kernel Skrevet 4. juni 2009 Del Skrevet 4. juni 2009 Debugging på kommandolinjen, er det mulig dah?! Jepp, og i mange tilfeller er det veldig greit. Har gjort noen endringer i en applikasjon, og nå feiler parsing av config filer: $ bin/pin_senter.debug --front-end TFS --issuer gem --conf conf/pin_test.conf --in pregchip01.txt Loading config 'conf/pin_test.conf' ENVIRONMENT '=' TESTMATRIX SDC-SOURCE-PATH '=' data/emv/input_pin/sdc/ TFS-SOURCE-PATH '=' data/emv/input_pin/tfs/ BBS-SOURCE-PATH '=' data/emv/input_pin/bbs/ CPRF-REQUEST-PATH '=' data/emv/input_pin/temp_debet/ ISO-RESPONSE-PATH '=' data/emv/input_pin/temp_debet/ PINDB-PATH '=' data/emv/pindb/ 2009-06-04 17:46:14 ERROR 'getconf/conf_sym.c' line 686: pre-condition violation: 'SYM_LOG_FILE && is_file(value)' så programmet trynet, når LOG_FILE parameter ble lest inn. Vi fyrer opp gdb $ gdb --args bin/pin_senter.debug --front-end TFS --issuer gem --conf conf/pin_test.conf --in pregchip01.txt GNU gdb 6.8-debian Copyright © 2008 Free Software Foundation, Inc. License GPLv3+: GNU GPL version 3 or later <http://gnu.org/licenses/gpl.html> This is free software: you are free to change and redistribute it. There is NO WARRANTY, to the extent permitted by law. Type "show copying" and "show warranty" for details. This GDB was configured as "i486-linux-gnu"... for å starte debug sesjon, så kan man enten skrive break main og run, eller gdb $ start Breakpoint 1 at 0x80590cc: file src/pin_main.c, line 302. main (argc=0x9, argv=0xbfab8014) at src/pin_main.c:302 302 { jeg setter break punkt der hvor feilen var gdb $ b conf_sym.c:686 Breakpoint 2 at 0x8063440: file getconf/conf_sym.c, line 686. gdb $ info break Num Type Disp Enb Address What 2 breakpoint keep y 0x08063440 in pin_conf_add at getconf/conf_sym.c:686 og kjører via continue kommandoen: gdb $ c Loading config 'conf/pin_test.conf' ENVIRONMENT '=' TESTMATRIX SDC-SOURCE-PATH '=' data/emv/input_pin/sdc/ TFS-SOURCE-PATH '=' data/emv/input_pin/tfs/ BBS-SOURCE-PATH '=' data/emv/input_pin/bbs/ CPRF-REQUEST-PATH '=' data/emv/input_pin/temp_debet/ ISO-RESPONSE-PATH '=' data/emv/input_pin/temp_debet/ PINDB-PATH '=' data/emv/pindb/ Breakpoint 2, pin_conf_add (conf=0xbfaa6028, ctx=0x808ea00, id=SYM_LOG_FILE, value=0x808f078 "data/log/PIN_system.log") at getconf/conf_sym.c:686 686 REQUIRE( SYM_LOG_FILE && is_file(value) ); nå er vi interessert i å kikke på variabelen "value" gdb $ print value $1 = 0x808f078 "data/log/PIN_system.log" for å steppe til neste linje, next gdb $ n 2009-06-04 17:52:03 ERROR 'getconf/conf_sym.c' line 686: pre-condition violation: 'SYM_LOG_FILE && is_file(value)' Program exited with code 01. setter debug sesjon i bakgrunnen med Control-Z gdb $ [1]+ Stopped gdb --args bin/pin_senter.debug --front-end TFS --issuer gem --conf conf/pin_test.conf --in pregchip01.txt og sjekker om filen finnes $ ls data/log/ PIN_senter.log Nei, så da lager vi den $ touch data/log/PIN_system.log tar debugger opp igjen $ fg gdb --args bin/pin_senter.debug --front-end TFS --issuer gem --conf conf/pin_test.conf --in pregchip01.txt The program is not being run. setter break punkt på main $ b main Breakpoint 3 at 0x80590cc: file src/pin_main.c, line 302. og kjører fra starten igjen gdb $ run Breakpoint 3, main (argc=0x9, argv=0xbf8b7614) at src/pin_main.c:302 302 { gdb $ c Loading config 'conf/pin_test.conf' ENVIRONMENT '=' TESTMATRIX SDC-SOURCE-PATH '=' data/emv/input_pin/sdc/ TFS-SOURCE-PATH '=' data/emv/input_pin/tfs/ BBS-SOURCE-PATH '=' data/emv/input_pin/bbs/ CPRF-REQUEST-PATH '=' data/emv/input_pin/temp_debet/ ISO-RESPONSE-PATH '=' data/emv/input_pin/temp_debet/ PINDB-PATH '=' data/emv/pindb/ Breakpoint 2, pin_conf_add (conf=0xbf8a5628, ctx=0x808ea00, id=SYM_LOG_FILE, value=0x808f078 "data/log/PIN_system.log") at getconf/conf_sym.c:686 686 REQUIRE( SYM_LOG_FILE && is_file(value) ); tilbake til der hvor programmet feilet, stepper til neste linje gdb $ n 687 conf->fname_log = xstrdup(value); vola, det virket! Her er gdbinit filen min: # INSTRUCTIONS: save as ~/.gdbinit # # DESCRIPTION: A cracker-friendly gdb configuration file. # # REVISION : 7 # # CONTRIBUTORS: mammon_, elaine, pusillus, mong, tor # # FEEDBACK: http://board.anticrack.de/viewforum.php?f=35 # # NOTES: 'help user' in gdb will list the commands/descriptions in this file # 'context on' now enables auto-display of context screen # # CHANGELOG: # Version 7 # removed much stuff that didn't work, added "des" # Version 6.1 # fixed filename in step_to_call so it points to /dev/null # changed location of logfiles from /tmp to ~ # Version 6j # added print_insn_type, get_insn_type, context-on, context-off commands # added trace_calls, trace_run, step_to_call commands # changed hook-stop so it checks $SHOW_CONTEXT variable # Version 5 # added bpm, dump_bin, dump_hex, bp_alloc commands # added 'assemble' by elaine, 'gas_asm' by mong # added Tip Topics for aspiring crackers # Version 4 # added eflags-changing insns by pusillus # added bp, nop, null, and int3 patch commands, also hook-stop # Version 3 # incorporated elaine's if/else goodness into the hex/ascii dump # Version 2 # radix bugfix by elaine # TODO: # * add global vars to allow user to control stack,data,code win sizes # * add dump, append, set write, etc commands # * more tips! # __________________gdb options_________________ set confirm off set verbose off # #set prompt 33[01;m33] niel@gdb $ 33[0m # set prompt 33[31mgdb $ 33[0m set output-radix 0x10 set input-radix 0x10 # # These make gdb never pause in its output # set height 0 set width 0 # why do these not work??? ==> REMOVE #set $SHOW_CONTEXT = 1 #set $SHOW_NEST_INSN=0 set disassembly-flavor intel # ______________breakpoint aliases_____________ define bpl info breakpoints end document bpl List breakpoints end define bp #set $SHOW_CONTEXT = 1 break * $arg0 end document bp Set a breakpoint on address Usage: bp addr end define bpc clear $arg0 end document bpc Clear breakpoint at function/address Usage: bpc addr end define bpe enable $arg0 end document bpe Enable breakpoint # Usage: bpe num end define bpd disable $arg0 end document bpd Disable breakpoint # Usage: bpd num end define bpt set $SHOW_CONTEXT = 1 tbreak $arg0 end document bpt Set a temporary breakpoint on address Usage: bpt addr end define bpm set $SHOW_CONTEXT = 1 awatch $arg0 end document bpm Set a read/write breakpoint on address Usage: bpm addr end define bhb set $SHOW_CONTEXT = 1 hb * $arg0 end document bhb Set Hardware Assisted breakpoint on address Usage: bhb addr end # ______________process information____________ define argv show args end document argv Print program arguments end define stack info stack end document stack Print call stack end define frame info frame info args info locals end document frame Print stack frame end define flags if (($eflags >> 0xB) & 1 ) printf "O " else printf "o " end if (($eflags >> 0xA) & 1 ) printf "D " else printf "d " end if (($eflags >> 9) & 1 ) printf "I " else printf "i " end if (($eflags >> 8) & 1 ) printf "T " else printf "t " end if (($eflags >> 7) & 1 ) printf "S " else printf "s " end if (($eflags >> 6) & 1 ) printf "Z " else printf "z " end if (($eflags >> 4) & 1 ) printf "A " else printf "a " end if (($eflags >> 2) & 1 ) printf "P " else printf "p " end if ($eflags & 1) printf "C " else printf "c " end printf "\n" end document flags Print flags register end define eflags printf " OF <%d> DF <%d> IF <%d> TF <%d>",\ (($eflags >> 0xB) & 1 ), (($eflags >> 0xA) & 1 ), \ (($eflags >> 9) & 1 ), (($eflags >> 8) & 1 ) printf " SF <%d> ZF <%d> AF <%d> PF <%d> CF <%d>\n",\ (($eflags >> 7) & 1 ), (($eflags >> 6) & 1 ),\ (($eflags >> 4) & 1 ), (($eflags >> 2) & 1 ), ($eflags & 1) printf " ID <%d> VIP <%d> VIF <%d> AC <%d>",\ (($eflags >> 0x15) & 1 ), (($eflags >> 0x14) & 1 ), \ (($eflags >> 0x13) & 1 ), (($eflags >> 0x12) & 1 ) printf " VM <%d> RF <%d> NT <%d> IOPL <%d>\n",\ (($eflags >> 0x11) & 1 ), (($eflags >> 0x10) & 1 ),\ (($eflags >> 0xE) & 1 ), (($eflags >> 0xC) & 3 ) end document eflags Print entire eflags register end define reg printf " eax:%08X ebx:%08X ecx:%08X ", $eax, $ebx, $ecx printf " edx:%08X eflags:%08X\n", $edx, $eflags printf " esi:%08X edi:%08X esp:%08X ", $esi, $edi, $esp printf " ebp:%08X eip:%08X\n", $ebp, $eip printf " cs:%04X ds:%04X es:%04X", $cs, $ds, $es printf " fs:%04X gs:%04X ss:%04X ", $fs, $gs, $ss echo 33[31m flags echo 33[0m end document reg Print CPU registers end define func info functions end document func Print functions in target end define var info variables end document var Print variables (symbols) in target end define lib info sharedlibrary end document lib Print shared libraries linked to target end define sig info signals end document sig Print signal actions for target end define thread info threads end document thread Print threads in target end define u info udot end document u Print kernel 'user' struct for target end define dis disassemble $arg0 end document dis Disassemble address Usage: dis addr end # ________________hex/ascii dump an address______________ define ascii_char # thanks elaine set $_c=*(unsigned char *)($arg0) if ( $_c < 0x20 || $_c > 0x7E ) printf "." else printf "%c", $_c end end document ascii_char Print the ASCII value of arg0 or '.' if value is unprintable end define hex_quad printf "%02X %02X %02X %02X %02X %02X %02X %02X", \ *(unsigned char*)($arg0), *(unsigned char*)($arg0 + 1), \ *(unsigned char*)($arg0 + 2), *(unsigned char*)($arg0 + 3), \ *(unsigned char*)($arg0 + 4), *(unsigned char*)($arg0 + 5), \ *(unsigned char*)($arg0 + 6), *(unsigned char*)($arg0 + 7) end document hex_quad Print eight hexadecimal bytes starting at arg0 end define hexdump printf "%08X : ", $arg0 hex_quad $arg0 printf " - " hex_quad ($arg0+8) printf " " ascii_char ($arg0) ascii_char ($arg0+1) ascii_char ($arg0+2) ascii_char ($arg0+3) ascii_char ($arg0+4) ascii_char ($arg0+5) ascii_char ($arg0+6) ascii_char ($arg0+7) ascii_char ($arg0+8) ascii_char ($arg0+9) ascii_char ($arg0+0xA) ascii_char ($arg0+0xB) ascii_char ($arg0+0xC) ascii_char ($arg0+0xD) ascii_char ($arg0+0xE) ascii_char ($arg0+0xF) printf "\n" end document hexdump Display a 16-byte hex/ASCII dump of arg0 end # # des # define des printf "%02X%02X %02X%02X %02X%02X %02X%02X", \ *(unsigned char*)($arg0), *(unsigned char*)($arg0 + 1), \ *(unsigned char*)($arg0 + 2), *(unsigned char*)($arg0 + 3), \ *(unsigned char*)($arg0 + 4), *(unsigned char*)($arg0 + 5), \ *(unsigned char*)($arg0 + 6), *(unsigned char*)($arg0 + 7) printf " - '" ascii_char ($arg0) ascii_char ($arg0+1) ascii_char ($arg0+2) ascii_char ($arg0+3) ascii_char ($arg0+4) ascii_char ($arg0+5) ascii_char ($arg0+6) ascii_char ($arg0+7) printf "'\n" end document des Print arg0 as a DES block (eight hexadecimal bytes) end # # sha - dump SHA-1 buffer # define sha set $i = 0 while $i < 20 printf "%d %02X\n", $i, *(unsigned char*)($arg0 + $i) set $i = $i + 1 end printf "\n" end document sha Print arg0 as a SHA-1 block (20 hexadecimal bytes) end #EOF Lenke til kommentar
GeirGrusom Skrevet 4. juni 2009 Del Skrevet 4. juni 2009 Er dette reklame for debugging 1985-style? Lenke til kommentar
kernel Skrevet 4. juni 2009 Forfatter Del Skrevet 4. juni 2009 Hehe, det er faktisk mange som synes dette er veldig grei metode å debugge på. Når man jobber på stormaskiner eller servere som ikke kjører Windows, så er det vanlig at GUI mangler totalt. Så dette er veldig nyttig å kunne, selv om studenter slipper unna med IDE, så gjør ikke alle profesjonelle utviklere det gitt. Lenke til kommentar
Giddion Skrevet 4. juni 2009 Del Skrevet 4. juni 2009 <snip>Når man jobber på stormaskiner eller servere som ikke kjører Windows, så er det vanlig at GUI mangler totalt. Så dette er veldig nyttig å kunne, selv om studenter slipper unna med IDE, så gjør ikke alle profesjonelle utviklere det gitt. Det stemmer det... dessverre. Takk og lov for gdbserver så man kan redusere det til et minimum Lenke til kommentar
kernel Skrevet 4. juni 2009 Forfatter Del Skrevet 4. juni 2009 Takk og lov for gdbserver så man kan redusere det til et minimum Jeg ser ungdommen gjør alle mulige krumspring for å unngå dette, de installerer cross-compiler og masse tjafs for å kunne debugge via IDE, men etter min erfaring trengs kun en backtrace og så finner jeg feilen i ca. 90% av tilfellene. De bruker lenger tid... Lenke til kommentar
Giddion Skrevet 4. juni 2009 Del Skrevet 4. juni 2009 Det er poenget når jeg bruker gdb direkte... det er rett og slett den enkleste og raskeste metoden for å finne feil i enkelte tilfeller...... men i mer kompliserte situasjoner syntes jeg at det er best med en ide.... nå har ikke jeg gdb inn i fingrenne så det blir mange oppslag i manualen og det påvirker nok mitt synspunkt Lenke til kommentar
kernel Skrevet 4. juni 2009 Forfatter Del Skrevet 4. juni 2009 (endret) nå har ikke jeg gdb inn i fingrenne så det blir mange oppslag i manualen og det påvirker nok mitt synspunkt Det er ikke så mye å huske, du kommer langt med start r - run b - break n - next s - step c - continue p - print l - list q - quit info help og for mer avansert gdb debugging, kan man ta en titt på core <core-dump> - post-mortem debugging bt - backtrace print av call stack av f.eks. <core-dump> frame n - hopper til frame nr. n i f.eks <core-dump> watch - setter watch point, dvs. break punkt når variabel endres rwatch - break punkt når variabel leses awatch - break punkt når variabel leses eller endres og for enda mer avanserte triks, kan man ta en titt på .gdbinit filen jeg postet, akkurat som jeg definerte des og sha funksjonene der, så er det enkelt å utvide med sine egne gdb makroer. Endret 4. juni 2009 av kernel Lenke til kommentar
[kami] Skrevet 5. juni 2009 Del Skrevet 5. juni 2009 en ting mange ikke vet er at man kan bytte til windowed mode ved å trykke ctr+x,ctr+a (samme for å bytte tilbake) Da får man kildekoden på øvre halvdel og kommandolinje på resten. når du stepper så er det en indikator som flytter seg etter som hvor du er i kildekoden. gdb er nyttig den, bare litt avskrekkende å bli kjent med. visual studio/valgrind er overlegene om man har det som alternativ though. Lenke til kommentar
GeirGrusom Skrevet 6. juni 2009 Del Skrevet 6. juni 2009 I VS har en øyeblikkelig oversikt over call stack, registre, variabler, watches og dissasembly mens en debugger. I tillegg har du jo edit & continue så en slipper å restarte debugging dersom en finner en liten feil. Lenke til kommentar
Giddion Skrevet 6. juni 2009 Del Skrevet 6. juni 2009 I VS har en øyeblikkelig oversikt over call stack, registre, variabler, watches og dissasembly mens en debugger.I tillegg har du jo edit & continue så en slipper å restarte debugging dersom en finner en liten feil. gdb har støtte for det også (så vidt jeg vet)... vel ikke e&c da. gdb burde ikke sammenlignes med visual studio debugger, men heller med programmer som er av samme type som gdb som f. eks. microsoft console debugger (cdb). [kami] Det med vindu modus skulle jeg gjerne vist før kernel Nice liste. Lenke til kommentar
GeirGrusom Skrevet 6. juni 2009 Del Skrevet 6. juni 2009 gdb har støtte for det også (så vidt jeg vet) Joda, jeg at det har støtte for det. Jeg laget et IDE for D en gang, og da brukte jeg gdb som debugger gjennom IDE-et ved å sende og lese tekst fra programmet. Poenget er at en får ikke vite alt samtidig fordi det ikke er GUI basert. Du må spørre etter forskjellige ting. I et IDE er alle opplysningene tilgjengelig hele tiden uten at du trenger å spørre etter dem, og du får vite verdien i en variabel ved å holde over den med musepekeren. Lenke til kommentar
kernel Skrevet 6. juni 2009 Forfatter Del Skrevet 6. juni 2009 I et IDE er alle opplysningene tilgjengelig hele tiden uten at du trenger å spørre etter dem, og du får vite verdien i en variabel ved å holde over den med musepekeren. Poenget er at man ikke alltid kan debugge et program via IDE, og i en rekke tilfeller går det veldig greit å gjøre dette på gamle måten. Forøvrig, applikasjonen jeg debugget i initiell post, går på en system uten X windows og all kommunikasjon til maskinen er stengt, skal applikasjon debugges i produksjon, må man gjøre dette direkte via konsollet. All input- og output inneholder sensitiv informasjon, og det er ikke tillatt å feilsøke produksjons data på testsystem. Den mest effektive måten å feilsøke for eksempel en server på, er ikke å sette break punkt og vente på at feiltilfelle oppstår. Noen bugs kan skje en per 100 000 skudd... andre bugs oppstår kun på produksjon maskin, hvor man som utvikler ikke nødvendigvis har tilgang. Det man gjerne får er en core dump, det å ta en backtrace, gå til riktig frame og se på variablene der, er ingen heksekunst og går utmerket uten IDE. Hvis man vedlikeholder en kernel-mode driver eller real-time kode, så er heller ikke en IDE den måten debugging (normalt) foregår på. Har ikke sett noe statistikk, men det vil ikke forundre meg om andelen av C programmerere som bedriver embedded/kernel mode utvikling nå, er større en dem som bedriver applikasjons utvikling. Lenke til kommentar
GeirGrusom Skrevet 7. juni 2009 Del Skrevet 7. juni 2009 Poenget er at man ikke alltid kan debugge et program via IDE, og i en rekke tilfeller går det veldig greit å gjøre dette på gamle måten. Forøvrig, applikasjonen jeg debugget i initiell post, går på en system uten X windows og all kommunikasjon til maskinen er stengt, skal applikasjon debugges i produksjon, må man gjøre dette direkte via konsollet. All input- og output inneholder sensitiv informasjon, og det er ikke tillatt å feilsøke produksjons data på testsystem. Er det ikke mer normalt å bare ha test-data i et test-system? Den mest effektive måten å feilsøke for eksempel en server på, er ikke å sette break punkt og vente på at feiltilfelle oppstår. Noen bugs kan skje en per 100 000 skudd... andre bugs oppstår kun på produksjon maskin, hvor man som utvikler ikke nødvendigvis har tilgang. Det man gjerne får er en core dump, det å ta en backtrace, gå til riktig frame og se på variablene der, er ingen heksekunst og går utmerket uten IDE. Ja, så klart. Hvis problemet skjer på produksjonsmaskinen er vel neppe et IDE aktuelt.Hvis man vedlikeholder en kernel-mode driver eller real-time kode, så er heller ikke en IDE den måten debugging (normalt) foregår på. Har ikke sett noe statistikk, men det vil ikke forundre meg om andelen av C programmerere som bedriver embedded/kernel mode utvikling nå, er større en dem som bedriver applikasjons utvikling. Ja, det har du nok rett i. Det finnes mange bedre alternativer til C for normal applikasjonsutvikling. Lenke til kommentar
kernel Skrevet 8. juni 2009 Forfatter Del Skrevet 8. juni 2009 (endret) Det finnes mange bedre alternativer til C for normal applikasjonsutvikling. Tja, hvilket verktøy som er best blir fort subjektivt, etter min mening kommer det først og fremst an på hva man kan godt. Så for de som kan C eller C++ best, så blir det mest effektivt å bruke det språket. Endret 8. juni 2009 av kernel Lenke til kommentar
Giddion Skrevet 8. juni 2009 Del Skrevet 8. juni 2009 <nip>Så for de som kan C eller C++ best, så blir det mest effektivt å bruke det språket. Jeg er ikke enig, med deg. Hvis prosjektet er av en hvis størrelse kan det godt hende at det lønner seg å lære seg et nytt språk. Lenke til kommentar
kernel Skrevet 8. juni 2009 Forfatter Del Skrevet 8. juni 2009 (endret) Jeg er ikke enig, med deg.Hvis prosjektet er av en hvis størrelse kan det godt hende at det lønner seg å lære seg et nytt språk. Greit nok, men forutsetningen min var at man kan språket godt. Edit: Det eneste området jeg har følt C/C++ virkelig kommer til kort, har vært til programmering av avansert logikk, men kostnaden ved å lære Lisp og/eller Prolog ser ganske avskrekkende ut... Endret 8. juni 2009 av kernel Lenke til kommentar
Giddion Skrevet 8. juni 2009 Del Skrevet 8. juni 2009 (endret) Dette blir veldig off topic, men jeg mener at man vil være mer effektiv med et høyere språk enn c++ selv om man kan c++ godt. C++ er rett og slett for tungvindt i forhold til andre språk. Det er ikke noe begrensninger i selve språket, men det er mye mer å tenke på i forhold til andre språk. Endret 8. juni 2009 av Giddion Lenke til kommentar
kernel Skrevet 9. juni 2009 Forfatter Del Skrevet 9. juni 2009 For min del, vil det å opparbeide samme kompetansenivå i ett annet språk, ta flere år. Lenke til kommentar
kernel Skrevet 9. juni 2009 Forfatter Del Skrevet 9. juni 2009 Eksempel på debugge program med Segmentation fault. #include <stdio.h> #include <string.h> void foo(void) { char *p = NULL; strcpy(p, "Seg fault"); } int main(void) { foo(); return 0; } $ gcc -g -ansi seg_fault.c $ gdb a.out GNU gdb 6.8-debian Copyright © 2008 Free Software Foundation, Inc. License GPLv3+: GNU GPL version 3 or later <http://gnu.org/licenses/gpl.html> This is free software: you are free to change and redistribute it. There is NO WARRANTY, to the extent permitted by law. Type "show copying" and "show warranty" for details. This GDB was configured as "i486-linux-gnu"... gdb $ r Program received signal SIGSEGV, Segmentation fault. 0xb7ed89ba in memcpy () from /lib/tls/i686/cmov/libc.so.6 gdb $ bt #0 0xb7ed89ba in memcpy () from /lib/tls/i686/cmov/libc.so.6 #1 0x0804839c in foo () at seg_fault.c:7 #2 0x080483b4 in main () at seg_fault.c:12 gdb $ frame 1 #1 0x0804839c in foo () at seg_fault.c:7 7 strcpy(p, "Seg fault"); gdb $ p p $1 = 0x0 gdb $ q Lenke til kommentar
GeirGrusom Skrevet 9. juni 2009 Del Skrevet 9. juni 2009 (endret) Det finnes mange bedre alternativer til C for normal applikasjonsutvikling. Tja, hvilket verktøy som er best blir fort subjektivt, etter min mening kommer det først og fremst an på hva man kan godt. Så for de som kan C eller C++ best, så blir det mest effektivt å bruke det språket. Det er jeg kjempeuenig i. For å dra sammenligningen veldig mye lenger for å understreke poenget kan en ikke si det er like enkelt å lage et program som skriver ut en Fibbonaci rekke i Assembly som det er i Haskell. Det er mange ting C++ er uegnet til, både på grunn av minnebehandling og på grunn av syntaks som andre språk ville gjort en bedre jobb. Eksempelvis er GUI noe som på tross av gode GUI biblioteker i C++ kan være betydelig enklere å få til i andre språk. Ta for eksempel C# (som jeg kan best) som har LINQ (Language Intergrated Query) for å jobbe med data i arrays (collections) XML datakilder eller SQL datakilder, lambdauttrykk og automatisk garbage collection. Dette er ting som helt klart gjør at C# for en fordel ovenfor C++ i mange oppgaver. Selv om oppgaven kan løses i C++ er ikke løsningen like elegant som den ville vært i C#. Det var jo lenge her en tråd hvor noen ønsket å lese en fil til en string, som kan gjøres med én linje i kanskje alle andre programmeringsspråk enn C++. Men øh, dette er off-topic I et IDE ville en segmentation fault gitt deg et breakpoint mye hendigere ^^ Endret 9. juni 2009 av GeirGrusom Lenke til kommentar
