C#: Mitt lille spill prosjekt
Gjest Slettet-aNZFa3
Disclaimer: Dette spillet har ikke noe fancy 3D eller 2D grafikk, designet er hovedsakelig bygd opp av windows forms.
Sakser dette fra et annet forum:
http://z3.invisionfree.com/Osiris_Games/in...?showtopic=8752
Old thread on different forum:
http://z10.invisionfree.com/pqgames/index.php?showtopic=389
About the game:
The user take a role of a computer company like Dell, HP, Alienware etc. The user will be able to produce computers, and consoles, later in the game PDAs, cell phones etc. The game will consist of two main databases, one for real life computer components and one for fictional components, if the user selects to use the fictional database, later then in the game the user can design it's own components, export them and share them with other users which can then import them into the game.
All components in the real life database and the fictional will have a year restriction, which means that all components are not available in the first year.
The game is going to be turnbased and with some difficult grades, choosing the easist one will result in more starting capital, easier to earn money, but the price on components will still be the same. Choosing the hardest at another hand, will result in less starting capital, and much harder to earn money, but the price on components will still be the same.
You will also be able to hire team members into your crew, and offcourse they will have salary. Some computers may also fail because of the user's lack of skill, can be raised by training in the game, the outcome of the computers will be determit the skill of the team members, the skill of the user.
The game will also have a hotseat multiplayer mode up to 8 players, the players can create alliances or be harsh opponents.
My developing blog:
http://andre-nilsen.blogspot.com/
I am also working on a light version of , and I got a pre alpha version of it.
Screenshot:
Download link:
http://www.mediafire.com/?sharekey=e23a412...04e75f6e8ebb871
Newest version, v0.1.2.3
Please report any bugs either in this thread or on my blog. You can also come up with suggestions.
Hva var feilmeldinga? I den versjonen jeg har nå, så har jeg ikke lagt med dll filen til SQL Server CE, men jeg kan gjøre det nå.
EDIT: Computers for sale 0.1.2.3 - HOTFIX, spesielt til deg :)
Under Detaljer stod dette:
Se slutten av denne meldingen for detaljert informasjon om aktivering av
JIT-feilsøking (Just In Time) i stedet for denne dialogboksen.
************** Unntakstekst **************
System.IO.FileNotFoundException: Kan ikke laste inn filen eller samlingen System.Data.SqlServerCe, Version=3.5.1.0, Culture=neutral, PublicKeyToken=89845dcd8080cc91 eller en av avhengighetene. Systemet finner ikke angitt fil.
Filnavn: System.Data.SqlServerCe, Version=3.5.1.0, Culture=neutral, PublicKeyToken=89845dcd8080cc91
ved ComputersforSale.LV.DatabaseDataSetTableAdapters.CPUTableAdapter.Fill(CPUDataTable dataTable)
ved ComputersforSale.LV.Form1.Form1_Load(Object sender, EventArgs e) i C:\Users\Andre\Documents\Visual Studio 2008\Projects\Computers for Sale - LV\Form1.cs:linje 40
ved System.Windows.Forms.Form.OnLoad(EventArgs e)
ved System.Windows.Forms.Form.OnCreateControl()
ved System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible)
ved System.Windows.Forms.Control.CreateControl()
ved System.Windows.Forms.Control.WmShowWindow(Message& m)
ved System.Windows.Forms.Control.WndProc(Message& m)
ved System.Windows.Forms.ScrollableControl.WndProc(Message& m)
ved System.Windows.Forms.ContainerControl.WndProc(Message& m)
ved System.Windows.Forms.Form.WmShowWindow(Message& m)
ved System.Windows.Forms.Form.WndProc(Message& m)
ved System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
ved System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
ved System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
ADV: Logging av samlingsbinding er slått AV.
Hvis du vil aktivere logging av mislykket samlingsbinding, setter du registerverdien [HKLM\Software\Microsoft\Fusion!EnableLog] (DWORD) til 1.
Merk: Logging av mislykket samlingsbinding vil ha litt innvirkning på ytelsen.
Hvis du vil slå av denne funksjonen, fjerner du registerverdien [HKLM\Software\Microsoft\Fusion!EnableLog].
************** Innlastede samlinger **************
mscorlib
Samlingsversjon: 2.0.0.0
Win32-versjon: 2.0.50727.4918 (NetFXspW7.050727-4900)
CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
Samlingsversjon: 0.1.2.3
Win32-versjon: 0.1.2.3
CodeBase: file:///C:/Users/rune/Desktop/ComputersForSale/Computers%20for%20Sale%20-%20LV.exe
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
System.Drawing
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
System.Data
CodeBase: file:///C:/Windows/assembly/GAC_32/System.Data/2.0.0.0__b77a5c561934e089/System.Data.dll
System.Xml
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
System.Data.DataSetExtensions
Samlingsversjon: 3.5.0.0
Win32-versjon: 3.5.30729.4918 built by: NetFXw7
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Data.DataSetExtensions/3.5.0.0__b77a5c561934e089/System.Data.DataSetExtensions.dll
System.Core
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Core/3.5.0.0__b77a5c561934e089/System.Core.dll
System.Windows.Forms.resources
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Windows.Forms.resources/2.0.0.0_no_b77a5c561934e089/System.Windows.Forms.resources.dll
mscorlib.resources
************** JIT-feilsøking **************
Når du skal aktivere JIT-feilsøking (Just In Time), må .config-filen for dette
programmet eller datamaskinen (machine.config) ha
jitDebugging-verdien angitt i delen system.windows.forms.
Programmet må også kompileres med feilsøking
aktivert.
For eksempel:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
Når JIT-feilsøking er aktivert, blir alle ubehandlede unntak
sendt til JIT-feilsøkingen som er registrert på datamaskinen,
i stedet for å bli behandlet av denne dialogboksen.
Endret av miXer
Det fungerte med den siste versjonen, men skjønte ikke stort av poenget. Var flere ganger jeg ikke fikk penger etter å ha bygd en maskin etter de spesifikasjonene som stod i tooltip'en til misson'et og da fikk jeg heller ikke bygd flere maskiner.
Rart det da, kan du spesifisere hvilke oppdrag det gjelder, så skal jeg se på det.
EDIT: Og etter at du har bygd den maskinen så må du trykke på "Next week", så skal du få penger, jeg har testet dette på alle oppdragene, og for meg så funker det.
Bare fortsett å komme med mer kritikk, så lærer jeg, og kan forbedre prosjektet.
EDIT 2: Jeg prøvde en gang til nå, og hos meg nå så var det noen oppdrag jeg ikke fikk noen penger for. Jeg jobber med saken, og prøver å fikse det i løpet av uka. (Når det er sol har jeg ikke tid, men jeg har mer tid hvis det blir overskya og regn).
EDIT 3: Jeg fant kilden til problemet etter en kjapp debug, prøver å fikse det nå.
Endret av Slettet-aNZFa3
