praystation Skrevet 11. juni 2009 Del Skrevet 11. juni 2009 (endret) Tilleggspakken "Flash & Thunder" kommer på PSN Store i dag. Inneholder 2 nye brett: Southern Hills og Beachhead som er hentet fra det første Killzone spillet. I brettet Southern Hills vil du bli utsatt for atombomber, hvor du må finne ly så fort som mulig: Helghast Field Manual 15: Surviving the Southern HillsThe treacherous ISA forces have resorted to using nuclear devices in their futile efforts to invade our beloved home-planet of Helghan. This cowardly act will not go unpunished and the Helghast High Command training corps has prepared a field manual to ensure its loyal soldiers do not die in vain. Read the below carefully as it could be the difference between your survival of a nuclear attack and turning into a burning corpse. When you hear the siren, drop whatever you are doing. Just run like heck. A live soldier is a lot more useful to the Helghan Empire than a scorched, smoking one. You’ll only have a couple of seconds to get to cover, so don’t waste any time. Science be damned! Just Duck & Cover! If you see the nuke going off the in the distance, simply ensure that you have a roof above your head. You don’t even have to close the windows or anything. Anyone caught outside will be turned into a something resembling jerky. If you spawn in your base and hear the sirens going off, just stay where you are and the let the folks outside deal with the problems. You’ll be much quicker off the mark once the dust settles. Sentry Bots and Sentry Turrets are not immune to the devastating power of the nuke. Don’t leave them sitting outside, or they will turn into burning chunks like anything else. Place Sentry turrets inside to ensure their safety and they will cut off the enemies path to shelter. If you are inside, watch the doorways for enemies ducking inside to safety. Or even better, mow them down with an emplaced machine gun before they get anywhere near. That’ll teach ‘em to run like dogs! Out in the open? Any base can be a safe spot from the impending nuclear annihilation. If you find yourself far from home, just go duck into the enemies’ base. Your chances of survival will be higher than out in the open. The Bots in Killzone 2 do have a sense of self-preservation and when that siren sounds, they will try to save themselves as much as any living player. Follow them for the closest safe-spot, but make sure no sneaky ISA scum are hiding in there in the first place. Repaired ammo boxes and Emplaced MG’s will not be destroyed by the blast, so you won’t have to repair them again. Assassination targets! If the siren goes off, get to cover. I repeat, run like hell. Nothing worse than successfully defending the target and having it turned into smithereens before your very eyes and not being able to do anything about it. If all else fails, climb up the ladder to the roof of the central base to get a good view of the explosion in the east. It might cause you a fiery death, but damn it the explosion is too sexy not to look at in all of its splendor. Keep these tips in mind when the ISA Cruisers launch their gutless assault on our beloved planet and you might just survive another day. KILDE Endret 11. juni 2009 av praystation Lenke til kommentar
deathshot Skrevet 11. juni 2009 Del Skrevet 11. juni 2009 høres bra ut, men spiller aldri Killzone2, falt ikke i smak Lenke til kommentar
KongRudi Skrevet 13. juni 2009 Del Skrevet 13. juni 2009 Stilig trailer om atombomber: http://www.gametrailers.com/player/51411.html Lenke til kommentar
