rocknrolf77 Skrevet 1. juli 2009 Del Skrevet 1. juli 2009 Er det mulig å slippe å få skrivebordsbakgrunnen dratt over 2 skjermer med dual screen oppsett? Distro : Arch Gpu : Radeon 4870 xorg.conf : # xorg.conf (X.Org X Window System server configuration file) # # This file was generated by dexconf, the Debian X Configuration tool, using # values from the debconf database. # # Edit this file with caution, and see the xorg.conf manual page. # (Type "man xorg.conf" at the shell prompt.) # # This file is automatically updated on xserver-xorg package upgrades *only* # if it has not been modified since the last upgrade of the xserver-xorg # package. # # Note that some configuration settings that could be done previously # in this file, now are automatically configured by the server and settings # here are ignored. # # If you have edited this file but would like it to be automatically updated # again, run the following command: # sudo dpkg-reconfigure -phigh xserver-xorg Section "Monitor" Identifier "Configured Monitor" EndSection Section "Monitor" Identifier "amdcccle-Monitor[1]-0" Option "VendorName" "ATI Proprietary Driver" Option "ModelName" "Generic Autodetecting Monitor" Option "DPMS" "true" EndSection Section "Monitor" Identifier "amdcccle-Monitor[1]-1" Option "VendorName" "ATI Proprietary Driver" Option "ModelName" "Generic Autodetecting Monitor" Option "DPMS" "true" EndSection Section "Screen" Identifier "Default Screen" Device "Configured Video Device" Monitor "Configured Monitor" DefaultDepth 24 SubSection "Display" Virtual 2960 1050 EndSubSection EndSection Section "Screen" Identifier "amdcccle-Screen[1]-0" Device "amdcccle-Device[1]-0" Monitor "amdcccle-Monitor[1]-0" DefaultDepth 24 SubSection "Display" Viewport 0 0 Depth 24 Virtual 2960 1050 EndSubSection EndSection Section "Screen" Identifier "amdcccle-Screen[1]-1" Device "amdcccle-Device[1]-1" Monitor "amdcccle-Monitor[1]-1" DefaultDepth 24 SubSection "Display" Viewport 0 0 Depth 24 Virtual 2960 1050 EndSubSection EndSection Section "Module" Load "glx" EndSection Section "ServerLayout" Identifier "amdcccle Layout" Screen 0 "amdcccle-Screen[1]-0" 0 0 EndSection Section "Device" Identifier "Configured Video Device" Driver "fglrx" EndSection Section "Device" Identifier "amdcccle-Device[1]-0" Driver "fglrx" BusID "PCI:1:0:0" EndSection Section "Device" Identifier "amdcccle-Device[1]-1" Driver "fglrx" BusID "PCI:1:0:0" Screen 1 EndSection Section "ServerFlags" Option "Xinerama" "off" EndSection Lenke til kommentar
HawP Skrevet 1. juli 2009 Del Skrevet 1. juli 2009 (endret) Hvis jeg forstod problemet riktig, så har du nok en av de nyere Catalyst driverne og har blitt "offer" for et problem der RandR 1.2 og/eller Catalyst ikke helt "skjønner" to-skjermsløsning. Prøv å legge inn linja Option "EnableRandR12" "false" i device seksjonen som brukes av X. I din xorg.conf slik du har "limt" den inn så skulle det da bli slik i følgende seksjon: Section "Device" Identifier "amdcccle-Device[1]-0" Driver "fglrx" Option "EnableRandR12" "false" BusID "PCI:1:0:0" EndSection Endret 1. juli 2009 av HawP Lenke til kommentar
rocknrolf77 Skrevet 2. juli 2009 Forfatter Del Skrevet 2. juli 2009 Hjalp desverre ikke Lenke til kommentar
Varj Skrevet 2. juli 2009 Del Skrevet 2. juli 2009 mitt ati-kort var ganske bugga mht flere skjermer når jeg brukte closed source driverne (catalyst), nå bruker jeg open source driverne, tilsvarende 3d ytelse (for mitt kort) og ingen problemer med flere skjermer. Lenke til kommentar
HawP Skrevet 2. juli 2009 Del Skrevet 2. juli 2009 Ah, du hadde jo en Virtual linje under Screen seksjonen også. Prøv å kommenter ut (sett # først på linja) Virtual linja i screen seksjonen identifisert med Identifier "amdcccle-Screen[1]-1" Lenke til kommentar
