Trenger hjelp med å installere XAMPP
Hei!
Jeg trenger hjelp til å installere XAMMP, på nettsiden står det følgende:
After downloading simply type in the following commands:
  1. Go to a Linux shell and login as the system administrator root: su
  2. Extract the downloaded archive file to /opt: tar xvfz xampp-linux-1.7.1.tar.gz -C /opt
    Warning: Please use only this command to install XAMPP. DON'T use any Microsoft Windows tools to extract the archive, it won't work.
    Warning 2: already installed XAMPP versions get overwritten by this command.
That's all. XAMPP is now installed below the /opt/lampp directory.
Men jeg får det ikke til å fungere, kan noen hjelpe meg litt?
fredrik@fredrik-laptop ~ $ sudo su
_____________________________________
/ Let him choose out of my files, his \
| projects to accomplish.             |
\ -- Shakespeare, "Coriolanus"        /
  \   \_\_    _/_/
   \      \__/
          (oo)\_______
          (__)\       )\/\
              ||----w |
fredrik-laptop fredrik # tar xvfz xampp-linux-1.7.1.tar.gz -C /opt
tar: xampp-linux-1.7.1.tar.gz: Cannot open: No such file or directory
tar: Error is not recoverable: exiting now
tar: Child returned status 2
tar: Error exit delayed from previous errors
tar xvfz /home/fredrik/Skrivebord/xampp-linux-1.7.1.tar.gz -C /opt
Blir til =
tar: lampp/var/mysql/test: Cannot mkdir: No such file or directory
lampp/var/mysql/mysql_upgrade_info
tar: lampp/var/mysql/mysql_upgrade_info: Cannot open: No such file or directory
lampp/var/mysql/freeside.err-old
tar: lampp/var/mysql/freeside.err-old: Cannot open: No such file or directory
lampp/var/proftpd/
tar: lampp/var/proftpd: Cannot mkdir: No such file or directory
lampp/var/proftpd/proftpd.delay
tar: lampp/var/proftpd/proftpd.delay: Cannot open: No such file or directory
lampp/var/run/
tar: lampp/var/run: Cannot mkdir: No such file or directory
lampp/RELEASENOTES
tar: lampp/RELEASENOTES: Cannot open: No such file or directory
lampp/lampp
tar: lampp/lampp: Cannot open: No such file or directory
lampp/libexec/
tar: lampp/libexec: Cannot mkdir: No such file or directory
lampp/build.sh
tar: lampp/build.sh: Cannot open: No such file or directory
Edit: glem det, glemte "sudo"
Endret av Blomsterbob
