help needed with a broken connection
Hi all,
Firstly, sorry about writing in english, my norwegian is nowhere near good enough to explain my problem..
Anyways, here`s the deal, we are making modiifications to our house, and unfortunately removed an internet socket from the wall - in doing so, we completely broke our internet connection.
What i have now are a bunch of different coloured wires and a box ( see pictures below
There were two sets of wires going into this box, one going in, and the other going out (to the plug we use upstairs i think).
The question is, which wires go where? all i can see are the numbers 1 to 8 in the box (see the image of the stupid box above)as you can see, i tried joining the wires together, but that didnt work.
in case the image isnt clear enough, these are the wire colours i have:
green
blue
orange
brown
blue/white striped
orange/white striped
brown/white striped
green/white striped.
i think thats it anyway.
Well, if anyone can help me solve this problem, i would be gratefull, and in return they will receive a big mac menu with extra fries and one of those mcdonalds hats with the elastic string.
seriously!
cheers
steve
Endret av steve10001
wow, quick reply,
liked the "let me google that for you" touch. I would have but as i know nothing about these things, i wasnt sure what exactly to search for.
Well anyway, i`ll give that a shot and if its a winner i`ll get that big mac menu off to you :-)
Gjest Slettet-t8fn5F
Well. Since it's your first post on this forum, it's needed to show you google. Ourr best resource on the net. It's all about asking the right question.
If you have a box upstairs, it would be a good idea to check the color coding of the cable in that very box. There are several ways to connect these and I would not assume anything until actually observed ;)
The main thing to keep in mind is that the Cat5e cable you probably are using, consists of 4 pairs. In order to transfer data it is very important to use these pairs as they are balanced. (actually what colored pair you use is not important, but its good to keep a standard for future additions)
Pair 1: 1,2 Orange/W Orange
Pair 2: 3,6 Green/W Green
Pair 3: 4,5 Blue/W Blue
Pair 4: 7,8 Brown/W Brown
The reason for the weird scheme with pair 2 is telephony can use the center pins of the RJ-45 while data is transferred on pin 123&6.
If Gigabit is used it needs all 4 pairs, while 100Mbit uses only pair 1 & pair 2.
Endret av la7dfa.com
hi again,
I tried different variations but then found that the plug upstairs is differently wired, see picture below:
(edit)
forgot to mention, we dont use a telephone landline in the house if that matters)
thanx for the help so far:-)
The box upstairs is connected correct. Just notice it starts with conductor 4 & 5.
The color coding downstairs should follow the same scheme with colors and numbers but 4 & 5 are in the middle of the row and not in the beginning.
The reason for the "weird" 45123678 upstairs is "telephony is easier to connect" since it uses the first pair there... Just old fashioned way to do it.
Downstairs you should start with the green pair, not the blue since that goes to 4 & 5 in the middle.
Pair 1: 1,2 Green/White, Green
Pair 2: 3,6 Orange/W, Orange
Pair 3: 4,5 Blue/W, Blue
Pair 4: 7,8 Brown/W, Brown
well 50% good :-), i wired up the downstairs as you said (la7dfa.com)and managed to get the router to get a stable connection from the downstairs plug, but i still get a flashing light upstairs - no connection.
i noticed that the plug upstairs has the wires in reverse - see the bottom image in my last post
Downstairs
Upstairs
Pair 1: 1,2 White, green/green
does this matter?
p.s, which of the wires actually deliver the broadband? i only ask because my freind uses only 2 wires.
cheers
steve
  • 3 uker senere...
hiya all!
here`s the update (just got back from my holiday)
well the wiring of this plug wasnt as straightforward as i though, it turns out the wiring was as la7dfa.com said in the previous reply, but with one major difference, the blue and blue/white wires were swapped from position 4&5 to position 1&2.
GOING INTO THE BOX:
GOING OUT OF THE BOX TO UPSTAIRS:
Pair 1: 1,2 Blue/W, Blue
took me ages to figure tha out.
anyway, thanks again for all your help, and hopefully this thread may help someone else out in the future.
cheers
Steve
