis du ikke får det til , gi beskjed så sender jeg deg ISO filen. Lenke til kommentar
