OpenFOAM og oppsett av dette.
Hei, jeg lurer på om det er noen som har erfaring med oppsett av systemvariablene til openFOAM ?
Det står iallefall følgende i readme fila :
--snip-----
3 Installation
Download and unpack the files in the $HOME/OpenFOAM directory as described in: http://www.OpenFOAM.org/download.html
The environment variable settings are contained in files in an etc/ directory in the OpenFOAM release. e.g. in
$HOME/OpenFOAM/OpenFOAM-<VERSION>/etc/
where <VERSION> corresponds to the version 1.4, 1.5, …
EITHER, if running bash or ksh (if in doubt type 'echo $SHELL'), source the etc/bashrc file by adding the following line to the end of your $HOME/.bashrc file:
. OpenFOAM/OpenFOAM-<VERSION>/etc/bashrc
Then update the environment variables by sourcing the $HOME/.bashrc file by typing in the terminal:
. $HOME/.bashrc
OR, if running tcsh or csh, source the etc/cshrc file by adding the following line to the end of your $HOME/.cshrc file:
source $HOME/OpenFOAM/OpenFOAM-<VERSION>/etc/cshrc
Then update the environment variables by sourcing the $HOME/.cshrc file by typing in the terminal:
source $HOME/.cshrc
Jeg kjører kubuntu hardy og nevnte fil ser slik ut:
# ~/.bashrc: executed by bash(1) for non-login shells.
# see /usr/share/doc/bash/examples/startup-files (in the package bash-doc)
# for examples
# If not running interactively, don't do anything
[ -z "$PS1" ] && return
# don't put duplicate lines in the history. See bash(1) for more options
export HISTCONTROL=ignoredups
# ... and ignore same sucessive entries.
export HISTCONTROL=ignoreboth
# check the window size after each command and, if necessary,
# update the values of LINES and COLUMNS.
shopt -s checkwinsize
# make less more friendly for non-text input files, see lesspipe(1)
[ -x /usr/bin/lesspipe ] && eval "$(lesspipe)"
# set variable identifying the chroot you work in (used in the prompt below)
if [ -z "$debian_chroot" ] && [ -r /etc/debian_chroot ]; then
debian_chroot=$(cat /etc/debian_chroot)
fi
# set a fancy prompt (non-color, unless we know we "want" color)
case "$TERM" in
xterm-color)
PS1='${debian_chroot:+($debian_chroot)}\[33[01;32m\]\u@\h\[33[00m\]:\[33[01;34m\]\w\[33[00m\]\$ '
PS1='${debian_chroot:+($debian_chroot)}\u@\h:\w\$ '
esac
# Comment in the above and uncomment this below for a color prompt
#PS1='${debian_chroot:+($debian_chroot)}\[33[01;32m\]\u@\h\[33[00m\]:\[33[01;34m\]\w\[33[00m\]\$ '
# If this is an xterm set the title to user@host:dir
case "$TERM" in
xterm*|rxvt*)
PROMPT_COMMAND='echo -ne "33]0;${USER}@${HOSTNAME}: ${PWD/$HOME/~}07"'
esac
# Alias definitions.
# You may want to put all your additions into a separate file like
# ~/.bash_aliases, instead of adding them here directly.
# See /usr/share/doc/bash-doc/examples in the bash-doc package.
#if [ -f ~/.bash_aliases ]; then
# . ~/.bash_aliases
#fi
# enable color support of ls and also add handy aliases
if [ "$TERM" != "dumb" ]; then
eval "`dircolors -b`"
alias ls='ls --color=auto'
#alias dir='ls --color=auto --format=vertical'
#alias vdir='ls --color=auto --format=long'
fi
# some more ls aliases
#alias ll='ls -l'
#alias la='ls -A'
#alias l='ls -CF'
# enable programmable completion features (you don't need to enable
# this, if it's already enabled in /etc/bash.bashrc and /etc/profile
# sources /etc/bash.bashrc).
if [ -f /etc/bash_completion ]; then
. /etc/bash_completion
. $HOME/isprins/OpenFOAM/OpenFOAM-1.5/.OpenFOAM-1.5/bashrc
fi
Jeg får følgende melding ved åpning av konsoll:
bash: /isprins/OpenFOAM/OpenFOAM-1.5/.OpenFOAM-1.5/bashrc: No such file or directory
Hva er det jeg har gjort feil ?
Erstatt
med
. OpenFOAM/OpenFOAM-1.5/etc/bashrc
i .bashrc (vurder å flytte linjen helt nederst, den har ingenting i if-statement å gjøre).
