Tips til gode FSX add-ons nettsider
  • 1 måned senere...
Har vi en egen flightsim x tråd? Med tilleggspakker osv?
Tongass Fjords X for FSX
- unpack the Tongass_Fjords folder to your FSX installation
- add the two scenery areas to FSX:
- Run FSX, Settings -> Scenery Library -> Add Area
- browse to the Tongass_Fjords folder, highlight the Tongass_Fjords_Lower_Priority folder, check "use directly" and hit ok
- do the same for the Higher_Priority folder and make sure it's listed above the other
- done! maps and manual found in Docs
Skjønner ikke hvordan man gjør dette, bla bla and hit OK, funker ikke hos meg, da blar den seg bare vidre i mappen
Endret av War
