problem med opengl til windows 7 64-bit
Hei!
Eg skulle prøve counter strike 1.6 i går, men skjermen begynte å blinke (flickering) så skiftet eg render til software og da sluttet det å blinke. så googlet eg problemet og fant ut at mange hadde akkurat det samme problemet. Eg fant dette
"Ok finally got CS working with OpenGL. Heres what I did with my graphics adapter (hopefully something similar will help others). Apparently (at least with Intel) the new win7 drivers did not include OpenGL in them. All I had to do was download the latest driver package from Intels website and install it in compatability mode for windows Vista. Now playing CS :].
.. took quite a few tries. make sure the computer doesnt try to revert back to a different driver. also, when I finally did get the vista driver installed correctly, It had to restart like 3 times"
Eg forstod ikkje helt og ber om hjelp
Håpe på raske og gode svar :thumbup:
