Mobilen funker i microbølgeovnen?
Gjest Slettet+65132
Gjest Slettet+65132
Er dette normalt?
Ser ut som jeg har full dekning. Slik som jeg har trudd skal microbølgeovnen stenge for denne type stråling? Har ikke prøvd å skru på mikrobølgeovnen, men ville da tru at den stenger for stråling uansett om den er på eller ikke..
Endret av Slettet+65132
I følge wiki brukes det samme tpe stråling i mikrobølgeovner og mobiltelefoner! ; o Det samme gjør Wifi, bluetooth + en hel haug andre trådløse dupeditt-teknologier.
Det virker dog som om strålingen i mikrobølgeovnen har en klart høyere frekvens - noe det fint kan være mulig å skille ut i veggene.
The microwaves emitted by the source in a microwave oven are confined in the oven by the material out of which microwave oven is constructed. Tests have shown confinement of the microwaves in commercially available ovens to be so nearly universal as to make routine testing unnecessary.[22] According to the United States Food and Drug Administration's Center for Devices and Radiological Health, a US Federal standard limits the amount of microwaves that can leak from an oven throughout its lifetime to 5 milliwatts of microwave radiation per square centimeter at approximately 2 inches from the surface of the oven. [23] This is far below the exposure level currently considered to be harmful to human health.
The radiation produced by a microwave oven is non-ionizing. It therefore does not have the cancer risks associated with ionizing radiation such as X-rays, ultraviolet light, and high-energy particles. Long-term rodent studies to assess cancer risk have so far failed to identify any carcinogenicity from 2.45 GHz microwave radiation even with chronic (i.e., large fraction of life span) exposure levels, far larger than humans are likely to encounter from any leaking ovens.[24][25] However, with the oven door open, the radiation may cause damage by heating; as with any cooking device. Nearly every microwave sold has a protective interlock so that it cannot be run when the door is open or improperly latched.
Du har nok altså svært lite å frykte : )
