discover2k Skrevet 11. juli 2009 Rapporter Del Skrevet 11. juli 2009 Heisan, har lest en god del på forumet her om landeveissykkler. Ser ut som folk har god peiling og får gode svar tilbake. Jeg tenkte jeg skulle kjøpe denne sykkelen Specialized, Allez Compact -09 Ramme Specialized A1 Premium Aluminum, fully manipulated tubing, smooth weld compact race design, integrated headset Gaffel Specialized FACT carbon, carbon fiber legs, aluminum crown and steerer Bremser Ultralight dual pivot brakes, Teflon pivots, forged alloy w/ standard pads Girskifter Shimano Sora, 9-speed STI, flight deck compatible Krankgir Shimano Sora, 31.8mm clamp, bottom pull Krank Sugino, five arm, polished Nav Specialized forged alloy, 32 hole, sealed bearings, QR Felger Alex S500, sleeve joint, CNC sidewalls, 32 hole Dekk Specialized Mondo Sport, 700x23c, wire bead, 60TPI, Flak Jacket Kjede Shimano HG73, 9-speed Kassett Shimano Tiagra, 9-speed, 11-25t Styre Specialized Comp, 6061 alloy, short drop, ergonomic shaping, 31.8mm Stem Specialized Comp-Set, 3D forged alloy, 4-position adjustable, 4-bolt 31.8mm clamp Sadelpinne Specialized carbon wrapped, two-bolt clamp, 27.2mm Sadel Specialized Comp Road, full padding Pedal Silver cage, black body, w/ toe clip and strap Får den for 8500kr Hvordan er den sykkelen? Lenke til kommentar
