Problemer med Intel WiFi Link 5300
Hei! Trenger litt hjelp her. Har problemer med å koble til det trådløse nettverket mitt. Jeg har et "Intel Wireless WiFi Link 5300"-kort og det bruker iwlagn-driveren. Distroen er forøvrig Ubuntu 9.04 som er installert på en HP Elitebook 6930p.
Jeg har prøvd å koble meg til ved å bruke NetworkManager, men da kommer det opp hele tiden at jeg må skrive inn krypteringspassordet (bruker WPA). Hvis jeg forsøker
sudo iwconfig wlan0 key s:<passord> eller sudo iwconfig wlan0 key <hexa-nøkkel>
får jeg bare opp denne feilmeldingen:
Error for wireless request "Set Encode" (8B2A) :
  SET failed on device wlan0; Invalid argument.
dmesg | grep iwlagn gir:
[	6.942164] iwlagn: Intel(R) Wireless WiFi Link AGN driver for Linux, 1.3.27ks
[	6.942166] iwlagn: Copyright(c) 2003-2008 Intel Corporation
[	6.942246] iwlagn 0000:03:00.0: PCI INT A -> GSI 17 (level, low) -> IRQ 17
[	6.942272] iwlagn 0000:03:00.0: setting latency timer to 64
[	6.942330] iwlagn: Detected Intel Wireless WiFi Link 5300AGN REV=0x24
[	6.961112] iwlagn: Tunable channels: 13 802.11bg, 24 802.11a channels
[	6.961166] iwlagn 0000:03:00.0: irq 2296 for MSI/MSI-X
[	6.961837] phy0: Selected rate control algorithm 'iwl-agn-rs'
[   15.204864] iwlagn 0000:03:00.0: firmware: requesting iwlwifi-5000-1.ucode
[   15.399502] Registered led device: iwl-phy0:radio
[   15.400052] Registered led device: iwl-phy0:assoc
[   15.400065] Registered led device: iwl-phy0:RX
[   15.400076] Registered led device: iwl-phy0:TX
dmesg | grep wlan0 gir:
[   15.405588] ADDRCONF(NETDEV_UP): wlan0: link is not ready
[   26.418865] wlan0: authenticate with AP 00:19:5b:56:7f:35
[   26.420735] wlan0: authenticated
[   26.420739] wlan0: associate with AP 00:19:5b:56:7f:35
[   26.426863] wlan0: RX AssocResp from 00:19:5b:56:7f:35 (capab=0x431 status=0 aid=1)
[   26.426866] wlan0: associated
[   26.428571] ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[   36.428715] wlan0: disassociating by local choice (reason=3)
[   36.884040] wlan0: no IPv6 routers present
[   44.920081] wlan0: deauthenticated
[   44.921271] wlan0: authenticate with AP 00:19:5b:56:7f:35
[   45.920050] wlan0: direct probe to AP 00:19:5b:56:7f:35 try 1
[   45.923496] wlan0 direct probe responded
[   45.923501] wlan0: authenticate with AP 00:19:5b:56:7f:35
[   45.925273] wlan0: authenticated
[   45.925276] wlan0: associate with AP 00:19:5b:56:7f:35
[   45.929510] wlan0: RX ReassocResp from 00:19:5b:56:7f:35 (capab=0x431 status=0 aid=1)
[   45.929513] wlan0: associated
[   55.931187] wlan0: disassociating by local choice (reason=3)
[   59.168861] wlan0: deauthenticated
[   59.169972] wlan0: authenticate with AP 00:19:5b:56:7f:35
[   60.168039] wlan0: direct probe to AP 00:19:5b:56:7f:35 try 1
[   60.171483] wlan0 direct probe responded
denne fortsetter slik og blir bare større jo flere ganger jeg prøver å koble meg til det trådløse nettet.
Noen som vet hva som er galt? Jeg har googla en del, men jeg har ikke funnet noen løsning på problemet.
Har nå fått det til. Viste seg å være en bug i driveren. Hadde ingenting med krypteringen å gjøre slik som jeg trodde. Har ikke lest så altfor nøye om denne bug'en, men slik jeg har forstått det er problemet at man ikke får ip-adresse når man kobler seg til et aksesspunkt som bruker 802.11n. Det jeg gjorde var å skru av 802.11n i aksesspunktet slik at den bare bruker 802.11g og b.
