4890 OC limit fixed!
Nizzen
It should work on all reference 4890 cards. If the PCB is different or the bios file size, do not flash it.
Reminder:
Everyone have to remember, that by flashing this bios you will loose warranty on your card. If you damage or break hardware by trying this, it is only your own fault. So, if you are not 100%, that you know what you are doing, don't do it.
Suggestion: Use latest atiflash.
http://www.xtremesystems.org/forums/showth...8334&page=9
http://rapidshare.de/files/48067239/4890FIX.bin.html
Lykke til :mrgreen:
