slette system cache? hva skjer da?
Gjest Slettet-T9cKWhDpN0
"Q. I’ve gone through the maps several times and I still can’t find the one that I missed. HELP!!!
A. Try resetting your system or clearing the system cache. Often doing so will make a glitched Flag/Templar suddenly spawn.
To clear the cache, access 'memory' in the system blade, and then highlight the hard drive. Now press: Y, X, X, LB, RB, X, X. The following message should appear: "Do you want to perform maintenance on your Xbox 360 storage devices?""
jeg letter etter alle flaggene i assassins creed og fant en tråd hvor det over stod.
så hva skjer om jeg sletter system cache? går det utover spillene? mister jeg saves?
Endret av Slettet-T9cKWhDpN0
Gjest Slettet+19873487
Hei,
Jeg har ingen Xbox 360 selv, men hvis det menes det samme med system cache som på andre systemer, så er dette bare et mellomlager. Dette er et lite lager som sørger for at systemet jobber raskere. Selve 'saves'-ene lagres nok på selve disken.
Konklusjon: System cache på xbox 360 kan slettes/tømmes uten at du mister saves.
OBS! OBS! Kan noen bekrefte det jeg sier?
Achievements _kan_ bli slettet:
http://www.gamespot.com/pages/forums/show_...pic_id=26334264
Mer presist svar:
MORE INFORMATION
The cache is used to store items such as game updates, system updates, and gamer pictures of your friends. When you clear, or "purge," the system cache, you clear the cache for all storage devices that are connected to your Xbox 360 console.
When you clear the system cache, the following will occur:
. You will clear all the achievements that are stored in the cache.
Note This does not delete the information permanently. This action forces this information to be downloaded from Xbox LIVE again.
. You will clear all previously downloaded game updates. You must download these updates again before you play the games on Xbox LIVE .
. You will not clear system updates from the system. The console software version will not change if you clear the cache.
