double layer brenner
i dag så skulle jeg til å dra til lageret til dvdink. Så traff det meg at jeg kansje hadde dl brenner. Så på fronten av pcen der stod det : dvd multi recorder rw , dvd + r dl
Betyr det da at jeg har dual layer brenner ? Pcen er cirka 2 år gammel. Eller hvordan kan jeg se om det er dual layer ?
EDIT:
Her er drevet ?
Det er vel denne? http://www.cdfreaks.com/hardware/product/8..._-TS-H652D.html
Endret av The-One
Fikk det til slutt i går. Fikk til å brenne og spille takket være deg :)
Men med img brun ville jeg brenne spillet på 2.4 men fikk 4.
Her er loggen:
:37:43 ImgBurn Version 2.5.0.0 started!
I 15:37:43 Microsoft Windows Vista Home Premium Edition (6.0, Build 6000)
I 15:37:43 Total Physical Memory: 1 038 208 KB  -  Available: 372 756 KB
I 15:37:43 Initialising SPTI...
I 15:37:43 Searching for SCSI / ATAPI devices...
I 15:37:44 Found 2 DVD-ROMs and 1 DVD±RW/RAM!
I 15:39:25 Operation Started!
I 15:39:25 Source File: C:\Users\Navn\Documents\backupspill\The.Godfather.2\backup-tgod2\backup-tgod2.dvd
I 15:39:25 Source File Sectors: 3 825 924 (MODE1/2048)
I 15:39:25 Source File Size: 7 835 492 352 bytes
I 15:39:25 Source File Volume Identifier: XGD2DVD_NTSC
I 15:39:25 Source File Volume Set Identifier: 34672923
I 15:39:25 Source File Implementation Identifier: Sonic Scenarist 3.1
I 15:39:26 Source File File System(s): ISO9660; UDF (1.02)
I 15:39:26 Destination Device: [0:1:0] TSSTcorp CD/DVDW TS-H652D GA01 (E:) (ATA)
I 15:39:26 Destination Media Type: DVD+R DL (Disc ID: MKM-003-00) (Speeds: 4x; 6x; 8x)
I 15:39:26 Destination Media Sectors: 4 173 824
I 15:39:26 Write Mode: DVD
I 15:39:26 Write Type: DAO
I 15:39:26 Write Speed: 2,4x
I 15:39:26 Link Size: Auto
I 15:39:26 Lock Volume: Yes
I 15:39:26 Test Mode: No
I 15:39:26 OPC: No
I 15:39:26 BURN-Proof: Enabled
W 15:39:26 Write Speed Miscompare! - Wanted: 3 324 KB/s (2,4x), Got: 5 540 KB/s (4x)
I 15:39:26 Book Type Setting: DVD-ROM
I 15:39:26 User Specified L0 Data Zone Capacity: 1 913 760
I 15:39:59 Set L0 Data Zone Capacity Succeeded!
I 15:40:00 Filling Buffer... (40 MB)
I 15:40:11 Writing LeadIn...
I 15:40:12 Writing Session 1 of 1... (1 Track, LBA: 0 - 3825923)
I 15:40:12 Writing Track 1 of 1... (MODE1/2048, LBA: 0 - 3825923)
I 15:40:12 Writing Layer 0... (LBA: 0 - 1913759)
I 15:51:59 Writing Layer 1... (LBA: 1913760 - 3825923)
I 16:03:48 Synchronising Cache...
I 16:03:52 Closing Track...
I 16:03:54 Finalising Disc...
I 16:04:30 Exporting Graph Data...
I 16:04:30 Graph Data File: C:\Users\NAVN\AppData\Roaming\ImgBurn\Graph Data Files\TSSTcorp_CD-DVDW_TS-H652D_GA01_14-AUGUST-2009_15-39_MKM-003-00_2,4x.ibg
I 16:04:30 Export Successfully Completed!
I 16:04:30 Operation Successfully Completed! - Duration: 00:25:04
I 16:04:30 Average Write Rate: 5 407 KB/s (3.9x) - Maximum Write Rate: 5 578 KB/s (4.0x)
Spillet funker fint men bråker mer enn de andre spillene. Kan det være fordi den brent på 4 ?
Fikk nå probløem med et spill.
Jeg testet den med abgx. Den fant en feil så den på med putte autofix til level 3.
Så gjorde jeg det. Så tok jeg testen.
Her er Loggen
───────────────▀▀▀─▀▀▀─▀▀█──────└─┘└─┘└─┘─v1.0.1───────[http://abgx360.net]────
Checking for updates to GameNameLookup.csv and abgx360.dat...
    Server file GameNameLookup.csv no newer than local file - not retrieving
    Server file abgx360.dat no newer than local file - not retrieving
C:\Users\Navn\Documents\prototypebackup.dvd is vali
d
Checking Game
    ISO: "C:\Users\Ihsan\Documents\prototypebackup.
iso"
    Size: 7838695424 bytes (SplitVid 3rd wave)
    Files in ISO: 40, Folders in ISO: 0
    Total bytes used: 7203465836 (98.70%)
Game appears to have random padding
Checking default.xex
    Original PE Filename:  prototypef.exe
    Original PE Timestamp: 2009/04/17 20:45:25
    Game Name:             [PROTOTYPE](tm)
    Developer:             Radical
    Publisher:             Activision
    Genre:                 ACTION
    Achievements:          40 Achievements totaling 1000 Gamerscore
    XEX CRC = 1071D174
    XEX Media ID: E8F9FAAC73898D30420E30A0-32211A45
Prototype
Region Code: 0xFFFFFFFF
    Region Free!
Checking SS
    Timestamp of Authoring: 2009/04/21 00:00:00
    Timestamp of Mastering: 2009/04/25 08:46:31
Caution: This SS contains a value (angle 359) that will cause older versions
of iXtreme to return a detectable bad response! Make sure your drive is flashed
with iXtreme version 1.4 or newer. Alternatively, you may enable the option to
adjust angle 359 for compatibility with iXtreme < v1.4
    SS CRC = EB359686 (RawSS = 1E00A95A)
    SS Media ID: E8F9FAAC73898D30420E30A0-32211A45 (matches game)
SS looks valid
Checking DMI
    Timestamp of Authoring: 2009/04/21 00:00:00 (matches SS)
    DMI CRC = 644072A3
    DMI Media ID: E8F9FAAC73898D30420E30A0-32211A45 (matches game)
DMI looks valid
Checking PFI
    PFI CRC = 2A4CCBD3
PFI matches known data (3rd wave - requires iXtreme v1.51 or later)
Video partition found
    Video CRC = 0E58FB9D (V0 = CF942E7B, V1 = 4809B37A)
Video partition matches known data (3rd wave - requires iXtreme v1.51 or later)
Stealth check passed!
Starting Verification
    Looking for EB3596861071D174.ini in the online verified database
    There is no verified rip of this Xex/SS combination in the online database
Failed to find a verified ini file for this Xex/SS combination
Verification failed
Starting AutoFix
    Looking for Xex_1071D174.ini in the online verified database
Downloading Xex_1071D174.ini
100% [================================>] 18
    Xex_1071D174.ini was downloaded successfully
    'Xex_1071D174.ini' contains 2 SS CRCs, randomly picked #1
    Looking for 62291BA91071D174.ini in the online verified database
Downloading 62291BA91071D174.ini
100% [================================>] 328
    62291BA91071D174.ini was downloaded successfully
    Using 62291BA91071D174.ini (328 bytes)
    Looking for SS_62291BA9.bin in the online verified database
Downloading SS_62291BA9.bin
100% [================================>] 2,048
    SS_62291BA9.bin was downloaded successfully
    Verifying SS_62291BA9.bin is valid before using it for AutoFix
Checking SS
    Timestamp of Mastering: 2009/04/24 00:00:26
    SS CRC = 62291BA9 (RawSS = A1506A17)
SS looks valid
    Automatically patching stealth files...
    Patching SS from SS_62291BA9.bin
Stealth files patched successfully!
Checking Game CRC... (press Q to cancel)
Percent  Elapsed  Estimated   Time     Average     Current     Errors    Total
   Done     Time       Time   Left       Speed       Speed  Recovered  Retries
   100%     3:21       3:21   0:00   34.6 MB/s   35.2 MB/s
    AnyDVD style corruption was not detected
    Game CRC = 28FFEB70
Game partition CRC matches the verified ini!
AutoFix was successful!
Press any key to exit . . .
Så tok jeg testen på nytt for å se
Her er den loggen:
C:\Users\Ihsan\Documents\prototypebackup.dvd is vali
d
Checking Game
iso"
    Developer:             Radical
    Genre:                 ACTION
    XEX CRC = 1071D174
Prototype
    Region Free!
Checking SS
SS looks valid
Checking DMI
    DMI CRC = 644072A3
DMI looks valid
Checking PFI
    PFI CRC = 2A4CCBD3
    Server file 62291BA91071D174.ini no newer than local file - not retrieving
    Video CRC matches
    V0    CRC matches
    V1    CRC matches
    PFI   CRC matches
    DMI   CRC matches
    SS    CRC matches
    Xex   CRC matches
   100%     2:09       2:09   0:00   53.9 MB/s   58.1 MB/s
    Game CRC = 28FFEB70 (matches)
All CRCs match
Verification was successful!
Ville prøve med xdvdmulletter å.
Når jeg lastet opp spillet ga det meg en melding:
"Video file is broken or invalid would you like to fix it?"
Trykket da på "no"
Her er bilde:
Posten ble lang men setter pris på om noen som kan dette godt kan se gjennom loggene. Er jeg trygg med dette spillet?
