Blåskjerm i Win2k. Irriterende! Help..
Får denne blåskjermen:
***STOP: 0x0000001E (0xC0000005, 0xBECF7B07, 0x00000000, 0x5952439B) KMODE_EXCEPTION_NOT_HANDLED
Noen som veit hva jeg kan gjøre? Er så f**** irriterende! Skjer aldri når jeg bruker maskina, men når jeg lar den stå over natta, pga av nedlastning, klikker den nesten med en gang virker det som.. Har også på nedlastning når jeg bruker maskina, så tror ikke programmet har no å si... Er det hjelp å legge inn WinXp Pro?
Håper virkelig noen kan dette, da blir jeg skikkelig glad!! På forhånd takk, Jan-Sølve SW
2 sek på google:
Message:
STOP: 0x0000001E (parameter, parameter, parameter, parameter) KMODE_EXCEPTION_NOT_HANDLED
Explanation:
This is a Windows 2000 Executive character-mode STOP message. It indicates that a kernel-mode exception was not handled. The second parameter in the parameter list is the memory address at which the unhandled exception occurred. Usually, the exception address pinpoints the driver/function that caused the problem. A common problem is 0x80000003, which means a hard-coded breakpoint or assertion was hit but the system started NODEBUG.
User Action:
If this is the first time you have booted after installing new hardware, remove the hardware and boot again. Check the Microsoft Hardware Compatibility List to verify that the hardware and its drivers are compatible with Windows 2000. For information about the hardware, contact the supplier. If you are installing Windows 2000 for the first time, check the Windows 2000 system requirements, including the amount of RAM and disk space required to load the operating system. Also, check the Hardware Compatibility List to verify that the system can run Windows 2000. If Windows 2000 is loaded and no new hardware has been installed, reboot with recovery options set to create a dump file. If the message continues to appear, select the Last Known Good option when you reboot. If there is no Last Known Good configuration, try using the Emergency Repair Disk. If you do not have an Emergency Repair Disk, contact your technical support group.
Ja, bruker Windows 2000 Pro.
Har slått av all PowerManagment i Windows. Skal prøve å virusscanne nå, og prøve memtest86. Nedlastningsprogrammet er hele tiden på, men maskina klikker når jeg ikke "bruker" den. Altså når jeg legger meg. Takk for svar hittil. Tar gjerne imot flere forslag.
Jan-Sølve SW
