Session - Cookies - Login-side
Hei!
Prøver å lage en "login-side" og tenkte å bruke cookies til dette.
Fant en tutorial her.
Denne fikk jeg ikke til å virke helt... ta en titt her:
Her er login.htm:
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">
<html>
<head>
<title>Logg inn</title>
</head>
<body>
<form action="login.php" method=POST>
Username: <input type="text" name="username"> <br>
Password: <input type="password" name="thepass"> <br>
<input type="hidden" name="dt" value="1"> <br>
<input type="submit" value="Logg inn">
</form>
</body>
</html>
Login.php:
<?php
// Call this "login.php"
session_start(); // put this before ANY output is sent -- it has header information!
$dt=$_POST[dt];
$username=$_POST[username];
$thepass=$_POST[thepass];
if($dt==0) {
echo "<b>Error!</b><br><br><a href=login.htm>Gå tilbake til innloggings-siden</a>";
else if($dt==1) {
mysql_connect("127.0.0.1", "user", "password") or die("Could not connect");
mysql_select_db("it") or die("Could not select database");
$user = mysql_query("SELECT * FROM users WHERE username='$username' LIMIT 1");
if(mysql_num_rows($user) > 0) {
$user2 = mysql_fetch_array($user);
if($user2['password'] == $thepass) {
session_register("loggedin");
$loggedin = 1;
echo "Du er nå logget inn...<br> <a href="page1.php">page1.php</a> <br> n";
else { echo "Feil passord!"; }
else { echo "Feil brukernavn:<b> $username</b>! <br> n"; }
</body>
</html>
Page1.php:
<?php
// this page is page1.php
session_start(); // BEFORE HEADER OUTPUT
$creator = "Scallion";
$website = "www.scallion.sp00fed.net";
session_register("creator");
session_register("website");
echo "<a href=page2.php>Page 2</a>";
Page2.php:
<?php
// this page is page2.php
if($_SESSION['loggedin'] == 1) {
echo "Creator: ".$_SESSION['creator']."<br> n";
echo "Website: ".$_SESSION['website']."<br> n";
else {
echo "Not logged in.";
Når jeg kommer til page2.php sier den "Not logged in."
Har sett på www.php.net, men finner ikke ut av det... er det noen glupe hoder her som kan hjelpe meg litt? :)
