Firefox blokkerer for innlegg på forum. Hvordan skru av dette?
Får opp denne meldingen:
The host from which you are accessing the board is not recognized as a valid host. This is more than likely related to a firewall issue that is blocking the referer variable. Check your firewall settings and try again.
Bruk tilbake-knappen for å returnere til forrige side.
Hvordan får jeg enablet dette?
Dette har trolig med Norton og brannmur å gjøre.
Når forumet sjekker "http referer" så kan brannmuren blokkere.
Du får prøve å slå av brannmuren for å se om det funker da. I såfall kan du endre innstillingene for http referer.
Basically this is a quick check to make sure that the posting form is being submitted from the website, and not saved to the person's harddrive, altered and submitted. It's easy to spoof the referer variable, and many people have it disabled on their system via their firewall, so alot of .threads owners turn this setting off.
