Hjelp - Installere Hydra i Ubuntu
Jeg prøver å installere brute force-programmet Hydra i Ubuntu Jaunty Jantalope 9.04.
Under ser dere hva jeg har prøvd på så langt.
Klikk for å se/fjerne innholdet nedenfor
			{-i | -s | <command>}
usage: sudo -e [-S] [-p prompt] [-u username|#uid] file ...
kristian@kristian-laptop:~$ dir
Bilder		examples.desktop  Musikk	 Skrivebord
Dokumenter  Maler		  Offentlig  Videoer
kristian@kristian-laptop:~$ cd Skrivebord
kristian@kristian-laptop:~/Skrivebord$ dir
hydra-5.4-src  hydra-5.4-src.tar.gz
kristian@kristian-laptop:~/Skrivebord$ cd hydra-5.4-src
kristian@kristian-laptop:~/Skrivebord/hydra-5.4-src$ sudo make
[sudo] password for kristian:
gcc -I. -Wall -O2 -o pw-inspector pw-inspector.c
gcc -I. -Wall -O2 -c hydra-vnc.c
gcc -I. -Wall -O2 -c hydra-pcnfs.c
gcc -I. -Wall -O2 -c hydra-rexec.c
gcc -I. -Wall -O2 -c hydra-nntp.c
gcc -I. -Wall -O2 -c hydra-socks5.c
gcc -I. -Wall -O2 -c hydra-telnet.c
hydra-telnet.c: In function ‘service_telnet’:
hydra-telnet.c:177: warning: ignoring return value of ‘write’, declared with attribute warn_unused_result
hydra-telnet.c:191: warning: ignoring return value of ‘write’, declared with attribute warn_unused_result
hydra-telnet.c:198: warning: ignoring return value of ‘write’, declared with attribute warn_unused_result
gcc -I. -Wall -O2 -c hydra-cisco.c
gcc -I. -Wall -O2 -c hydra-http.c
gcc -I. -Wall -O2 -c hydra-ftp.c
gcc -I. -Wall -O2 -c hydra-imap.c
gcc -I. -Wall -O2 -c hydra-pop3.c
gcc -I. -Wall -O2 -c hydra-smb.c
gcc -I. -Wall -O2 -c hydra-icq.c
gcc -I. -Wall -O2 -c hydra-cisco-enable.c
gcc -I. -Wall -O2 -c hydra-ldap.c
gcc -I. -Wall -O2 -c hydra-mysql.c
gcc -I. -Wall -O2 -c hydra-http-proxy.c
gcc -I. -Wall -O2 -c hydra-smbnt.c
gcc -I. -Wall -O2 -c hydra-mssql.c
gcc -I. -Wall -O2 -c hydra-snmp.c
gcc -I. -Wall -O2 -c hydra-cvs.c
gcc -I. -Wall -O2 -c hydra-smtpauth.c
gcc -I. -Wall -O2 -c hydra-sapr3.c
gcc -I. -Wall -O2 -c hydra-ssh2.c
gcc -I. -Wall -O2 -c hydra-teamspeak.c
gcc -I. -Wall -O2 -c hydra-postgres.c
gcc -I. -Wall -O2 -c hydra-rsh.c
gcc -I. -Wall -O2 -c hydra-rlogin.c
gcc -I. -Wall -O2 -c hydra-oracle-listener.c
hydra-oracle-listener.c:10:2: warning: #warning "The Oracle Listener module does not work yet"
gcc -I. -Wall -O2 -c hydra-svn.c
gcc -I. -Wall -O2 -c hydra-pcanywhere.c
gcc -I. -Wall -O2 -c hydra-sip.c
hydra-sip.c:4:25: error: openssl/ssl.h: No such file or directory
hydra-sip.c:5:25: error: openssl/err.h: No such file or directory
hydra-sip.c:6:25: error: openssl/md5.h: No such file or directory
hydra-sip.c: In function ‘md5_crypt’:
hydra-sip.c:24: error: ‘MD5_DIGEST_LENGTH’ undeclared (first use in this function)
hydra-sip.c:24: error: (Each undeclared identifier is reported only once
hydra-sip.c:24: error: for each function it appears in.)
hydra-sip.c:26: error: ‘MD5_CTX’ undeclared (first use in this function)
hydra-sip.c:26: error: expected ‘;’ before ‘c’
hydra-sip.c:31: warning: implicit declaration of function ‘MD5_Init’
hydra-sip.c:31: error: ‘c’ undeclared (first use in this function)
hydra-sip.c:32: warning: implicit declaration of function ‘MD5_Update’
hydra-sip.c:33: warning: implicit declaration of function ‘MD5_Final’
hydra-sip.c:24: warning: unused variable ‘md5_raw’
hydra-sip.c: In function ‘sip_register’:
hydra-sip.c:60: error: ‘MD5_DIGEST_LENGTH’ undeclared (first use in this function)
hydra-sip.c:61: warning: unused variable ‘resp’
hydra-sip.c:61: warning: unused variable ‘mu’
hydra-sip.c:60: warning: unused variable ‘urp’
make: *** [hydra-sip.o] Error 1
kristian@kristian-laptop:~/Skrivebord/hydra-5.4-src$ sudo make install
kristian@kristian-laptop:~/Skrivebord/hydra-5.4-src$ hydra
bash: hydra: command not found
kristian@kristian-laptop:~/Skrivebord/hydra-5.4-src$ sudo apt-get install libssl-dev libgtk2.0-dev
E: Får ikke låst /var/lib/dpkg/lock - open (11 Resource temporarily unavailable)
E: Unable to lock the administration directory (/var/lib/dpkg/), is another process using it?
Leser pakkelister ... Ferdig
Skaper oversikt over avhengighetsforhold
Leser tilstandsinformasjon ... Ferdig
E: Klarte ikke å finne pakken libssl-dev
kristian@kristian-laptop:~/Skrivebord/hydra-5.4-src$ wget -c http://freeworld.thc.org/releases/hydra-5.4-src.tar.gz
--2009-06-09 20:41:04--  http://freeworld.thc.org/releases/hydra-5.4-src.tar.gz
Resolving freeworld.thc.org... 76.74.9.21
Connecting to freeworld.thc.org|76.74.9.21|:80... connected.
HTTP request sent, awaiting response... 200 OK
Length: 208272 (203K) [application/x-gzip]
Saving to: `hydra-5.4-src.tar.gz'
100%[======================================>] 208 272	 26,8K/s   in 7,6s
2009-06-09 20:41:15 (26,8 KB/s) - `hydra-5.4-src.tar.gz' saved [208272/208272]
kristian@kristian-laptop:~/Skrivebord/hydra-5.4-src$ ./configure
Starting hydra auto configuration ...
Checking for openssl (libssl/ssl.h) ...
								... NOT found, SSL support disabled
Get it from http://www.openssl.org
Checking for Postgres (libpq) ...
						  ... NOT found, module postgres disabled
Checking for SVN (ibsvn_client-1 libapr-0.so libaprutil-0.so) ...
						  ... NOT found, module svn disabled
Checking for SAP/R3 (librfc/saprfc.h) ...
								  ... NOT found, module sapr3 disabled
Get it from http://www.sap.com/solutions/netweaver/linux/eval/index.asp
Checking for libssh (libssh/libssh.h) ...
								  ... NOT found, module ssh2 disabled
Get it from http://0xbadc0de.be/ - use v0.11!
Hydra will be installed into .../bin of: /usr/local
 (change this by running ./configure --prefix=path)
Writing Makefile.in ...
NOTES NOTES NOTES NOTES NOTES NOTES NOTES NOTES NOTES NOTES NOTES NOTES
ARM/PalmPilot users: please run ./configure-arm or ./configure-palm respectivly
now type "make"
kristian@kristian-laptop:~/Skrivebord/hydra-5.4-src$ male
bash: male: command not found
kristian@kristian-laptop:~/Skrivebord/hydra-5.4-src$ make
kristian@kristian-laptop:~/Skrivebord/hydra-5.4-src$ make install
kristian@kristian-laptop:~/Skrivebord/hydra-5.4-src$ sudo apt-get install libssl-dev libssh-dev libpq-dev
Merk, velger libssh-2-dev istedenfor libssh-dev
Følgende ekstra pakker vil bli installert.
 comerr-dev libgcrypt11-dev libgpg-error-dev libkadm55 libkrb5-dev libpq5
 libssh-2 libssh-2-dev zlib1g-dev
Foreslåtte pakker:
 libgcrypt11-doc krb5-doc postgresql-doc-8.3 libssh-2-doc
Følgende NYE pakker vil bli installert:
 comerr-dev libgcrypt11-dev libgpg-error-dev libkadm55 libkrb5-dev libpq-dev
 libpq5 libssh-2 libssh-2-dev libssl-dev zlib1g-dev
0 oppgraderte, 11 nylig installerte, 0 å fjerne og 149 ikke oppgradert.
Må hente 3544kB med arkiver.
Etter denne operasjonen vil 12,6MB ekstra diskplass bli brukt.
Vil du fortsette [Y/n]? y
Hent:1 http://no.archive.ubuntu.com jaunty/main libgpg-error-dev 1.4-2ubuntu7 [36,0kB]
Hent:2 http://no.archive.ubuntu.com jaunty/main libgcrypt11-dev 1.4.1-2ubuntu1 [287kB]
Hent:3 http://no.archive.ubuntu.com jaunty/main libkadm55 1.6.dfsg.4~beta1-5ubuntu2 [166kB]
Hent:4 http://no.archive.ubuntu.com jaunty/main libpq5 8.3.7-1 [301kB]
Hent:5 http://no.archive.ubuntu.com jaunty/main zlib1g-dev 1:1.2.3.3.dfsg-12ubuntu2 [166kB]
Hent:6 http://no.archive.ubuntu.com jaunty/main libssl-dev 0.9.8g-15ubuntu3 [2101kB]
Hent:7 http://no.archive.ubuntu.com jaunty/main comerr-dev 2.1-1.41.4-1ubuntu1 [42,4kB]
Hent:8 http://no.archive.ubuntu.com jaunty/main libkrb5-dev 1.6.dfsg.4~beta1-5ubuntu2 [92,9kB]
Hent:9 http://no.archive.ubuntu.com jaunty/main libpq-dev 8.3.7-1 [192kB]
Hent:10 http://no.archive.ubuntu.com jaunty/universe libssh-2 0.2+svn20070321-4 [66,9kB]
Hent:11 http://no.archive.ubuntu.com jaunty/universe libssh-2-dev 0.2+svn20070321-4 [93,3kB]
Hentet 3544kB på 10min 37s (5563B/s)
Velger den tidligere fravalgte pakken libgpg-error-dev.
(Leser database ... 101349 filer og kataloger er installerte.)
Pakker ut libgpg-error-dev (fra .../libgpg-error-dev_1.4-2ubuntu7_amd64.deb) ...
Velger den tidligere fravalgte pakken libgcrypt11-dev.
Pakker ut libgcrypt11-dev (fra .../libgcrypt11-dev_1.4.1-2ubuntu1_amd64.deb) ...
Velger den tidligere fravalgte pakken libkadm55.
Pakker ut libkadm55 (fra .../libkadm55_1.6.dfsg.4~beta1-5ubuntu2_amd64.deb) ...
Velger den tidligere fravalgte pakken libpq5.
Pakker ut libpq5 (fra .../libpq5_8.3.7-1_amd64.deb) ...
Velger den tidligere fravalgte pakken zlib1g-dev.
Pakker ut zlib1g-dev (fra .../zlib1g-dev_1%3a1.2.3.3.dfsg-12ubuntu2_amd64.deb) ...
Velger den tidligere fravalgte pakken libssl-dev.
Pakker ut libssl-dev (fra .../libssl-dev_0.9.8g-15ubuntu3_amd64.deb) ...
Velger den tidligere fravalgte pakken comerr-dev.
Pakker ut comerr-dev (fra .../comerr-dev_2.1-1.41.4-1ubuntu1_amd64.deb) ...
Velger den tidligere fravalgte pakken libkrb5-dev.
Pakker ut libkrb5-dev (fra .../libkrb5-dev_1.6.dfsg.4~beta1-5ubuntu2_amd64.deb) ...
Velger den tidligere fravalgte pakken libpq-dev.
Pakker ut libpq-dev (fra .../libpq-dev_8.3.7-1_amd64.deb) ...
Velger den tidligere fravalgte pakken libssh-2.
Pakker ut libssh-2 (fra .../libssh-2_0.2+svn20070321-4_amd64.deb) ...
Velger den tidligere fravalgte pakken libssh-2-dev.
Pakker ut libssh-2-dev (fra .../libssh-2-dev_0.2+svn20070321-4_amd64.deb) ...
Behandler utløsere for man-db ...
Behandler utløsere for doc-base ...
Processing 23 changed, 1 added doc-base file(s)...
Registering documents with scrollkeeper...
Setter opp libgpg-error-dev (1.4-2ubuntu7) ...
Setter opp libgcrypt11-dev (1.4.1-2ubuntu1) ...
Setter opp libkadm55 (1.6.dfsg.4~beta1-5ubuntu2) ...
Setter opp libpq5 (8.3.7-1) ...
Setter opp zlib1g-dev (1:1.2.3.3.dfsg-12ubuntu2) ...
Setter opp libssl-dev (0.9.8g-15ubuntu3) ...
Setter opp comerr-dev (2.1-1.41.4-1ubuntu1) ...
Setter opp libkrb5-dev (1.6.dfsg.4~beta1-5ubuntu2) ...
Setter opp libpq-dev (8.3.7-1) ...
Setter opp libssh-2 (0.2+svn20070321-4) ...
Setter opp libssh-2-dev (0.2+svn20070321-4) ...
Behandler utløsere for libc6 ...
ldconfig deferred processing now taking place
kristian@kristian-laptop:~/Skrivebord/hydra-5.4-src$ clean ./configure
bash: clean: command not found
								... found
						  ... found
								  ... found
NOTE: ensure that you have libssh v0.11 installed!! Get it from http://0xbadc0de.be !
now type "make"
gcc -I. -Wall -O2 -c hydra-sip.c -DLIBOPENSSL -DLIBPOSTGRES -DLIBSSH
gcc -I. -Wall -O2 -c hydra-vmauthd.c -DLIBOPENSSL -DLIBPOSTGRES -DLIBSSH
gcc -I. -Wall -O2 -c hydra-http-proxy-auth-ntlm.c -DLIBOPENSSL -DLIBPOSTGRES -DLIBSSH
gcc -I. -Wall -O2 -c hydra-imap-ntlm.c -DLIBOPENSSL -DLIBPOSTGRES -DLIBSSH
gcc -I. -Wall -O2 -c hydra-pop3-ntlm.c -DLIBOPENSSL -DLIBPOSTGRES -DLIBSSH
gcc -I. -Wall -O2 -c hydra-smtpauth-ntlm.c -DLIBOPENSSL -DLIBPOSTGRES -DLIBSSH
gcc -I. -Wall -O2 -c hydra-http-form.c -DLIBOPENSSL -DLIBPOSTGRES -DLIBSSH
hydra-http-form.c: In function ‘start_http_form’:
hydra-http-form.c:119: warning: format ‘%d’ expects type ‘int’, but argument 9 has type ‘size_t’
hydra-http-form.c:131: warning: format ‘%d’ expects type ‘int’, but argument 8 has type ‘size_t’
hydra-http-form.c:142: warning: format ‘%d’ expects type ‘int’, but argument 6 has type ‘size_t’
gcc -I. -Wall -O2 -c crc32.c -DLIBOPENSSL -DLIBPOSTGRES -DLIBSSH
gcc -I. -Wall -O2 -c d3des.c -DLIBOPENSSL -DLIBPOSTGRES -DLIBSSH
gcc -I. -Wall -O2 -c md4.c -DLIBOPENSSL -DLIBPOSTGRES -DLIBSSH
gcc -I. -Wall -O2 -c hydra-mod.c -DLIBOPENSSL -DLIBPOSTGRES -DLIBSSH
hydra-mod.c: In function ‘hydra_child_exit’:
hydra-mod.c:279: warning: ignoring return value of ‘write’, declared with attribute warn_unused_result
hydra-mod.c:281: warning: ignoring return value of ‘write’, declared with attribute warn_unused_result
hydra-mod.c:283: warning: ignoring return value of ‘write’, declared with attribute warn_unused_result
hydra-mod.c: In function ‘hydra_get_next_pair’:
hydra-mod.c:297: warning: ignoring return value of ‘read’, declared with attribute warn_unused_result
hydra-mod.c: In function ‘hydra_completed_pair’:
hydra-mod.c:330: warning: ignoring return value of ‘write’, declared with attribute warn_unused_result
hydra-mod.c: In function ‘hydra_completed_pair_found’:
hydra-mod.c:339: warning: ignoring return value of ‘write’, declared with attribute warn_unused_result
hydra-mod.c:341: warning: ignoring return value of ‘write’, declared with attribute warn_unused_result
hydra-mod.c: In function ‘hydra_completed_pair_skip’:
hydra-mod.c:350: warning: ignoring return value of ‘write’, declared with attribute warn_unused_result
hydra-mod.c:352: warning: ignoring return value of ‘write’, declared with attribute warn_unused_result
gcc -I. -Wall -O2 -c ntlm.c -DLIBOPENSSL -DLIBPOSTGRES -DLIBSSH
ntlm.c: In function ‘buildAuthResponse’:
ntlm.c:1278: warning: the address of ‘lmRespData’ will always evaluate as ‘true’
ntlm.c:1279: warning: the address of ‘ntRespData’ will always evaluate as ‘true’
gcc -I. -Wall -O2 -c hydra.c -DLIBOPENSSL -DLIBPOSTGRES -DLIBSSH
hydra.c: In function ‘hydra_restore_write’:
hydra.c:328: warning: format ‘%d’ expects type ‘int’, but argument 4 has type ‘long int’
hydra.c:328: warning: format ‘%d’ expects type ‘int’, but argument 5 has type ‘long int’
hydra.c: In function ‘hydra_restore_read’:
hydra.c:356: warning: ignoring return value of ‘fgets’, declared with attribute warn_unused_result
hydra.c:364: warning: ignoring return value of ‘fread’, declared with attribute warn_unused_result
hydra.c:366: warning: ignoring return value of ‘fread’, declared with attribute warn_unused_result
hydra.c:372: warning: ignoring return value of ‘fgets’, declared with attribute warn_unused_result
hydra.c:380: warning: ignoring return value of ‘fgets’, declared with attribute warn_unused_result
hydra.c:385: warning: ignoring return value of ‘fgets’, declared with attribute warn_unused_result
hydra.c:392: warning: ignoring return value of ‘fread’, declared with attribute warn_unused_result
hydra.c:395: warning: ignoring return value of ‘fread’, declared with attribute warn_unused_result
hydra.c:402: warning: ignoring return value of ‘fread’, declared with attribute warn_unused_result
hydra.c:403: warning: ignoring return value of ‘fgets’, declared with attribute warn_unused_result
hydra.c:408: warning: ignoring return value of ‘fgets’, declared with attribute warn_unused_result
hydra.c:410: warning: ignoring return value of ‘fgets’, declared with attribute warn_unused_result
hydra.c:417: warning: ignoring return value of ‘fgets’, declared with attribute warn_unused_result
hydra.c: In function ‘hydra_spawn_arm’:
hydra.c:689: warning: ignoring return value of ‘write’, declared with attribute warn_unused_result
hydra.c: In function ‘hydra_main’:
hydra.c:1766: warning: ignoring return value of ‘write’, declared with attribute warn_unused_result
hydra.c:1895: warning: ignoring return value of ‘write’, declared with attribute warn_unused_result
gcc -I. -Wall -O2 -lm -o hydra hydra-vnc.o hydra-pcnfs.o hydra-rexec.o hydra-nntp.o hydra-socks5.o hydra-telnet.o hydra-cisco.o hydra-http.o hydra-ftp.o hydra-imap.o hydra-pop3.o hydra-smb.o hydra-icq.o hydra-cisco-enable.o hydra-ldap.o hydra-mysql.o hydra-http-proxy.o hydra-smbnt.o hydra-mssql.o hydra-snmp.o hydra-cvs.o hydra-smtpauth.o hydra-sapr3.o hydra-ssh2.o hydra-teamspeak.o hydra-postgres.o hydra-rsh.o hydra-rlogin.o hydra-oracle-listener.o hydra-svn.o hydra-pcanywhere.o hydra-sip.o hydra-vmauthd.o hydra-http-proxy-auth-ntlm.o hydra-imap-ntlm.o hydra-pop3-ntlm.o hydra-smtpauth-ntlm.o hydra-http-form.o crc32.o d3des.o md4.o hydra-mod.o ntlm.o hydra.o -lm -lssl -lpq -lssh -lcrypto -L/usr/lib -L/usr/local/lib -L/lib -L/lib -L/usr/lib || echo -e "\nIF YOU RECEIVED THE ERROR MESSAGE \"cannot find -lpq\" DO THE FOLLOWING:\n  make clean; ./configure\n  vi Makefile	<- and remove the \"-lpq\" and \"-DLIBPOSTGRES\" statements\n  make\n"
hydra.o: In function `hydra_spawn_arm':
hydra.c:(.text+0x116f): undefined reference to `service_ssh2'
hydra.c:(.text+0x11b9): undefined reference to `service_smbnt'
hydra.c:(.text+0x1297): undefined reference to `service_postgres'
collect2: ld returned 1 exit status
-e
IF YOU RECEIVED THE ERROR MESSAGE "cannot find -lpq" DO THE FOLLOWING:
 vi Makefile	<- and remove the "-lpq" and "-DLIBPOSTGRES" statements
 make
If men could get pregnant, abortion would be a sacrament
cd hydra-gtk && ./make_xhydra.sh
Trying to compile xhydra now (hydra gtk gui) - dont worry if this fails, this is really optional ...
Error: configure wasnt happy. Analyse this:
configure: error: Library requirements (gtk+-2.0 >= 2.0.0) not met; consider adjusting the PKG_CONFIG_PATH environment variable if your libraries are in a nonstandard prefix so pkg-config can find them.
make: [xhydra] Error 1 (ignored)
Now type make install
kristian@kristian-laptop:~/Skrivebord/hydra-5.4-src$ make installgcc -I. -Wall -O2 -lm -o hydra hydra-vnc.o hydra-pcnfs.o hydra-rexec.o hydra-nntp.o hydra-socks5.o hydra-telnet.o hydra-cisco.o hydra-http.o hydra-ftp.o hydra-imap.o hydra-pop3.o hydra-smb.o hydra-icq.o hydra-cisco-enable.o hydra-ldap.o hydra-mysql.o hydra-http-proxy.o hydra-smbnt.o hydra-mssql.o hydra-snmp.o hydra-cvs.o hydra-smtpauth.o hydra-sapr3.o hydra-ssh2.o hydra-teamspeak.o hydra-postgres.o hydra-rsh.o hydra-rlogin.o hydra-oracle-listener.o hydra-svn.o hydra-pcanywhere.o hydra-sip.o hydra-vmauthd.o hydra-http-proxy-auth-ntlm.o hydra-imap-ntlm.o hydra-pop3-ntlm.o hydra-smtpauth-ntlm.o hydra-http-form.o crc32.o d3des.o md4.o hydra-mod.o ntlm.o hydra.o -lm -lssl -lpq -lssh -lcrypto -L/usr/lib -L/usr/local/lib -L/lib -L/lib -L/usr/lib || echo -e "\nIF YOU RECEIVED THE ERROR MESSAGE \"cannot find -lpq\" DO THE FOLLOWING:\n  make clean; ./configure\n  vi Makefile	<- and remove the \"-lpq\" and \"-DLIBPOSTGRES\" statements\n  make\n"
-e
 make
test -e hydra.exe && touch Makefile || strip hydra pw-inspector
strip: 'hydra': No such file
make: [strip] Error 1 (ignored)
test -e hydra.exe && strip hydra.exe pw-inspector.exe || touch hydra
test -e xhydra && strip xhydra || touch Makefile
test -e hydra.exe && touch Makefile || cp hydra pw-inspector /usr/local/bin && cd /usr/local/bin && chmod 755 hydra pw-inspector
cp: cannot create regular file `/usr/local/bin/hydra': Permission denied
cp: cannot create regular file `/usr/local/bin/pw-inspector': Permission denied
make: [install] Error 1 (ignored)
test -e hydra.exe && cp hydra.exe pw-inspector.exe /usr/local/bin && cd /usr/local/bin && chmod 755 hydra.exe pw-inspector.exe || touch Makefile
test -e xhydra && cp xhydra /usr/local/bin && cd /usr/local/bin && chmod 755 xhydra
Endret av Skagen
La deler av innlegget i skjul-tag.
Hydra er å finne i diverse pakkebrønner, der Offensive Security sin nok er den som er mest aktuell for de fleste. Om du ikke absolutt installere fra kildekode, tror jeg det er bedre om du installerer fra repos.
Endret av Kadmium
Takk.
Jeg må ikke installere fra kildekode. helst ikke for å være ærlig.
Jeg har nå søkt litt rundt, men finner det vanskelig å finne lenken til Offensive Security sine repository. Det jeg tror er riktig er Backtracker4 sine pakkebrønner, men når den er lagt til Synaptic og jeg søker på hydra finner den ingenting. Noen tips/lenker til pakkebrønnen
