Hjelp med "enkel" login.
Hei.
Eg fant eit greit script på google, men når eg skal teste registreringa kommer det bare opp "Error: User not added to database." Trur eg har gjort alt rett men siden eg ikkje kan noko om dette så spør eg her om det er nokon som kan hjelpe meg.
Eg har server hos Pro ISP, der eg lagde ein MySQL Database til dette. Eg la infoen til den inn i dbconfig.php som skulle snakke med databasen.
Link til sida.
Link til sida mi.
Håper noko tar seg til til å hjelpe.
Endret av BigJaffa
Brukeren har skrivetilgang.
Register.php
<?php
// dbConfig.php is a file that contains your
// database connection information. This
// tutorial assumes a connection is made from
// this existing file.
include ("dbConfig.php");
//Input vaildation and the dbase code
if ( $_GET["op"] == "reg" )
$bInputFlag = false;
foreach ( $_POST as $field )
 if ($field == "")
 else
  $bInputFlag = true;
// If we had problems with the input, exit with error
if ($bInputFlag == false)
 die( "Problem with your registration info. "
  ."Please go back and try again.");
// Fields are clear, add user to database
//  Setup query
$q = "INSERT INTO `dbUsers` (`username`,`password`,`email`) "
 ."VALUES ('".$_POST["username"]."', "
 ."PASSWORD('".$_POST["password"]."'), "
 ."'".$_POST["email"]."')";
//  Run query
$r = mysql_query($q);
// Make sure query inserted user successfully
if ( !mysql_insert_id() )
 die("Error: User not added to database.");
else
 // Redirect to thank you page.
 Header("Location: register.php?op=thanks");
} // end if
//The thank you page
elseif ( $_GET["op"] == "thanks" )
echo "<h2>Thanks for registering!</h2>";
//The web form for input ability
else
echo "<form action=\"?op=reg\" method=\"POST\">\n";
echo "Username: <input name=\"username\" MAXLENGTH=\"16\"><br />\n";
echo "Password: <input type=\"password\" name=\"password\" MAXLENGTH=\"16\"><br />\n";
echo "Email Address: <input name=\"email\" MAXLENGTH=\"25\"><br />\n";
echo "<input type=\"submit\">\n";
echo "</form>\n";
// EOF
dbConfig.php
// Replace the variable values below
// with your specific database information.
$host = "localhost";
$user = "khavehla_kris";
$pass = "123456789";
$db   = "khavehla_dbusers";
// This part sets up the connection to the
// database (so you don't need to reopen the connection
// again on the same page).
$ms = mysql_pconnect($host, $user, $pass);
if ( !$ms )
echo "Error connecting to database.\n";
// Then you need to make sure the database you want
// is selected.
mysql_select_db($db);
Endret av BigJaffa
Register.php
<?php
//  Setup query
//  Run query
else
} // end if
Har du laget tabellen dbUsers? Isåfall, inneholder tabellen dbUsers alle de cellene som er listet(username, password, email)?
