[Løst]Finner ikke Marscore.dll
Hei, jeg lurer på hvordan man fikser feilen med att datamaskinen ikke finner Marscore.dll. Beskjeden kommer opp når jeg f.eks, går inn på Hjelp og støtte. :(
Noen som vet noe om dette problemet? ;)
(Har Windows XP Home Edition 32-bit om det skulle være nødvendig :thumbup: )
PROBLEM LØST!
Søkte litt på internett, og fant ut hvordan man løser det! :thumbup:
for all of you who are having the "marscore.dll not found" problem...I had the same problem and finally got it fixed....go to c:\windows\inf
find the Pchealth.inf file
right click it and choose install
that will reinstall the help and support center
if you get a message that says
"insert service pack CD" just hit cancel and it will ask you if you want to skip this file
say YES... do this whenever it comes up and it will finally finish installing....
hope this helps...it worked for me
sorry ...forgot to say that you need your setup disk and when you begin installing you will have to point the install toward your i386 folder
hope this helps
Endret av te8et
