Snuzuki Skrevet 22. august 2009 Del Skrevet 22. august 2009 lurer bare på,hva slags verdi den har i dag,kjøpt i 2006 på høsten, det er 2 x 80 gb disker så er det 16 GHz modellen ATi graffik kort radeon xpress 200m 1.0 GB RAM ■ The following processors, varying by computer model: ❏ AMD Turion 64 ML-44 (2.4-GHz) ❏ AMD Turion 64 ML-40 (2.2-GHz) ❏ AMD Turion 64 ML-40 (2.2-GHz) ❏ AMD Turion 64 ML-37 (2.0-GHz) ❏ AMD Turion 64 ML-34 (1.8-GHz) ❏ AMD Turion 64 ML-32 (1.8-GHz) ❏ AMD Turion 64 ML-30 (1.6-GHz) ❏ Mobile AMD Sempron 3300 (2.0-GHz) ❏ Mobile AMD Sempron 3100 (1.8-GHz) ■ 17.0-inch, WSXGA+, TFT (1680 × 1050) with BrightView or 17.0-inch, WXGA+, TFT (1440 × 900) with BrightView display, varying by computer model ■ 120-, 100-, or 80-GB high-capacity hard drive, varying by computer model ■ 256-MB DDR1 synchronous DRAM (SDRAM) at 333 MHz, expandable to 2.0 GB ■ Microsoft® Windows® XP Home Edition or Windows XP Professional, varying by computer model ■ Full-size Windows keyboard with full-size numeric keypad ■ TouchPad pointing device, including dedicated vertical scroll region ■ Integrated 10Base-T/100Base-TX Ethernet local area network (LAN) network interface card (NIC) with RJ-45 jack ■ Integrated high-speed 56K modem with RJ-11 jack ■ Integrated wireless support for Mini PCI IEEE 802.11a/b/g WLAN device ■ Support for one Type I or Type II PC Card slot, with support for both 32-bit (CardBus) and 16-bit PC Cards ■ Support for ExpressCard slot ■ External 65-watt AC adapter with 3-wire power cord ■ 8-cell Li-Ion battery ■ Stereo speakers ■ Volume up, volume mute, and volume down buttons ■ QuickPlay buttons ■ Support for the following optical drives: ❏ DVD±RW and CD-RW Double-Layer Combo Drive with LightScribe ❏ DVD±RW and CD-RW Double-Layer Combo Drive ❏ DVD/CD-RW Combo Drive ■ Connectors: ❏ Audio-in (microphone) ❏ Audio-out (headphone) ❏ Digital Media Slot ❏ Expansion port 2 ❏ ExpressCard slot ❏ External monitor ❏ IEEE 1394 ❏ PC Card ❏ Power ❏ RJ-11 (modem) ❏ RJ-45 (network) ❏ S-Video-out ❏ Universal Serial Bus (USB) v. 2.0 (4 ports) Lenke til kommentar
EivindS_ Skrevet 22. august 2009 Del Skrevet 22. august 2009 Veldig lite. Jeg hadde en 15" versjon av den laptopen med noenlunde like spesifikasjoner, og den ga jeg bort til bror min gratis. Lenke til kommentar
OC-Freak Skrevet 22. august 2009 Del Skrevet 22. august 2009 500,- toppen. Får jo nye maskiner som er mange ganger så raske til 3000,- Lenke til kommentar
