Sjekket routerloggen min for moro skyld i dag, og ser at den tydeligvis har blitt spammet ned av tilkoblingsforsøk fra diverse IPer i natt - hva betyr egentlig dette?
2009/08/09 02:36:41 : Blocked access attempt : TCP from 79.138.202.130:4444 to **.***.**.***:37419
2009/08/09 02:38:13 : Blocked access attempt : TCP from 213.199.141.141:80 to **.***.**.***:1180
2009/08/09 02:40:40 : Blocked access attempt : TCP from 79.156.54.220:10586 to **.***.**.***:37419
2009/08/09 02:41:32 : Blocked access attempt : TCP from 85.167.116.175:19961 to **.***.**.***:37419
2009/08/09 02:44:14 : Blocked access attempt : TCP from 85.164.151.145:53826 to **.***.**.***:37419
2009/08/09 02:44:14 : Blocked access attempt : TCP from 81.170.172.178:6756 to **.***.**.***:37419
2009/08/09 02:44:15 : Blocked access attempt : TCP from 78.69.225.82:49982 to **.***.**.***:37419
2009/08/09 02:44:15 : Blocked access attempt : TCP from 85.195.19.131:1489 to **.***.**.***:37419
2009/08/09 02:44:15 : Blocked access attempt : TCP from 83.253.171.166:52454 to **.***.**.***:37419
2009/08/09 02:44:16 : Blocked access attempt : TCP from 90.224.154.113:54071 to **.***.**.***:37419
2009/08/09 02:44:16 : Blocked access attempt : TCP from 83.252.185.185:2001 to **.***.**.***:37419
2009/08/09 02:44:17 : Blocked access attempt : TCP from 85.164.151.145:53826 to **.***.**.***:37419
2009/08/09 02:44:17 : Blocked access attempt : TCP from 81.170.172.178:6756 to **.***.**.***:37419
2009/08/09 02:44:18 : Blocked access attempt : TCP from 78.69.225.82:49982 to **.***.**.***:37419
2009/08/09 02:44:18 : Blocked access attempt : TCP from 85.195.19.131:1489 to **.***.**.***:37419
2009/08/09 02:44:18 : Blocked access attempt : TCP from 83.253.171.166:52454 to **.***.**.***:37419
2009/08/09 02:44:19 : Blocked access attempt : TCP from 90.224.154.113:54071 to **.***.**.***:37419
2009/08/09 02:44:19 : Blocked access attempt : TCP from 83.252.185.185:2001 to **.***.**.***:37419
2009/08/09 02:44:23 : Blocked access attempt : TCP from 85.164.151.145:53826 to **.***.**.***:37419
2009/08/09 02:44:23 : Blocked access attempt : TCP from 81.170.172.178:6756 to **.***.**.***:37419
2009/08/09 02:44:23 : Blocked access attempt : TCP from 78.69.225.82:49982 to **.***.**.***:37419
2009/08/09 02:44:24 : Blocked access attempt : TCP from 85.195.19.131:1489 to **.***.**.***:37419
2009/08/09 02:44:24 : Blocked access attempt : TCP from 83.253.171.166:52454 to **.***.**.***:37419
2009/08/09 02:44:25 : Blocked access attempt : TCP from 90.224.154.113:54071 to **.***.**.***:37419
2009/08/09 02:44:25 : Blocked access attempt : TCP from 83.252.185.185:2001 to **.***.**.***:37419
2009/08/09 02:45:56 : Blocked access attempt : TCP from 88.105.99.50:51680 to **.***.**.***:37419
2009/08/09 02:46:07 : Blocked access attempt : TCP from 85.197.138.129:1055 to **.***.**.***:37419
2009/08/09 02:46:24 : Blocked access attempt : TCP from 88.105.99.50:51707 to **.***.**.***:37419
2009/08/09 02:47:00 : Blocked access attempt : TCP from 85.165.245.42:50337 to **.***.**.***:37419
2009/08/09 02:47:00 : Blocked access attempt : TCP from 85.230.76.88:3475 to **.***.**.***:37419
2009/08/09 02:47:00 : Blocked access attempt : TCP from 88.89.23.202:57850 to **.***.**.***:37419
2009/08/09 02:47:00 : Blocked access attempt : TCP from 95.34.50.56:63447 to **.***.**.***:37419
2009/08/09 02:47:00 : Blocked access attempt : TCP from 88.8.45.9:3028 to **.***.**.***:37419
2009/08/09 02:47:00 : Blocked access attempt : TCP from 87.93.42.125:2638 to **.***.**.***:37419
2009/08/09 02:47:01 : Blocked access attempt : TCP from 82.18.249.254:62914 to **.***.**.***:37419
2009/08/09 02:47:01 : Blocked access attempt : TCP from 90.193.125.12:56221 to **.***.**.***:37419
2009/08/09 02:47:01 : Blocked access attempt : TCP from 78.69.193.30:64009 to **.***.**.***:37419
2009/08/09 02:47:02 : Blocked access attempt : TCP from 90.231.200.55:1676 to **.***.**.***:37419
2009/08/09 02:47:03 : Blocked access attempt : TCP from 81.232.129.197:62043 to **.***.**.***:37419
2009/08/09 02:47:03 : Blocked access attempt : TCP from 85.230.76.88:3475 to **.***.**.***:37419
2009/08/09 02:47:03 : Blocked access attempt : TCP from 85.165.245.42:50337 to **.***.**.***:37419
2009/08/09 02:47:03 : Blocked access attempt : TCP from 88.89.23.202:57850 to **.***.**.***:37419
2009/08/09 02:47:03 : Blocked access attempt : TCP from 88.8.45.9:3028 to **.***.**.***:37419
2009/08/09 02:47:03 : Blocked access attempt : TCP from 87.93.42.125:2638 to **.***.**.***:37419
2009/08/09 02:47:04 : Blocked access attempt : TCP from 82.18.249.254:62914 to **.***.**.***:37419
2009/08/09 02:47:04 : Blocked access attempt : TCP from 78.69.193.30:64009 to **.***.**.***:37419
2009/08/09 02:47:05 : Blocked access attempt : TCP from 90.231.200.55:1676 to **.***.**.***:37419
2009/08/09 02:47:06 : Blocked access attempt : TCP from 81.232.129.197:62043 to **.***.**.***:37419
2009/08/09 02:47:09 : Blocked access attempt : TCP from 85.230.76.88:3475 to **.***.**.***:37419
2009/08/09 02:47:09 : Blocked access attempt : TCP from 85.165.245.42:50337 to **.***.**.***:37419
2009/08/09 02:47:09 : Blocked access attempt : TCP from 88.89.23.202:57850 to **.***.**.***:37419
2009/08/09 02:47:09 : Blocked access attempt : TCP from 88.8.45.9:3028 to **.***.**.***:37419
2009/08/09 02:47:09 : Blocked access attempt : TCP from 87.93.42.125:2638 to **.***.**.***:37419
2009/08/09 02:47:10 : Blocked access attempt : TCP from 82.18.249.254:62914 to **.***.**.***:37419
2009/08/09 02:47:10 : Blocked access attempt : TCP from 78.69.193.30:64009 to **.***.**.***:37419
2009/08/09 02:47:11 : Blocked access attempt : TCP from 90.231.200.55:1676 to **.***.**.***:37419
2009/08/09 02:47:12 : Blocked access attempt : TCP from 81.232.129.197:62043 to **.***.**.***:37419
2009/08/09 02:49:30 : Blocked access attempt : TCP from 90.211.76.148:54070 to **.***.**.***:37419
2009/08/09 02:49:40 : Blocked access attempt : TCP from 88.91.241.161:60083 to **.***.**.***:37419
2009/08/09 02:50:22 : Blocked access attempt : TCP from 82.35.90.52:1493 to **.***.**.***:37419
2009/08/09 02:50:55 : Blocked access attempt : TCP from 77.103.29.1:50357 to **.***.**.***:37419
2009/08/09 02:51:14 : Blocked access attempt : TCP from 88.104.44.9:49793 to **.***.**.***:37419
2009/08/09 02:54:19 : Blocked access attempt : TCP from 85.164.151.145:54303 to **.***.**.***:37419
2009/08/09 02:54:24 : Blocked access attempt : TCP from 81.227.12.231:58715 to **.***.**.***:37419
2009/08/09 02:54:24 : Blocked access attempt : TCP from 90.231.147.149:20726 to **.***.**.***:37419
2009/08/09 02:54:24 : Blocked access attempt : TCP from 81.234.251.139:16715 to **.***.**.***:37419
2009/08/09 02:54:24 : Blocked access attempt : TCP from 90.200.118.212:51195 to **.***.**.***:37419
2009/08/09 02:54:24 : Blocked access attempt : TCP from 90.149.231.122:50503 to **.***.**.***:37419
2009/08/09 02:54:27 : Blocked access attempt : TCP from 81.234.251.139:16715 to **.***.**.***:37419
2009/08/09 02:54:27 : Blocked access attempt : TCP from 90.231.147.149:20726 to **.***.**.***:37419
2009/08/09 02:54:27 : Blocked access attempt : TCP from 90.200.118.212:51195 to **.***.**.***:37419
2009/08/09 02:54:27 : Blocked access attempt : TCP from 81.227.12.231:58715 to **.***.**.***:37419
2009/08/09 02:54:27 : Blocked access attempt : TCP from 90.149.231.122:50503 to **.***.**.***:37419
2009/08/09 02:54:33 : Blocked access attempt : TCP from 90.231.147.149:20726 to **.***.**.***:37419
2009/08/09 02:54:33 : Blocked access attempt : TCP from 81.234.251.139:16715 to **.***.**.***:37419
2009/08/09 02:54:33 : Blocked access attempt : TCP from 81.227.12.231:58715 to **.***.**.***:37419
2009/08/09 02:54:33 : Blocked access attempt : TCP from 90.200.118.212:51195 to **.***.**.***:37419
2009/08/09 02:54:33 : Blocked access attempt : TCP from 90.149.231.122:50503 to **.***.**.***:37419
2009/08/09 02:54:34 : Blocked access attempt : TCP from 90.229.236.123:1854 to **.***.**.***:37419
2009/08/09 02:54:34 : Blocked access attempt : TCP from 83.252.47.86:52664 to **.***.**.***:37419
2009/08/09 02:54:34 : Blocked access attempt : TCP from 81.170.241.23:3889 to **.***.**.***:37419
2009/08/09 02:54:35 : Blocked access attempt : TCP from 83.109.1.201:51486 to **.***.**.***:37419
2009/08/09 02:54:37 : Blocked access attempt : TCP from 90.229.236.123:1854 to **.***.**.***:37419
2009/08/09 02:54:37 : Blocked access attempt : TCP from 81.170.241.23:3889 to **.***.**.***:37419
2009/08/09 02:54:37 : Blocked access attempt : TCP from 83.252.47.86:52664 to **.***.**.***:37419
2009/08/09 02:54:38 : Blocked access attempt : TCP from 83.109.1.201:51486 to **.***.**.***:37419
2009/08/09 02:54:43 : Blocked access attempt : TCP from 90.229.236.123:1854 to **.***.**.***:37419
2009/08/09 02:54:43 : Blocked access attempt : TCP from 81.170.241.23:3889 to **.***.**.***:37419
2009/08/09 02:54:43 : Blocked access attempt : TCP from 83.252.47.86:52664 to **.***.**.***:37419
2009/08/09 02:54:44 : Blocked access attempt : TCP from 83.109.1.201:51486 to **.***.**.***:37419
2009/08/09 02:55:01 : Blocked access attempt : TCP from 90.231.147.149:20726 to **.***.**.***:37419
2009/08/09 02:55:03 : Blocked access attempt : TCP from 81.234.251.139:16715 to **.***.**.***:37419
2009/08/09 02:56:58 : Blocked access attempt : TCP from 86.176.178.111:50274 to **.***.**.***:37419
2009/08/09 02:57:18 : Blocked access attempt : TCP from 83.109.151.156:57316 to **.***.**.***:37419
2009/08/09 02:57:18 : Blocked access attempt : TCP from 213.65.212.65:3321 to **.***.**.***:37419
2009/08/09 02:57:21 : Blocked access attempt : TCP from 83.109.151.156:57316 to **.***.**.***:37419
2009/08/09 02:57:27 : Blocked access attempt : TCP from 213.65.212.65:3321 to **.***.**.***:37419
2009/08/09 02:57:49 : Blocked access attempt : TCP from 85.24.222.76:64183 to **.***.**.***:37419
2009/08/09 02:57:49 : Blocked access attempt : TCP from 83.109.151.156:57426 to **.***.**.***:37419
2009/08/09 02:57:49 : Blocked access attempt : TCP from 84.202.112.38:52668 to **.***.**.***:37419
2009/08/09 02:57:51 : Blocked access attempt : TCP from 213.65.212.65:3322 to **.***.**.***:37419
2009/08/09 02:57:52 : Blocked access attempt : TCP from 83.109.151.156:57426 to **.***.**.***:37419
2009/08/09 02:57:52 : Blocked access attempt : TCP from 84.202.112.38:52668 to **.***.**.***:37419
2009/08/09 02:57:57 : Blocked access attempt : TCP from 213.65.212.65:3322 to **.***.**.***:37419
2009/08/09 02:57:58 : Blocked access attempt : TCP from 83.109.151.156:57426 to **.***.**.***:37419
2009/08/09 02:57:58 : Blocked access attempt : TCP from 84.202.112.38:52668 to **.***.**.***:37419
2009/08/09 02:57:59 : Blocked access attempt : TCP from 84.215.133.86:58957 to **.***.**.***:37419
2009/08/09 03:00:02 : Wireless MAC address **:**:**:**:** has obtained IP address 192.168.1.108
2009/08/09 03:00:37 : Blocked access attempt : TCP from 81.105.73.117:1454 to **.***.**.***:37419
2009/08/09 03:00:39 : Blocked access attempt : TCP from 193.108.247.58:63902 to **.***.**.***:37419
2009/08/09 03:01:14 : Blocked access attempt : TCP from 90.231.247.118:52625 to **.***.**.***:37419
2009/08/09 03:02:01 : Blocked access attempt : TCP from 85.157.60.243:11981 to **.***.**.***:37419
2009/08/09 03:06:32 : Blocked access attempt : TCP from 81.167.158.16:2970 to **.***.**.***:37419
2009/08/09 03:06:33 : Blocked access attempt : TCP from 193.75.77.122:52888 to **.***.**.***:37419
2009/08/09 03:06:35 : Blocked access attempt : TCP from 81.167.158.16:2970 to **.***.**.***:37419
2009/08/09 03:06:36 : Blocked access attempt : TCP from 193.75.77.122:52888 to **.***.**.***:37419
2009/08/09 03:06:39 : Blocked access attempt : TCP from 85.157.60.243:11981 to **.***.**.***:37419
2009/08/09 03:06:41 : Blocked access attempt : TCP from 81.167.158.16:2970 to **.***.**.***:37419
2009/08/09 03:06:42 : Blocked access attempt : TCP from 193.75.77.122:52888 to **.***.**.***:37419
2009/08/09 03:07:02 : Blocked access attempt : TCP from 83.108.119.19:56256 to **.***.**.***:37419
2009/08/09 03:07:03 : Blocked access attempt : TCP from 81.167.158.16:2973 to **.***.**.***:37419
2009/08/09 03:07:05 : Blocked access attempt : TCP from 83.108.119.19:56256 to **.***.**.***:37419
2009/08/09 03:07:06 : Blocked access attempt : TCP from 81.167.158.16:2973 to **.***.**.***:37419
2009/08/09 03:07:07 : Blocked access attempt : TCP from 90.231.200.55:1676 to **.***.**.***:37419
2009/08/09 03:07:11 : Blocked access attempt : TCP from 83.108.119.19:56256 to **.***.**.***:37419
2009/08/09 03:07:12 : Blocked access attempt : TCP from 81.167.158.16:2973 to **.***.**.***:37419
2009/08/09 03:07:13 : Blocked access attempt : TCP from 193.216.179.234:61587 to **.***.**.***:37419
