Merkelig Apt-get problem i Debian...
Prøver å installere mplayer med apt-get (har lagt ved en server som har en unstable versjon av den nyeste).
Skriver følgende (og følgende blir feilmelding):
root@Poweredge[/home/ice-raven] apt-get install mplayer-686
Reading Package Lists... Done
Building Dependency Tree... Done
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
Since you only requested a single operation it is extremely likely that
the package is simply not installable and a bug report against
that package should be filed.
The following information may help to resolve the situation:
Sorry, but the following packages have unmet dependencies:
mplayer-686: Depends: libasound2 (> 0.9.2) but 0.9.0beta10a-3 is to be installed
Depends: libaudio2 but it is not installable
Depends: libc6 (>= 2.3.1-1) but 2.2.5-11.5 is to be installed
Depends: libcdparanoia0 (>= 3a9.8-7) but 3a9.8-6 is to be installed
Depends: libdv2 (>= 0.99) but it is not installable
Depends: libdvdnav1 (>= 0.1.3) but it is not installable
Depends: libesd0 (>= 0.2.29-1) or
libesd-alsa0 (>= 0.2.29-1) but it is not going to be installed
Depends: libfaad2-0 (>= 1.1) but it is not going to be installed
Depends: libfreetype6 (>= 2.1.4-1) but 2.0.9-1 is to be installed
Depends: libggi2 (>= 1:2.0.2) but it is not going to be installed
Depends: libncurses5 (>= 5.3.20021109-1) but 5.2.20020112a-7 is to be installed
Depends: libogg0 (>= 1.0.0) but 1.0rc3-1 is to be installed
Depends: libpostproc0 (>= 0.90rc4) but it is not going to be installed
Depends: libstdc++5 (>= 1:3.2.3-0pre6) but it is not installable
Depends: libvorbis0a (>= 1.0.0) but it is not installable
Depends: libxvidencore0 but it is not going to be installed
E: Sorry, broken packages
Jeg ANER ikke hva dette betyr...noen som har en anelse, er det fordi den er unstable, og jeg ikke har nok servere i min source.list eller er det en bug noe sted? :roll:
Takker for gode tilbakemeldinger..
Svarer litt seint..men ok...jeg har vært inne på apt-get.org og lagt til en "mplayer" server i listen min. APT-GET virker også på en hel haug av andre programmer, men det er noen som den ikke tar (de har samme "problem" som mplayer med noen spesielle pakker den ikke finner).
Er kanskje eneste muligheten å legge til de serverene som fører unstable software og dermed så vil det virke? Det ser jo ikke ut som at den har tilgang på stable pakker av en del som mplayer trenger...
Ikke vet jeg :roll: hadde bare vært morro å prøvd mplayer på denne maskina...
