[Løst]Gparted, 1.5TB disk = feilmld: length of -1 sectors error
Hei, Ubuntu og Gparted + 1.5 TB WD disk.
Har skaffet meg en en 1.5TB Western disk. Har formatert hele disken til dos label (Må gjøre det først).
Skal formatere hele disken til ext3 etterpå. Får feilmld "length of -1 sectors". Dersom jeg formaterer til 1TB eller mindre, så går det bra.
Anyone?
Google baby!
http://ubuntuforums.org/showthread.php?t=548225
Eller:
Well, I got it. I folowed the first few steps of http://eatingsecurity.blogspot.com/2...for-large.html to the letter, doing:
Code:
sudo su
parted
(parted) mklabel gpt
(parted) mkpartfs primary xfs 0 2249G
(parted) quit
...then formatting the partition to actual XFS using gparted. It must've been because I was using an msdos partition label instead of gpt, and I never knew to change that since I had no idea what any of the other ones than msdos (like gpt) were.
Marked solved. If you have this problem, use a gpt label instead of the default msdos!
Endret av Session^^
Hei.
Gjorde dette:
oyvind@pepper:~$ sudo su
[sudo] password for oyvind:
root@pepper:/home/oyvind# parted
GNU Parted 1.7.1
Using /dev/sda
Welcome to GNU Parted! Type 'help' to view a list of commands.
(parted) select /dev/sdc
Using /dev/sdc
(parted) print
Disk /dev/sdc: 1500GB
Sector size (logical/physical): 512B/512B
Partition Table: gpt
Number  Start  End  Size  File system  Name  Flags
(parted) mkpartfs primary xfs 0 1500GB
(parted) print
(parted) quit
Faar fremdeles samme feilmeld i gparted (se vedlagt bilde)post-14885-1247169151_thumb.png
Edit:Litt mer info: Ser at jeg ikke har støtte for XSF i Gparted. Er versjon 0.3.5 som er i min ubuntubox. hvordan oppdatere til 0.4.5 som er nyeste versjon?
Endret av Luske_Ludvig
