Diskusjonstråd: Olympus & Panasonic MicroFourThirds (+ FourThirds)
Da har pressemeldingen om E-P3 lekket ut...
Image Quality
Powerful image processor TruePic VI, a faster response time and excellent picture quality
Extremely effective, integrated in the body image stabilization for both video and sharp, blur-free images – works with any lens
12.3 effective megapixel sensor, High Speed ​​Live MOS sensor for the perfect operation in low light and when shooting HD
To ISO 12800
Record 1080i HD video with stereo audio, AVCHD recording format or the Motion JPEG
Compatibility with the new generation of dedicated lenses PEN
Ease of use
World’s fastest autofocus system – FAST AF – the camera with interchangeable lenses, from 35 AF points, highlighting the AF for pictures in low light and AF tracking the subject even outside the frame
Super light, providing wide viewing angles, touch screen 3.0 inch OLED screen with a resolution of 610.000 points – provides photo-quality color reproduction
Separate knobs for setting shutter speed and exposure
Touch Guide Live Guide available for filming and shooting HD, also in P / S / M / A
Live View mode and HD movie photos
3 programmable buttons
The scale level to facilitate the setting position in relation to the horizon
Easy to use menu function in the form of wheel settings – Live Wheel
Creativity and versatility
Ten creative artistic filters for HD movie mode and photo
Five effects that can be combined with artistic filters: Pinhole photography, Soft Focus, The effect of the frame, and new stars, and White Light Beam
Accessory Port 2 for compatibility with the ever-growing range of accessories PEN, for example, an electronic viewfinder VF-2 or the communication module penpal
Compatible with a range of 20 lenses Micro Four Thirds Four Thirds lenses 27 and over 500 other lenses (via adapter)
Shutter speeds to 1 / 4000 sec. and the shooting done at speeds up to 3 frames per second
Multiple exposure mode – 2 RAW
Li-ion battery BLS-5 long-life
Other interesting features
The timeless design of PEN, the ability to use interchangeable lenses, and attached the handle in two different sizes
The possibility of shooting 3D
Compatible with SDXC cards and Eye-Fi
Wireless flash control
Endret av eks
Bestilte meg Sigma 30mm fra JapanPhoto i dag :D
Virker som den er på vei ut av produksjon til Four Thirds kamera.
Jeg tror Sigma er på vei ut fra Four-Thirds generellt sett. Men de skal komme på µ-4/3 etter hvert. Ser nok noe der om ikke alt for lenge.
Noen som har peiling på hva E-P3 kommer til å koste, og når det kommer for salg i Norge?
Vet ikke, men tipper på 6-7000kr med kitlinse(14-42)? Skal ligge på 850euro i Europa, så burde vel være rundt der et sted.
Står august 2011 på releasene, så kommer vel forhåpentligvis da.
Jeg skal hvertfall ha ett, samme hva det koster :)
Nesten så de ikke helt hvor de vil med PEN. Nye modeller faller litt i ingenmannsland synes jeg. Hadde trodd de skulle dra det litt mer mot entusiastene men nei da. Bare nytt oppkok av forrige modell
Vesentlig raskere AF er jo en ganske stor oppgradering for entusiaster skulle man tro?
AtW
AtW
Jado det er fint det, men ikke det jeg ønsker meg.
På ønskelista mi står bl.a. egne dedikerte knapper for lukker, blender, iso, og valg av fokuspunkt.
AtW
Er ikke det delvis innfridd? Har forstått det som det var 5 custom knapper på EP3? Og valg av fokuspunkt på touchscreen?
AtW
Ville likt det bedre om de droppet blitzen, og heller la inn to plasser til hjul med blender og lukkervalg.
Rullehjulet bak burde ikke være kombi (trykkfølsomt med funksjoner) med fritt og heller lagt inn egne knapper for de funksjonene.
Formen hadde ikke trengt å være avrundet men mere firkantet for å få utnyttet størrelsen bedre. Avrundingen har ikke noe praktisk verdi, gjør ikke huset noe mindre.
Det er ikke helt enkelt å vite hva Olympus tenker, men det ser jo ikke ut som de retter noen av modellene mot virkelig proffbruk. Og det er kanskje greit nok, det er vel ikke der MFT har sin styrke heller selv om det sikkert er en del proffbrukere også.
Det som forundrer meg litt er at etter fire versjoner av essensielt det samme kameraet (E-P1, E-PL1, E-P2 og E-PL2) med litt forskjellig innpakning slår de til med tre nye modeller som igjen er essensielt det samme med litt forskjellig innpakning.
Personlig synes jeg nok den nye "plattformen" er den første virkelige oppgraderingen og da tenker jeg på AF først og fremst, men også Full HD video som i hvert fall er viktig i speclisten. Hvor bra den nye sensoren er gjenstår å se, og det gjør også om AFen er vesentlig forbedret også med gammel MFT optikk og ikke minst FT-objektiver. Og hva med følgefokus og fukus med seriebildefunksjonen?
En annen litt merkelig sak er at de lanserer tre modeller uten at en av dem er en type GH2/G3/E-620-konkurrent. De har alle elementene på plass, søkeren er bra nok, men ekstern, en modell med vribar skjerm og AMOLED-skjermen er veldig bra hvis den matcher den i XZ-1. Det ser bare ut som de ikke vil putte alle delene inn i ett kamera.
Det er også litt pussig at high end modellen har blits, men fast skjerm mens E-PL3 får vridbar skjerm, men mangler innebygd blits. Uansett, til tross for noen merkelige valg synes jeg specene ser lovende ut og får Olympus inn på banen igjen etter en litt svak periode.
Endret av seriksen
At high end modellen får blits var vel egentlig på tide - så lenge blits er nødvendig for RC-funksjonen på FL-36R, FL-50R og den nye FL-300R.
