Nok en Wifi + Ubuntu tråd. Finner ikke maskinvaren
Bygde sammen min nye PC igår og alt fungerer bortsett fra wifi.
lspci gir meg dette:
00:00.0 Host bridge: nVidia Corporation MCP79 Host Bridge (rev b1)
00:00.1 RAM memory: nVidia Corporation MCP79 Memory Controller (rev b1)
00:03.0 ISA bridge: nVidia Corporation MCP79 LPC Bridge (rev b2)
00:03.1 RAM memory: nVidia Corporation MCP79 Memory Controller (rev b1)
00:03.2 SMBus: nVidia Corporation MCP79 SMBus (rev b1)
00:03.3 RAM memory: nVidia Corporation MCP79 Memory Controller (rev b1)
00:03.4 RAM memory: nVidia Corporation Device 0a98 (rev b1)
00:03.5 Co-processor: nVidia Corporation MCP79 Co-processor (rev b1)
00:04.0 USB Controller: nVidia Corporation MCP79 OHCI USB 1.1 Controller (rev b1)
00:04.1 USB Controller: nVidia Corporation MCP79 EHCI USB 2.0 Controller (rev b1)
00:06.0 USB Controller: nVidia Corporation MCP79 OHCI USB 1.1 Controller (rev b1)
00:06.1 USB Controller: nVidia Corporation MCP79 EHCI USB 2.0 Controller (rev b1)
00:08.0 Audio device: nVidia Corporation MCP79 High Definition Audio (rev b1)
00:09.0 PCI bridge: nVidia Corporation MCP79 PCI Bridge (rev b1)
00:0a.0 Ethernet controller: nVidia Corporation MCP79 Ethernet (rev b1)
00:0b.0 IDE interface: nVidia Corporation MCP79 SATA Controller (rev b1)
00:0c.0 PCI bridge: nVidia Corporation MCP79 PCI Express Bridge (rev b1)
00:10.0 PCI bridge: nVidia Corporation MCP79 PCI Express Bridge (rev b1)
00:15.0 PCI bridge: nVidia Corporation MCP79 PCI Express Bridge (rev b1)
00:16.0 PCI bridge: nVidia Corporation MCP79 PCI Express Bridge (rev b1)
00:17.0 PCI bridge: nVidia Corporation MCP79 PCI Express Bridge (rev b1)
00:18.0 PCI bridge: nVidia Corporation MCP79 PCI Express Bridge (rev b1)
03:00.0 VGA compatible controller: nVidia Corporation GeForce 9300 / nForce 730i (rev b1)
og lsusb gir meg dette:
Bus 002 Device 007: ID 045e:0729 Microsoft Corp.
Bus 002 Device 006: ID 05ac:0304 Apple, Inc. Optical USB Mouse [Mitsumi]
Bus 002 Device 005: ID 0409:0058 NEC Corp. HighSpeed Hub
Bus 002 Device 004: ID 160a:3184
Bus 002 Device 002: ID 04fc:0c15 Sunplus Technology Co., Ltd
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 004 Device 002: ID 0a12:0001 Cambridge Silicon Radio, Ltd Bluetooth Dongle (HCI mode)
Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 003 Device 002: ID 0a81:0101 Chesen Electronics Corp. Keyboard
Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
dette hovedkortet (inkl wifi)
*-network
description: Ethernet interface
product: MCP79 Ethernet
vendor: nVidia Corporation
physical id: a
bus info: pci@0000:00:0a.0
logical name: eth0
version: b1
serial: 00:01:2e:24:61:7b
capacity: 1GB/s
width: 32 bits
clock: 66MHz
capabilities: pm bus_master cap_list ethernet physical mii 10bt 10bt-fd 100bt 100bt-fd 1000bt-fd autonegotiation
configuration: autonegotiation=on broadcast=yes driver=forcedeth driverversion=0.61 duplex=full ip=192.168.0.101 latency=0 link=yes maxlatency=20 mingnt=1 module=forcedeth multicast=yes port=MII speed=100MB/s
*-network DISABLED
physical id: 1
logical name: pan0
serial: c2:5c:da:0d:2f:b6
capabilities: ethernet physical
configuration: broadcast=yes driver=bridge driverversion=2.3 firmware=N/A link=yes multicast=yes
Merkverdig. Logicsupply-gutta nevner jo at en GPL-lisensiert driver er ute i det fri, så hvorfor er den ikke bakt inn i kjernen? Hm, ser at artikkelen var postet 2. januar, så det kan jo være at GPL-notisen er relativt ny. Jaja, da er det bare å håpe at driveren er på plass i kjernen til 9.10, da.
  • 3 uker senere...
Kan noen av dere kompilere for meg og sende .deb-fila? Går det an?
Hvorfor ikke bake selv?
Sist jeg prøvde fikk jeg masse feilmeldinger til tross for at jeg fulgte guiden som ble linket til.
Og det ville gått mye fortere og med mindre mas og support hvis en av dere kunne avse et par minutter for en trengende forumbruker :)
Enda enklere, lim dette inn i terminalen:
sudo apt-get install module-assistant build-essential
sudo module-assistant prepare
cd
wget http://www.viaarena.com/Driver/vt6656_wlan_linux_v118.zip
Åpne din favorit filbehandler og pakk ut fila vi dro ned.
fortsetter vi:
cd VT6656_WLAN_Linux_V118
make clean
sudo make install
etter hva det står i installen da.
Min erfaring er at det er mer safe å reboote så skal det autodetectes av udev, hvis du har tid (regner med det :p). Har hatt noen morsomme affærer med å laste inn enkelte drivere uten reboot (selv om man i teorien aldri skal trenge å reboote angående moduler.)
Endret av TheMaister
