OpenGL virker ikke lenger (ubuntu 8.04) Intel GMA X3100
Hei!
OpenGL har fungert feilfritt tidligere, men etter en oppdatering (som jeg ikke helt husker når eller hva), så har den tatt kvelden.
glxdemo viser kun et svart vindu og cairo-dock sliter litt, for å si det sånn.
glxgears ser ut til å funke og glxheads viser en trekant eller annen geometrisk form som spretter frenetisk rundt i vinduet. :S
Noen som har noen gode råd? Evt. i hvilken ende jeg skal starte?
glxinfo.txt:
name of display: :0.0
display: :0 screen: 0
direct rendering: Yes
server glx vendor string: SGI
server glx version string: 1.2
server glx extensions:
GLX_ARB_multisample, GLX_EXT_import_context, GLX_EXT_texture_from_pixmap,
GLX_EXT_visual_info, GLX_EXT_visual_rating, GLX_MESA_copy_sub_buffer,
GLX_OML_swap_method, GLX_SGI_make_current_read, GLX_SGI_swap_control,
GLX_SGIS_multisample, GLX_SGIX_fbconfig, GLX_SGIX_visual_select_group
client glx vendor string: SGI
client glx version string: 1.4
client glx extensions:
GLX_ARB_get_proc_address, GLX_ARB_multisample, GLX_EXT_import_context,
GLX_EXT_visual_info, GLX_EXT_visual_rating, GLX_MESA_allocate_memory,
GLX_MESA_copy_sub_buffer, GLX_MESA_swap_control,
GLX_MESA_swap_frame_usage, GLX_OML_swap_method, GLX_OML_sync_control,
GLX_SGI_make_current_read, GLX_SGI_swap_control, GLX_SGI_video_sync,
GLX_SGIS_multisample, GLX_SGIX_fbconfig, GLX_SGIX_pbuffer,
GLX_SGIX_visual_select_group, GLX_EXT_texture_from_pixmap
GLX version: 1.2
GLX extensions:
GLX_MESA_swap_control, GLX_MESA_swap_frame_usage, GLX_OML_swap_method,
OpenGL vendor string: Tungsten Graphics, Inc
OpenGL renderer string: Mesa DRI Intel® 965GM 4.1.3002 x86/MMX/SSE2
OpenGL version string: 1.4 Mesa 7.0.3-rc2
OpenGL extensions:
GL_ARB_depth_texture, GL_ARB_fragment_program, GL_ARB_imaging,
GL_ARB_multisample, GL_ARB_multitexture, GL_ARB_point_parameters,
GL_ARB_shadow, GL_ARB_texture_border_clamp, GL_ARB_texture_compression,
GL_ARB_texture_cube_map, GL_ARB_texture_env_add,
GL_ARB_texture_env_combine, GL_ARB_texture_env_crossbar,
GL_ARB_texture_env_dot3, GL_ARB_texture_mirrored_repeat,
GL_ARB_texture_non_power_of_two, GL_ARB_texture_rectangle,
GL_ARB_transpose_matrix, GL_ARB_vertex_buffer_object,
GL_ARB_vertex_program, GL_ARB_window_pos, GL_EXT_abgr, GL_EXT_bgra,
GL_EXT_blend_color, GL_EXT_blend_equation_separate,
GL_EXT_blend_func_separate, GL_EXT_blend_logic_op, GL_EXT_blend_minmax,
GL_EXT_blend_subtract, GL_EXT_clip_volume_hint, GL_EXT_cull_vertex,
GL_EXT_compiled_vertex_array, GL_EXT_convolution, GL_EXT_copy_texture,
GL_EXT_draw_range_elements, GL_EXT_fog_coord, GL_EXT_histogram,
GL_EXT_multi_draw_arrays, GL_EXT_packed_pixels, GL_EXT_point_parameters,
GL_EXT_polygon_offset, GL_EXT_rescale_normal, GL_EXT_secondary_color,
GL_EXT_separate_specular_color, GL_EXT_shadow_funcs, GL_EXT_stencil_wrap,
GL_EXT_subtexture, GL_EXT_texture, GL_EXT_texture3D,
GL_EXT_texture_edge_clamp, GL_EXT_texture_env_add,
GL_EXT_texture_env_combine, GL_EXT_texture_env_dot3,
GL_EXT_texture_filter_anisotropic, GL_EXT_texture_lod_bias,
GL_EXT_texture_object, GL_EXT_texture_rectangle, GL_EXT_vertex_array,
GL_3DFX_texture_compression_FXT1, GL_APPLE_client_storage,
GL_APPLE_packed_pixels, GL_ATI_blend_equation_separate,
GL_IBM_rasterpos_clip, GL_IBM_texture_mirrored_repeat,
GL_INGR_blend_func_separate, GL_MESA_pack_invert, GL_MESA_ycbcr_texture,
GL_MESA_window_pos, GL_NV_blend_square, GL_NV_light_max_exponent,
GL_NV_texture_rectangle, GL_NV_texgen_reflection, GL_OES_read_format,
GL_SGI_color_matrix, GL_SGI_color_table, GL_SGIS_generate_mipmap,
GL_SGIS_texture_border_clamp, GL_SGIS_texture_edge_clamp,
GL_SGIS_texture_lod, GL_SGIX_depth_texture, GL_SUN_multi_draw_arrays
visual x bf lv rg d st colorbuffer ax dp st accumbuffer ms cav
id dep cl sp sz l ci b ro r g b a bf th cl r g b a ns b eat
0x23 24 tc 0 32 0 r y . 8 8 8 8 0 0 0 0 0 0 0 0 0 None
0x24 24 tc 0 32 0 r . . 8 8 8 8 0 0 0 0 0 0 0 0 0 None
0x25 24 tc 0 32 0 r y . 8 8 8 8 0 24 8 0 0 0 0 0 0 None
0x26 24 tc 0 32 0 r . . 8 8 8 8 0 24 8 0 0 0 0 0 0 None
0x27 24 tc 0 32 0 r y . 8 8 8 8 0 0 0 16 16 16 16 0 0 Slow
0x28 24 tc 0 32 0 r . . 8 8 8 8 0 0 0 16 16 16 16 0 0 Slow
0x29 24 tc 0 32 0 r y . 8 8 8 8 0 24 8 16 16 16 16 0 0 Slow
0x2a 24 tc 0 32 0 r . . 8 8 8 8 0 24 8 16 16 16 16 0 0 Slow
0x2b 24 dc 0 32 0 r y . 8 8 8 8 0 0 0 0 0 0 0 0 0 None
0x2c 24 dc 0 32 0 r . . 8 8 8 8 0 0 0 0 0 0 0 0 0 None
0x2d 24 dc 0 32 0 r y . 8 8 8 8 0 24 8 0 0 0 0 0 0 None
0x2e 24 dc 0 32 0 r . . 8 8 8 8 0 24 8 0 0 0 0 0 0 None
0x2f 24 dc 0 32 0 r y . 8 8 8 8 0 0 0 16 16 16 16 0 0 Slow
0x30 24 dc 0 32 0 r . . 8 8 8 8 0 0 0 16 16 16 16 0 0 Slow
0x31 24 dc 0 32 0 r y . 8 8 8 8 0 24 8 16 16 16 16 0 0 Slow
0x32 24 dc 0 32 0 r . . 8 8 8 8 0 24 8 16 16 16 16 0 0 Slow
0x58 32 tc 0 32 0 r . . 8 8 8 8 0 0 0 0 0 0 0 0 0 Ncon
OS: Ubuntu 8.04
Skjermkort: Intel GMA X3100 (965)
PC: Fujitsu Siemens U9200
Endret av Melkekartong
Compiz funker ikke lenger
compiz:
jan@Lapdance:~$ compiz
Checking for Xgl: not present.
Detected PCI ID for VGA: 00:02.0 0300: 8086:2a02 (rev 03) (prog-if 00 [VGA controller])
Checking for texture_from_pixmap: not present.
Trying again with indirect rendering:
Checking for texture_from_pixmap: present.
Checking for non power of two support: present.
Checking for Composite extension: present.
Comparing resolution (1280x800) to maximum 3D texture size (2048): Passed.
Checking for nVidia: not present.
Checking for FBConfig: present.
/usr/bin/compiz.real (core) - Error: Could not acquire compositing manager selection on screen 0 display ":0.0"
/usr/bin/compiz.real (core) - Fatal: No manageable screens found on display :0.0
Samt at cairodock vanligvis funka knirkefritt tidligere, mens det nå kommer opp en advarsel som ber meg starte cairo-dock -c for å IKKE bruke openGL. Dersom jeg starter cairo-dock i openGL, så blir det som skal være transparent, svart..
