No One Lives Forever? 2 - Toolkit released
Og Toolkitet kan du downloade her
Noen features:
  • Various tutorials and reference documents in an easy-to-use help file.
[*]DEdit, the NOLF 2 world editor and related applications
[*]ModelEdit, the NOLF 2 model editor and related applications
[*]FXed, The NOLF 2 Special Effects editor
[*]Utilities for working with Renderstyles
[*]Utilities for modifying Nolf2 music and sound files
[*]LithRez, a command-line program for packing and unpacking NOLF.REZ (Resource) files
[*]Nolf 2 Source Code (Req Microsoft Visual C++ version 6.0 or higher)
[*]World Importer and Exporter for 3D Studio MAX
[*]World Importer for Maya
[*]Model Exporters for 3d Studio MAX and Maya
[*]Sample level files
[*]1000+ prefabs that you can use to make professional-looking levels quickly and easily.
[*]PERL assetlist generation scripts
[*]A special, development-only version of lithtech.exe.
[*]A completed version of the Demolition tutorial mod (Demolition.zip).
