Tråden for romfergeoppdraget STS-128
HKS
Oppdatering:
Tankingen av Discovery går etter planen. Det er fremdeles 80% sjans for at været er bra nok for oppskytning. Det har vært litt tordenvær rundt rampen, men ikke noe som har hindret nedtellingen.
Launch Day (Tuesday, Aug. 25)
Enter planned 2-hour, 30-minute built-in hold at T-3 hours
Complete filling the external tank with its flight load of liquid hydrogen and liquid oxygen propellants Final Inspection Team proceeds to launch pad
Perform inertial measurement unit preflight calibration
Align Merritt Island Launch Area tracking antennas
Resume countdown at T-3 hours
Perform open loop test with Eastern Range
Crew departs Operations and Checkout Building for the pad
Complete closeout preparations in the White Room
Check cockpit switch configurations
Begin Eastern Range final network open loop command checks
Flight crew begins entry into the orbiter
Astronauts perform air-to-ground voice checks with Launch and Mission Control
Begin to close Discovery’s crew hatch
Perform hatch seal and cabin leak checks
Complete White Room closeout
Closeout crew moves to fallback area
Primary ascent guidance data is transferred to the backup flight system
Enter planned 10-minute hold at T-20 minutes
NASA test director conducts final launch team briefings
Resume countdown at T-20 minutes
Transition the orbiter's onboard computers to launch configuration
Start fuel cell thermal conditioning
Close orbiter cabin vent valves
Transition backup flight system to launch configuration
Enter estimated 45-minute hold at T-9 minutes
Launch director, Mission Management Team and NASA test director conduct final polls for "go/no go" to launch
Resume countdown at T-9 minutes
Om kort tid reiser jeg opp på Press Site'n på Kennedy Space Center, så kommer til å oppdatere bloggen jevnlig derifra. Her i Florida virker stemningen som om folk regner med Discovery går av gårde. Det var en del tordenskyer i området, når jeg var ute å kjørte en tur i stad, men regner med de er borte innen oppskytingstidspunktet.
GO DISCOVERY!!
Tankingen av Discovery sin eksterne tank har nå gått inn i "topping".
Neste skritt er da å sende ut et inspeksjonsteam for å sørge for at det ikke er noen uønsket is eller annet fod på romfergen, tanken eller oppskytningsrampen.
Har du med noe foto-utstyr som takler nattoppskytning da? :)
Håper uansett du får en knallbra oppskytning. Har selv kun sett romfergeoppskytning på dagtid. For min del blir det nok et par timer søvn snart...
Checkout Crew og Inspection Team er nå ute på oppskytningsrampen.
Det begynner å bli mørkt i Florida. Discovery blir opplyst av store Xeon-lyskastere ute på oppskytningsrampe 39A. Alt ser bra ut så langt, for min del blir det noen timers pause i dekingen nå...
Over natten har værsituasjonen blitt betraktlig værre.
Det er tordenbyger i nærheten av romfergen, og redusert til kun 40% sjans for bra nok vær ved oppskytningstidspunktet.
Ellers er astronautene ombord nå, luken er lukket, og mannskapet er klar til å forlate rampen snart.
Fikk streng beskjed av Bob Cabana i går om å gi blanke i kamera ;)
Akkurat nå sitter jeg vegg i vegg med tv-studioet til CBS og Bill Harwood, som har latt oss jobbe fra bygningen deres. Det lyner i området og det ser ikke særlig bra ut.
De er i T-9 minutter og pause i nedtellingen nå.
Været blir bedre, det er bare et spørsmål om det er fort nok til å kunne blir GO før oppskytningstidspunktet. Hvis været ikke blir bra nok så gjør de et nytt forsøk imorgen.
De er snart klare til å polle oppskytningsteamet.
Det kommer nok til å bli en veldig dynamisk avgjørelse med været. De har muligheten til å begynne å telle ned fra T-9 minutter, og stoppe på T-5 minutter et par minutter for å se om været blir bra nok.
Der ble det NO GO på vær.
Det er desverre ikke sjans for at de klarer det idag. Oppskytningen må desverre utsettes med 24 timer.
Edit:
Oppskytningstidspunktet imorgen blir: 01:10 (EDT) / 07:10 (CET)
Endret av [GDI]Raptor
De jobber nå med å deaktivere utstyr, astronautene skal etterhvert ut av romfergen, og den eksterne tanken skal tømmes.
Forsøket imorgen blir som vanlig ca. 25 minutter tidligere enn idag.
På bildet ser dere Discovery ute på rampe 39A, og det regner ganske heftig. Dette viser at selv om værvarslet dagen før sier 80% sjans for oppskytning, så er det fremdeles 20% sjans for at det ikke blir bra nok...
Minner om at STS-116, som var Christer sitt forrige oppdrag også ble utsatt grunnet vær en gang.
Hva er grunnen til at de tømmer den når det kun er snakk om 24 timer utsettelse?
For det første så bruker de veldig mye drivstoff på å holde tanken full. Dette er flytende drivstoff på minus flere hundre grader, derfor koker det endel av. Når tanken er fylt opp går de inn i "Stable Replenish", dette vil egentlig si at de etterfyller det som koker av. De slutter ikke med å etterfylle tanken før et par minutter for oppskytning (da settes tanken under trykk også)
For det andre så innebærer så lave temperaturer over lang tid mye stress, både på materialer og på isolasjonsskummet på tanken, og sist men ikke minst, på grunn av sikkerhet. Når tanken er full ønsker du å begrense hvor mange du har i nærheten.
Håper det svarte på spørsmålet ditt... :)
Oppdatering fra tanking:
Problemer med en ventil i den eksterne tanken. De klarer ikke å se om den er lukket. De har stoppet å fylle hydrogen, og skal tømme tanken for å se om det hjelper. Om de allikevel har tid til å fylle tanken etterpå, og skyte opp er enda uvist.
Ventilen det er snakk om heter PV12, og er en pneumatisk ventil som kontrollerer strømmen av hydrogen ut av tanken. Dette er et kritisk system, og det kan se ut som de kommer til å avbryte for idag...
Edit:
Fill/Drain Valve kalles ventilen, og den er bak i romfergen sitt motorrom.
De har prøvd å resette ventilen, uten at det hjelper.
SCRUB!
Der ble oppskytningen avbryt for dag!
Vet enda ikke noe om når de kan prøve igjen. Tipper det blir en pressekonferanse senere idag...
Edit:
Minst 48 timers utsettelse foreløpig...
Edit 2:
30. august er siste sjanse for Discovery i dette vinduet. Etter det må de kanskje vente til oktober.
