Gruppere mapper i "directory of"
Jeg har mikset sammen et lite "directory of" script. Men jeg ønsker å gruppere mappene øverst. Nå sorteres alt etter alfabetisk rekkefølge.
Kan noen hjelpe meg med dette?
if (isset($_GET['dir'])) {
$subfolder = $_GET['dir'];
$count = "0";
$getDir = opendir(".$homeDir/$subfolder");
echo "<img src='./images/icons/folder.gif'> <font size='4'><a href='java script:history.go(-1)'>..</a></font><br>";
while($filename = readdir($getDir)) {
if ($filename[0]!= "." && $filename[0]!= ".." ) {
// 1. The "explode/end" approach
$ext = end(explode('.', $filename));
// 2. The "strrchr" approach
$ext = substr(strrchr($filename, '.'), 1);
// 3. The "strrpos" approach
$ext = substr($filename, strrpos($filename, '.') + 1);
// 4. The "preg_replace" approach
$ext = preg_replace('/^.*\.([^.]+)$/D', '$1', $filename);
// 5. The "never use this" approach
// From: http://php.about.com/od/finishedphp1/qt/file_ext_PHP.htm
$exts = split("[/\\.]", $filename);
$n = count($exts)-1;
$ext = $exts[$n];
if ($n == 0) { echo "<img src='./images/icons/folder.gif'> "; }
elseif ($ext == "pdf") { echo "<img src='./images/icons/pdf.gif'> "; }
elseif ($ext == "txt") { echo "<img src='./images/icons/text_plain.gif'> "; }
elseif ($ext == "pps") { echo "<img src='./images/icons/ppt.gif'> "; }
elseif ($ext == "doc") { echo "<img src='./images/icons/text.gif'> "; }
elseif ($ext == "jpg") { echo "<img src='./images/icons/image.gif'> "; }
elseif ($ext == "JPG") { echo "<img src='./images/icons/image.gif'> "; }
if ($n == 0) {
echo "<a href=\"?meny=dokumentasjon&side=javascript_input2&dir=$subfolder/$filename\">$filename</a><br>";
} else {
echo "<a href=\"?meny=dokumentasjon&side=javascript_input2&dir=$filename\">$filename</a><br>";
if ($n == 1) {
echo "<a href=\"#\" onclick=\"AddItem('$subfolder/$filename');\">$filename</a>     [ <a href='.$homeDir/$subfolder/$filename'>Åpne fil</a> ]<br>";
closedir($getDir);
Nedenfor er en kode jeg fant på php.net, koden skriver ut arrayet. Men hvordan får jeg mappene som klikkbar html?
<?php
function rec_scandir($dir)
$files = array();
if ( $handle = opendir($dir) ) {
while ( ($file = readdir($handle)) !== false ) {
if ( $file != ".." && $file != "." ) {
if ( is_dir($dir . "/" . $file) ) {
$files[$file] = rec_scandir($dir . "/" . $file);
}else {
$files[] = $file;
closedir($handle);
return $files;
function cmp($a, $b)
if ( is_string($a) && is_string($b) ) {
return strcmp($a, $b) > 0 ? 1 : -1;
}elseif ( is_int($a) && is_int($b) ) {
return $a > $b ? 1 : -1;
}elseif ( is_int($a) && is_string($b) ) {
return 1;
}elseif ( is_string($a) && is_int($b) ) {
return -1;
}else {
return 0;
function array_ukmultisort(&$arr, $func) {
uksort($arr, $func);
while ( list($key, $val) = each($arr) ) {
if ( is_array($val) ) {
array_ukmultisort($arr[$key], $func);
$dir = rec_scandir("./files");
array_ukmultisort($dir, "cmp");
echo "<pre>";
print_r($dir);
echo "</pre>";
Skrev det om litt jeg, har ikke sjekket om det faktisk fungerer ;)
Men skal ikke være all verden og debuge
La til noe eksperimentell whitespace funksjonalitet der også slik at du får linkene under
hvert directory rykket inn X antall hakk, finnes sikkert en bedre måte, men gikk fort i
svingene der.
function rec_scandir($dir, $level=0) {
$whitespace = '    ';
$ws = '';
while($i=0 < $level) {
$ws .= $ws;
$files = '';
if ($handle = opendir($dir)) {
while (($file = readdir($handle)) !== false) {
if ($file != ".." && $file != ".") {
if (is_dir($dir . "/" . $file)) {
$files .= $ws.$dir."/".$file."<br />\n";
$files .= rec_scandir($dir . "/" . $file, $level+1);
} else {
$files .= $dir."/".$file."<br />\n";
closedir($handle);
return $files;
