racin Skrevet 13. august 2009 Del Skrevet 13. august 2009 Har tenkt å gå til innkjøp av en Acer Travelmate 6593G, og i den anledning lurer jeg på om det er noen som kan si noe om denne maskinen. Spesifikasjoner: Processor: Intel Core 2 Duo, P8700, 2,26GHz, 1066MHz, 3MB L2 Cache. Chipset: Intel PM45, Intel Southbridge. RAM: 2x2048MB DDR3, PC8500 RAM, 1066MHz. Display adapter: AMD HD3470 256MB DDR2, with up to 1792MB extra via ATI HyperMemory Technology.* Hard drive: 320GB 7200RPM 2.5” SATA drive Display: 15.4", with Acer HighBrightness Crystal Brite technology, WSXGA+ TFT, resolution 1680x1050. Sound card & speakers: Realtek High Definition chipset, 24Bit stereo compatible. Two built-in stereo speakers. Optical drive: DVD, Multi layer DVD Battery: 9 Cell, 7200mAh Networking: WiFi Wireless 802.11N(Draft) Ethernet LAN 10/100/1000 Bluetooth 2.0 56K, V92 Modem Infrared Connectivity options: 1x VGA 1x DVI-D 1x HDMI 1x RJ-45 Ethernet 1x RJ-11 Modem 1x Microphone in 1x Speakers out / SPDIF 1x 5-in-1 card reader, SD, MS, MS Pro, MMC, xD 1x SmartCard reader 4x USB 1x ExpressCard 54 Slot 1x PC Card type II 1x Real click docking port Dimensions: 360(B)x267(D)x34~36(H)mm. 2.9kg. – 3.1kg. with battery. Warranty: Acer gives a two year right of revocation. Acer also provides a one year international warranty. Tester: http://laptop-review.eu/Reviews/Laptops/ac.../All-Pages.html http://www.idg.no/pcworld/article129607.ece?curPage=2 Lenke til kommentar
