DxO Mark: D5000 og 500D
http://www.dxomark.com/index.php/eng/Insig...vs.-Nikon-D5000
The Nikon D5000 outperforms the Canon EOS 500D for every metric evaluated on dxomark.com, but the differences are more significant for Color Depth (1 bit is equivalent to 2/3 stop) and Dynamic Range (1 Ev is 1 stop) than for Low-Light ISO (difference between the 2 cameras is about 1/3 stop). Of course, as the Canon EOS 500D provides a 15 Mpix sensor, the sensor (with an appropriate lens) should be able to capture slightly greater detail.
In contrast to Low-Light ISO score, Color Depth and Dynamic Range characterize the sensor at low ISO settings. Even if the Nikon D5000 achieves better scores at high ISO settings, the differences observed for Dynamic Range and Color Depth are higher at low ISO settings and explain the gap between the two cameras with respect to their global DxOMark Sensor scores.
