Sokkalf™ Skrevet 26. oktober 2009 Rapporter Del Skrevet 26. oktober 2009 Hva får dere i score på windows7 opplevelsesindeks primær hardisk?Jeg har 7,1 (x-25m 160 g2) Jeg får 7,5 med x25m 80 g2. Har X-25M 80GB gen 2., Intel ICH9R-kontroller i AHCI-modus. Jeg får 7,7. Lenke til kommentar
r0lfi Skrevet 26. oktober 2009 Rapporter Del Skrevet 26. oktober 2009 (endret) FYI Intel® Solid-State Drive Toolbox with Intel® SSD Optimizer Enables Users to Maximize SSD Performance over Time SANTA CLARA, Calif., Oct. 26, 2009 – On the heels of the Microsoft* Windows* 7 introduction, Intel Corporation today announced the availability of the Intel® Solid-State Drive (SSD) Toolbox, with Intel® SSD Optimizer and firmware update, for its 34nm Intel® X25-M Mainstream SATA SSDs. The latest tools are designed to help better manage and retain the out-of-box performance of Intel SSDs. An SSD is built to replace a traditional hard disk drive (HDD) with added performance, lower power consumption and higher reliability. The Intel SSD Toolbox allows users to more effectively monitor and manage the SSD’s health. The firmware upgrade and Intel SSD Optimizer use the Windows* 7 ATA Data Set Management Command (known as Trim) to help keep the Intel SSD running at continued high performance. In addition, the SSD Toolbox and Optimizer also allow the respective enhancements to work with Windows* XP and Vista* operating systems. “Fast and reliable access to data is critical for our SSD users,” said Pete Hazen, director of marketing, Intel NAND Solutions Group. “The latest firmware and toolbox upgrade for Intel 34nm SSD users provide a host of new management, information and diagnostic tools to help SSDs retain out-of-box performance. We are encouraging our 34nm customers to download the new firmware update today. Not only will Windows 7 users receive the performance enhancements of the Trim command, but so will our Windows XP and Vista users.” For 34nm X25-M 160GB owners, the firmware update also offers a performance boost to sequential write speeds by delivering up to 100MB per second, a 40 percent performance improvement over the existing firmware version. The Trim attribute of the ATA Data Set Management Command, often referred to as Trim, synchs the operating system’s view of deleted files with those that are deleted, but not erased on the drive. Trim tells the SSD which data blocks are no longer in use. This helps stabilize the performance and health of the SSD over time. The Intel SSD Toolbox provides SSD management tools and information about the drive, including comparing Self-Monitoring and Reporting Technology (S.M.A.R.T.) drive attributes to manufacturer threshold. It provides basic and full diagnostics, along with recommended actions. The Toolbox also features an easy-to-use graphical user interface that will allow end users to schedule and run the Trim command independent of the operating system. The company recommends users install the firmware update and toolbox, and run the Trim function daily to ensure best performance. The firmware upgrade can be found at www.intel.com/go/ssdfirmware and the Intel SSD Toolbox and Optimizer at www.intel.com/go/ssdtoolbox. Intel’s award-winning X25-M SSD began shipping on 34nm in July. The multi-level cell (MLC) Intel® X25-M Mainstream SATA SSD is aimed at laptop and desktop PCs, and available in 80 Gigabyte (GB) and 160GB versions. SSDs are data storage devices found inside computers. Because SSDs have no moving parts they offer faster performance and greater energy efficiency and durability than traditional HDDs. A draw for gamers, media creators and technology enthusiasts, SSDs have also played a key role in the emergence of ultra-thin and light notebook PCs that are becoming increasingly popular due to their design, size and longer battery life. For more information on Intel SSDs visit www.intel.com/go/ssd. Kilde:xtremesystems. Endret 26. oktober 2009 av r0lfi Lenke til kommentar
GunnarGul Skrevet 27. oktober 2009 Rapporter Del Skrevet 27. oktober 2009 Nå har jeg kjøpt 80 GB versjonen fra digital impuls, bestile i går kveld, ble levert istad. De brukte under 12 timer fra bestilling til levering. Veldig bra Lenke til kommentar
tevil Skrevet 27. oktober 2009 Rapporter Del Skrevet 27. oktober 2009 (endret) Ser at Dustinhome fremdeles har levering beregnet levering 27.10. Er det bare fordi de ikke har oppdatert systemet sitt eller er det muligens reellt? Er jo 150kr billigere enn digital impuls... Intel X25-M 80gb gen2? edit: Tok ikke sjansen og bestillte fra digital impuls, da er det bare å vente på Windows 7 og glede seg. Endret 27. oktober 2009 av tevil Lenke til kommentar
CAT-scan Skrevet 28. oktober 2009 Rapporter Del Skrevet 28. oktober 2009 Hva får dere i score på windows7 opplevelsesindeks primær hardisk?Jeg har 7,1 (x-25m 160 g2) Jeg får 7,5 med x25m 80 g2. Har X-25M 80GB gen 2., Intel ICH9R-kontroller i AHCI-modus. Jeg får 7,7. Hva er det den testen måler? Lenke til kommentar
Jobby Skrevet 11. november 2009 Rapporter Del Skrevet 11. november 2009 Ingen har den på lager Bestiller https://prisguiden.no/produkt/112606 så fort den er på lager hos en butikk.. Lenke til kommentar
L O G I M A N Skrevet 11. november 2009 Rapporter Del Skrevet 11. november 2009 Har intel fått sjekka noe mer ut om firmware oppdateringa nå? Lenke til kommentar
Panter Skrevet 11. november 2009 Rapporter Del Skrevet 11. november 2009 Ingen har den på lager Bestiller https://prisguiden.no/produkt/112606 så fort den er på lager hos en butikk.. Tips: Hvis du bestiller en X25-M kan det ta alt fra 1 uke til flere uker før du får en, en ting er imidlertid sikkert, hvis du ikke legger inn bestilling nå vil du alltid ligge bakerst i køen.(Komplett og flere får garantert inn men de går rett ut til de som har bestilt og vil derfor ikke vises som på lager) Lenke til kommentar
Jobby Skrevet 11. november 2009 Rapporter Del Skrevet 11. november 2009 (endret) Åja, da får jeg bestille nå da Bestilt på Datakjeden! Endret 12. november 2009 av Jobby Lenke til kommentar
Phantom3D Skrevet 12. november 2009 Rapporter Del Skrevet 12. november 2009 Bestillte fra amentio 22/10. Da var annkomst dato 30/10. Nå er estimert annkomstdato 17/11!! Begynner å bli ganske møkk lei venting.. Spes med tanke på at de lenge hadde disken på Digital Impuls, som kun er et par tre steinkast fra meg... Lenke til kommentar
SRD Skrevet 12. november 2009 Rapporter Del Skrevet 12. november 2009 Bestillte fra amentio 22/10. Da var annkomst dato 30/10. Nå er estimert annkomstdato 17/11!! Begynner å bli ganske møkk lei venting.. Spes med tanke på at de lenge hadde disken på Digital Impuls, som kun er et par tre steinkast fra meg... Jeg bestilte fra Amentio, men avbestilte. Men på min står det januar 2010... Jeg bestilte heller fra Digital Impuls, utrolig greie og hyggelige folk Lenke til kommentar
L O G I M A N Skrevet 12. november 2009 Rapporter Del Skrevet 12. november 2009 Bestillte fra amentio 22/10. Da var annkomst dato 30/10. Nå er estimert annkomstdato 17/11!! Begynner å bli ganske møkk lei venting.. Spes med tanke på at de lenge hadde disken på Digital Impuls, som kun er et par tre steinkast fra meg... Hvorfor bestilte du ikke på Digital Impuls?? Attpåtil kunne du bare gått å henta en og?? Lenke til kommentar
Phantom3D Skrevet 12. november 2009 Rapporter Del Skrevet 12. november 2009 Fordi når en nettbutikk sier de har varen 30/10 Og jeg ikke trenger den med en gang så er det penger å spare. +/- en uke er også helt greit. Men å sette opp forventet annkomstdato 3-4 ganger i uka synes jeg ikke er greit.. :-( Digital impuls har den fortsatt ikke.. :-( Lenke til kommentar
serrghi Skrevet 18. november 2009 Rapporter Del Skrevet 18. november 2009 Kan tipse om at Amentio har fått inn 51stk som de selger som "tilbud" som egentlig koster 250kr mer enn de gjorde tidligere. Dette gjelder altså R5 versjonen. Lenke til kommentar
Jobby Skrevet 18. november 2009 Rapporter Del Skrevet 18. november 2009 http://www.amentio.no/PartDetail.aspx?q=p:2538829;c:36376 Her har vi jo den disken? + den er på lager. Lenke til kommentar
CAT-scan Skrevet 18. november 2009 Rapporter Del Skrevet 18. november 2009 http://www.amentio.no/PartDetail.aspx?q=p:...bc:36376%3br:pg Denne er registrert i prisguiden. Lenke til kommentar
Pop Skrevet 19. november 2009 Rapporter Del Skrevet 19. november 2009 http://www.amentio.no/PartDetail.aspx?q=p:...bc:36376%3br:pg Denne er registrert i prisguiden. Noen som vet noe mer om hvor reell den tiden der er? 23.11.09 ETA... Evt andre butikker? Lenke til kommentar
SRD Skrevet 19. november 2009 Rapporter Del Skrevet 19. november 2009 Amentio har bare utsatt og utsatt forventet på lager i lang tid nå, så jeg tviler på at det er reelt. I ordren min stod det 06.01.2010. Så jeg bestilte heller fra Digital Impuls, og fikk den på under en uke. Lenke til kommentar
CAT-scan Skrevet 19. november 2009 Rapporter Del Skrevet 19. november 2009 Men er ikke disse identiske? Er det noe vesentlig jeg misser her? Lenke til kommentar
Anv Skrevet 19. november 2009 Rapporter Del Skrevet 19. november 2009 Men er ikke disse identiske? Det som skiller dem er ca 300 kroner Lenke til kommentar
