Battlefield: Bad Company 2 - Fakta, videoer og diskusjon.
Gjest Slettet-uVTr2vDm
Ny patch til BC2 i morgen! :D
LINK.
What is the patch about?
Its main goal is to address stability problems with the game and performance issues. It is not intended to address game logic fixes.
You are being vague. Exact changelist please!
Ok, here goes...
Removed some memory leaks
Fixed crashes when the game attempted to render lots of content (high detail, high FOV or multiple-monitor modes); this should particularly help multi-monitor users
Chat window no longer causes lag spikes
Chat window reworked opacity & visibility-time is controllable through settings in settings.ini
Clantag is remembered when using auto-login
Banner URLs can be up to 252 characters in length
SecuROM wrapper removed from non-Steam version
Minor performance enhancements
Reduced rubberbanding on servers with more than 24 active players
PrintScreen takes a screenshot, file stored in Documents\BFBC2\Screenshots directory
How large is the patch?
It is approximately 2.6GB.
Endret av N1ko
Ang. ny patchen...
Are there any known problems with it?
If your Windows username contains non-English characters (such as ö, ý, etc) then PunkBuster will not activate properly. To work around this, ensure that your Windows username uses only characters from the English character set. In other words, "7-bit ASCII only, please". We caught this at the very end of the validation pass, and decided that it was better to deliver the build to the public than to give it another tour through the whole patch generation and validation process.
Kanskje greit å legge seg på minnet hvis du heter Øyvind, Øystein eller Ågot..
( Sikkert noe med at franskmenn er lette å få til å overgi seg.)
Endret av Topguy
Hadde matcmaking fungert i BC2 hadde det omtrent ikke blitt baseraping. Håper de har fikset det på BF3.
Hvordan da? Det er ingen sammenheng mellom rang og skills.
Kanskje ikkje, men det seier seg sjølv at eitt lag med 16 lvl 2-20 vil bli totalt voldtatt av eitt lag med over 6-7 lvl 50.
Njaa, teamwork har igrunn mer og si etter min mening. Det og generelle fps skills.
Jeg er vel lvl 29 sammen med en kompis på lvl 32, banker vi som relgel de andre squads'a på BF, kan ikke si vi alltid vinner Rush, men det er ikke lett for 2 spillere og gjøre alt alene.
Men nå har jo faktisk BC2 en statistikk som heter "skill level" da. Den er så vidt jeg har skjønt mye basert på KDR og hvilken rank de du dreper og de du blir drept av er.
http://statsverse.com viser den ikke men http://bfbcs.com viser den.
På PC så velger man jo stort sett server selv så matchmaking har liten plass der. På PS3/Xbox så kan jeg forstå ønsket.
Jeg har 592. Aner ikke om det er bra eller dårlig, bryr meg egentlig ikke så mye.
Skill level på 592? :wow:
Det meste jeg har sett er 200.
Edit: Nå sjekket jeg min på bfbc.com å der var min på 374.
På statsverse er den på kun 171 :dontgetit:
Endret av Kim Spartacus
