Effectiv Skrevet 26. mai 2009 Del Skrevet 26. mai 2009 (endret) Hei! Har noen problemer på en pc her. Den fryser når jeg spiller, klikker når jeg spiller, klikker når man brenner cd osv osv. Masse bluescreens osv Har brukt Windbg for å lese minnedumpene, har 4 forskjellige dumper som jeg kunne trengt hjelp for å finne ut hva som er gale med Dump 1: Microsoft ® Windows Debugger Version 6.11.0001.404 X86 Copyright © Microsoft Corporation. All rights reserved. Loading Dump File [C:\Windows\Minidump\Mini052409-04.dmp] Mini Kernel Dump File: Only registers and stack trace are available Symbol search path is: srv*c:\symbols*http://msdl.microsoft.com/download/symbols Executable search path is: srv*c:\symbols*http://msdl.microsoft.com/download/symbols Windows Server 2008/Windows Vista Kernel Version 6001 (Service Pack 1) MP (2 procs) Free x86 compatible Product: WinNt, suite: TerminalServer SingleUserTS Built by: 6001.18000.x86fre.longhorn_rtm.080118-1840 Machine Name: Kernel base = 0x81817000 PsLoadedModuleList = 0x8192ec70 Debug session time: Sun May 24 17:54:26.879 2009 (GMT+2) System Uptime: 0 days 0:07:30.631 Loading Kernel Symbols ............................................................... ................................................................ ............ Loading User Symbols Loading unloaded module list ..... ******************************************************************************* * * * Bugcheck Analysis * * * ******************************************************************************* Use !analyze -v to get detailed debugging information. BugCheck A, {86a0bbdc, 8, 0, 81bd75b1} Unable to load image \SystemRoot\system32\DRIVERS\atikmdag.sys, Win32 error 0n2 *** WARNING: Unable to verify timestamp for atikmdag.sys *** ERROR: Module load completed but symbols could not be loaded for atikmdag.sys Probably caused by : dxgkrnl.sys ( dxgkrnl!DpQueueDpc+61 ) Followup: MachineOwner --------- 1: kd> !analyze -v ******************************************************************************* * * * Bugcheck Analysis * * * ******************************************************************************* IRQL_NOT_LESS_OR_EQUAL (a) An attempt was made to access a pageable (or completely invalid) address at an interrupt request level (IRQL) that is too high. This is usually caused by drivers using improper addresses. If a kernel debugger is available get the stack backtrace. Arguments: Arg1: 86a0bbdc, memory referenced Arg2: 00000008, IRQL Arg3: 00000000, bitfield : bit 0 : value 0 = read operation, 1 = write operation bit 3 : value 0 = not an execute operation, 1 = execute operation (only on chips which support this level of status) Arg4: 81bd75b1, address which referenced memory Debugging Details: ------------------ READ_ADDRESS: GetPointerFromAddress: unable to read from 8194e868 Unable to read MiSystemVaType memory at 8192e420 86a0bbdc CURRENT_IRQL: 8 FAULTING_IP: hal!KfLowerIrql+65 81bd75b1 c9 leave CUSTOMER_CRASH_COUNT: 4 DEFAULT_BUCKET_ID: COMMON_SYSTEM_FAULT BUGCHECK_STR: 0xA PROCESS_NAME: hl2.exe TRAP_FRAME: 86a2bb64 -- (.trap 0xffffffff86a2bb64) ErrCode = 00000000 eax=00000100 ebx=803d1120 ecx=803d2b08 edx=00000000 esi=00000000 edi=84b748c8 eip=81bd75b1 esp=86a2bbd8 ebp=86a0bbdc iopl=0 nv up ei pl nz na po nc cs=0008 ss=0010 ds=0023 es=0023 fs=0030 gs=0000 efl=00010202 hal!KfLowerIrql+0x65: 81bd75b1 c9 leave Resetting default scope LAST_CONTROL_TRANSFER: from 81bd75b1 to 81871d84 STACK_TEXT: 86a2bb64 81bd75b1 badb0d00 00000000 9ba79a48 nt!KiTrap0E+0x2ac 86a2bbdc 818cdf62 84b72000 85456d70 803d2b08 hal!KfLowerIrql+0x65 86a2bc00 85b4a164 01b748c8 00000000 00000000 nt!KeInsertQueueDpc+0x1e7 86a2bc18 8b81cab5 84b744f8 8b81c2b4 86a2bc3c dxgkrnl!DpQueueDpc+0x61 WARNING: Stack unwind information not available. Following frames may be wrong. 86a2bc28 8b8264d5 85355008 85456000 8545d88c atikmdag+0x17ab5 86a2bc3c 8b8d73e9 84b72000 86a2bc70 86a2bc50 atikmdag+0x214d5 86a2bc90 8b8d3afc 84b72000 8546ff90 8b8de080 atikmdag+0xd23e9 86a2bcf4 8b8d2fc7 85456000 84c54280 83d78560 atikmdag+0xceafc 86a2bd14 85b4a0fa 84c78908 00000000 86a2bd38 atikmdag+0xcdfc7 86a2bd24 818d215c 84c54280 84b744f8 00000000 dxgkrnl!DpiFdoMessageInterruptRoutine+0x17 86a2bd38 8186a971 84c54280 84b744f8 00000000 nt!KiInterruptMessageDispatch+0x12 86a2bd38 6ab4ec3c 84c54280 84b744f8 00000000 nt!KiInterruptDispatch+0x51 0fe1f87c 00000000 00000000 00000000 00000000 0x6ab4ec3c STACK_COMMAND: kb FOLLOWUP_IP: dxgkrnl!DpQueueDpc+61 85b4a164 8ad8 mov bl,al SYMBOL_STACK_INDEX: 3 SYMBOL_NAME: dxgkrnl!DpQueueDpc+61 FOLLOWUP_NAME: MachineOwner MODULE_NAME: dxgkrnl IMAGE_NAME: dxgkrnl.sys DEBUG_FLR_IMAGE_TIMESTAMP: 47918c64 FAILURE_BUCKET_ID: 0xA_dxgkrnl!DpQueueDpc+61 BUCKET_ID: 0xA_dxgkrnl!DpQueueDpc+61 Followup: MachineOwner --------- Dump 2: Loading Dump File [C:\Windows\Minidump\Mini052409-02.dmp] Mini Kernel Dump File: Only registers and stack trace are available Symbol search path is: srv*c:\symbols*http://msdl.microsoft.com/download/symbols Executable search path is: srv*c:\symbols*http://msdl.microsoft.com/download/symbols Windows Server 2008/Windows Vista Kernel Version 6001 (Service Pack 1) MP (2 procs) Free x86 compatible Product: WinNt, suite: TerminalServer SingleUserTS Built by: 6001.18000.x86fre.longhorn_rtm.080118-1840 Machine Name: Kernel base = 0x8181c000 PsLoadedModuleList = 0x81933c70 Debug session time: Sun May 24 17:13:51.399 2009 (GMT+2) System Uptime: 0 days 0:00:16.224 Loading Kernel Symbols ............................................................... ................................................................ ...... Loading User Symbols Loading unloaded module list ..... ******************************************************************************* * * * Bugcheck Analysis * * * ******************************************************************************* Use !analyze -v to get detailed debugging information. BugCheck 50, {94a8c9f8, 1, 9172e5fd, 0} Could not read faulting driver name Probably caused by : win32k.sys ( win32k!vSrcCopyS32D32Identity+5e ) Followup: MachineOwner --------- 1: kd> !analyze -v ******************************************************************************* * * * Bugcheck Analysis * * * ******************************************************************************* PAGE_FAULT_IN_NONPAGED_AREA (50) Invalid system memory was referenced. This cannot be protected by try-except, it must be protected by a Probe. Typically the address is just plain bad or it is pointing at freed memory. Arguments: Arg1: 94a8c9f8, memory referenced. Arg2: 00000001, value 0 = read operation, 1 = write operation. Arg3: 9172e5fd, If non-zero, the instruction address which referenced the bad memory address. Arg4: 00000000, (reserved) Debugging Details: ------------------ Could not read faulting driver name WRITE_ADDRESS: GetPointerFromAddress: unable to read from 81953868 Unable to read MiSystemVaType memory at 81933420 94a8c9f8 FAULTING_IP: win32k!vSrcCopyS32D32Identity+5e 9172e5fd ff4d08 dec dword ptr [ebp+8] MM_INTERNAL_CODE: 0 CUSTOMER_CRASH_COUNT: 2 DEFAULT_BUCKET_ID: VISTA_DRIVER_FAULT BUGCHECK_STR: 0x50 PROCESS_NAME: LogonUI.exe CURRENT_IRQL: 0 TRAP_FRAME: 94aac96c -- (.trap 0xffffffff94aac96c) ErrCode = 00000002 eax=ff704308 ebx=ff704308 ecx=00000000 edx=00000000 esi=94aacb70 edi=ff6a4308 eip=9172e5fd esp=94aac9e0 ebp=94a8c9f0 iopl=0 nv up ei ng nz ac po nc cs=0008 ss=0010 ds=0023 es=0023 fs=0030 gs=0000 efl=00010292 win32k!vSrcCopyS32D32Identity+0x5e: 9172e5fd ff4d08 dec dword ptr [ebp+8] ss:0010:94a8c9f8=???????? Resetting default scope LAST_CONTROL_TRANSFER: from 81876bb4 to 818c1155 STACK_TEXT: 94aac954 81876bb4 00000001 94a8c9f8 00000000 nt!MmAccessFault+0x10a 94aac954 9172e5fd 00000001 94a8c9f8 00000000 nt!KiTrap0E+0xdc 94aac9f0 9172e503 000000e8 052b0d6f fe4197d8 win32k!vSrcCopyS32D32Identity+0x5e 94aacc30 9172fc41 fe7afb88 fe65fc48 00000000 win32k!EngCopyBits+0x5b3 94aacd10 81873a7a fe7afb78 ffa588b8 ffa02890 win32k!NtGdiBitBlt+0x59c 94aacd10 77479a94 fe7afb78 ffa588b8 ffa02890 nt!KiFastCallEntry+0x12a WARNING: Frame IP not in any known module. Following frames may be wrong. 0025f658 00000000 00000000 00000000 00000000 0x77479a94 STACK_COMMAND: kb FOLLOWUP_IP: win32k!vSrcCopyS32D32Identity+5e 9172e5fd ff4d08 dec dword ptr [ebp+8] SYMBOL_STACK_INDEX: 2 SYMBOL_NAME: win32k!vSrcCopyS32D32Identity+5e FOLLOWUP_NAME: MachineOwner MODULE_NAME: win32k IMAGE_NAME: win32k.sys DEBUG_FLR_IMAGE_TIMESTAMP: 47c78851 FAILURE_BUCKET_ID: 0x50_win32k!vSrcCopyS32D32Identity+5e BUCKET_ID: 0x50_win32k!vSrcCopyS32D32Identity+5e Followup: MachineOwner --------- Dump 3: Microsoft ® Windows Debugger Version 6.11.0001.404 X86 Copyright © Microsoft Corporation. All rights reserved. Loading Dump File [C:\Windows\Minidump\Mini052409-03.dmp] Mini Kernel Dump File: Only registers and stack trace are available Symbol search path is: srv*c:\symbols*http://msdl.microsoft.com/download/symbols Executable search path is: srv*c:\symbols*http://msdl.microsoft.com/download/symbols Windows Server 2008/Windows Vista Kernel Version 6001 (Service Pack 1) MP (2 procs) Free x86 compatible Product: WinNt, suite: TerminalServer SingleUserTS Built by: 6001.18000.x86fre.longhorn_rtm.080118-1840 Machine Name: Kernel base = 0x8180f000 PsLoadedModuleList = 0x81926c70 Debug session time: Sun May 24 17:46:16.661 2009 (GMT+2) System Uptime: 0 days 0:31:45.310 Loading Kernel Symbols ............................................................... ................................................................ ............ Loading User Symbols Loading unloaded module list ..... ******************************************************************************* * * * Bugcheck Analysis * * * ******************************************************************************* Use !analyze -v to get detailed debugging information. BugCheck D1, {9920f838, 6, 0, 81f1b23c} Probably caused by : atapi.sys ( atapi!AtapiSendAtaCommand+ca ) Followup: MachineOwner --------- 1: kd> !analyze -v ******************************************************************************* * * * Bugcheck Analysis * * * ******************************************************************************* DRIVER_IRQL_NOT_LESS_OR_EQUAL (d1) An attempt was made to access a pageable (or completely invalid) address at an interrupt request level (IRQL) that is too high. This is usually caused by drivers using improper addresses. If kernel debugger is available get stack backtrace. Arguments: Arg1: 9920f838, memory referenced Arg2: 00000006, IRQL Arg3: 00000000, value 0 = read operation, 1 = write operation Arg4: 81f1b23c, address which referenced memory Debugging Details: ------------------ READ_ADDRESS: GetPointerFromAddress: unable to read from 81946868 Unable to read MiSystemVaType memory at 81926420 9920f838 CURRENT_IRQL: 6 FAULTING_IP: atapi!AtapiSendAtaCommand+ca 81f1b23c c9 leave CUSTOMER_CRASH_COUNT: 3 DEFAULT_BUCKET_ID: VISTA_DRIVER_FAULT BUGCHECK_STR: 0xD1 PROCESS_NAME: System TRAP_FRAME: 9922f7b8 -- (.trap 0xffffffff9922f7b8) ErrCode = 00000000 eax=0000fb00 ebx=83d9cb48 ecx=815a9840 edx=0000fb00 esi=815a9840 edi=83d9c36c eip=81f1b23c esp=9922f82c ebp=9920f838 iopl=0 nv up ei pl zr na pe nc cs=0008 ss=0010 ds=0023 es=0023 fs=0030 gs=0000 efl=00010246 atapi!AtapiSendAtaCommand+0xca: 81f1b23c c9 leave Resetting default scope LAST_CONTROL_TRANSFER: from 81f1b23c to 81869d84 STACK_TEXT: 9922f7b8 81f1b23c badb0d00 0000fb00 00000000 nt!KiTrap0E+0x2ac 9922f838 81f1b35f 83d9c36c 000003e8 00000102 atapi!AtapiSendAtaCommand+0xca 9922f850 81f1b3b1 83d9c36c 815a9840 9922f870 atapi!AtapiHandleAtaCommand+0x33 9922f860 81f28b57 83d9c36c 815a9840 9922f888 atapi!AtapiHwStartIo+0x27 9922f870 81f28cd5 83d9b0e0 815a95b8 83d9c600 ataport!CallMiniPortHwStartIo+0x1d 9922f888 81862651 815a95b8 83d9b002 83d9b0e0 ataport!IdeStartCrbSynchronized+0x5d 9922f8ac 81f28fe8 83d9b0e0 81f28c78 815a95b8 nt!KeSynchronizeExecution+0x21 9922f8d8 81efc074 815a95b8 9922f910 81bcd1f4 ataport!IdeStartIoCallBack+0xb8 9922f8e4 81bcd1f4 83d976e8 00000000 815a9614 PCIIDEX!BmReceiveScatterGatherList+0x1e 9922f910 81efc195 815a9614 83d976e8 835b1f40 hal!HalBuildScatterGatherList+0x1ba 9922f94c 81f287df 83d977a0 815a95b8 815a9500 PCIIDEX!BmSetup+0x3d 9922f968 81f28c60 83d9b0e0 815a9500 815a95b8 ataport!IdePortSetupScatterGatherList+0x2d 9922f980 81f27a90 83d9b0e0 815a95b8 83d9c600 ataport!IdeDispatchChannelRequest+0x6e 9922f998 81f27cbd 83d9b0e0 815a95b8 83d9c600 ataport!IdeStartChannelRequest+0x6c 9922f9b0 81f286e0 00d9c600 00000000 852a8008 ataport!IdeStartDeviceRequest+0xe7 9922f9d0 81f259c5 83d9c548 00000103 9922f9f8 ataport!IdePortPdoDispatch+0x98 9922f9e0 818cb053 83d9c548 852a8008 ffcd3ff4 ataport!IdePortDispatch+0x1d 9922f9f8 81e166a6 ffcd3ff4 9922fa18 81e1d084 nt!IofCallDriver+0x63 9922fa04 81e1d084 83da4c10 852a8008 852a80c0 acpi!ACPIDispatchForwardIrp+0x2a 9922fa18 81e16ee6 83da4c10 852a8008 00000000 acpi!ACPIIrpDispatchDeviceControl+0xa4 9922fa48 818cb053 83da4c10 82f44cb8 852a7290 acpi!ACPIDispatchIrp+0x19a 9922fa60 85dc474b 8153d748 852a7290 0000c800 nt!IofCallDriver+0x63 9922fa74 85dc415b 83da4c10 8445cb80 83e7c7c0 CLASSPNP!SubmitTransferPacket+0x106 9922fab4 85dc3ee7 00000000 0053d748 8445c870 CLASSPNP!ServiceTransferRequest+0x224 9922fadc 85dc4342 8445cac8 00000000 8445cac8 CLASSPNP!ClassReadWrite+0x16a 9922faf0 818cb053 8445cac8 8153d748 8153d888 CLASSPNP!ClassGlobalDispatch+0x20 9922fb08 81e8d116 ebbd7000 8153d748 83ef9490 nt!IofCallDriver+0x63 9922fb1c 81e8d151 8445c870 8153d86c 8445c7b8 partmgr!PmReadWrite+0x111 9922fb30 818cb053 8445c7b8 8153d748 8153d748 partmgr!PmGlobalDispatch+0x1d 9922fb48 81e9c6f1 8153d8ac 83ef93d8 8153d748 nt!IofCallDriver+0x63 9922fb64 818cb053 83ef93d8 8153d748 8153d8d0 volmgr!VmReadWrite+0x1b3 9922fb7c 85d93d77 00000009 ebbd7000 9922fba4 nt!IofCallDriver+0x63 9922fb8c 85d94565 84565ce0 8153d748 8184e1ef fvevol!RequestPassThrough+0x3b 9922fba4 85d92b6d 84565ce0 8153d748 85d7ac50 fvevol!FveFilterRead+0x23 9922fbc8 818cb053 84565c28 8153d748 00000000 fvevol!FveFilterRundownRead+0x11b 9922fbe0 85d6c864 8153d8d8 00000000 84668748 nt!IofCallDriver+0x63 9922fc08 85d6d542 84668748 8153d748 00000000 ecache!EcDeviceIoCallLowerDriver+0x1d4 9922fcd0 818cb053 84668690 8153d748 8153d918 ecache!EcDispatchReadWrite+0xc26 9922fce8 85d16033 9922fd38 8476b6c0 82f97ad0 nt!IofCallDriver+0x63 9922fd08 818cb053 8476b6c0 8153d748 86753550 volsnap!VolSnapRead+0x14d 9922fd20 85c16500 867534d8 9922fd44 818c8318 nt!IofCallDriver+0x63 9922fd2c 818c8318 86753550 00000000 ffffffff Ntfs!NtfsStorageDriverCallout+0x14 9922fd2c 818c8411 86753550 00000000 ffffffff nt!KiSwapKernelStackAndExit+0x118 867534e8 00000000 00000000 00000000 00000000 nt!KiSwitchKernelStackAndCallout+0x31 STACK_COMMAND: kb FOLLOWUP_IP: atapi!AtapiSendAtaCommand+ca 81f1b23c c9 leave SYMBOL_STACK_INDEX: 1 SYMBOL_NAME: atapi!AtapiSendAtaCommand+ca FOLLOWUP_NAME: MachineOwner MODULE_NAME: atapi IMAGE_NAME: atapi.sys DEBUG_FLR_IMAGE_TIMESTAMP: 47918f74 FAILURE_BUCKET_ID: 0xD1_atapi!AtapiSendAtaCommand+ca BUCKET_ID: 0xD1_atapi!AtapiSendAtaCommand+ca Followup: MachineOwner --------- Håper noen klarer å finne ut av dette! Mvh Julian EDIT: Den rebooter uten noen forvarsel, minnedump eller bluescreens. Har satt på at den ikke skal reboote vis den får bluescreen, og lagrer alt i minidumps. Endret 26. mai 2009 av Effectiv Lenke til kommentar
fenderebest Skrevet 26. mai 2009 Del Skrevet 26. mai 2009 Ut ifra minnedumpene. som er beskrevet er jeg fristet til å si en hardware feil. Er dette en ny PC eller har den fungert lenge uten noen endringer i hardwareoppsettet? Lenke til kommentar
Effectiv Skrevet 26. mai 2009 Forfatter Del Skrevet 26. mai 2009 Det er ikke akkurat en ny pc, men har bygget den selv. I starten virket den helt fint utenom at den fikk bluescreen når vi slo den av. Det er vista på den og tipper at det er feilen, men pcen nekter å lese Xp-boot cden. Aner ikke hvorfor :S Men hva tror du hardwarefeilen kan være? Noen forslag? Den har blitt verre etter at jeg reinstallerte vista av en eller annen grunn. Håper noen kan hjelpe meg litt her! Lenke til kommentar
ZombieBobie Skrevet 26. mai 2009 Del Skrevet 26. mai 2009 (endret) sett i control panel->administrator tools->event viewer-> ? mulig de popper opp i listen der under critical eller error events. Er gjerne litt lettere å skjønne hva som er galt da. Endret 26. mai 2009 av ZombieBobie Lenke til kommentar
fenderebest Skrevet 26. mai 2009 Del Skrevet 26. mai 2009 Det jeg ville ha først testet er minnet ved å boote fra en cd som har har memtest. Hadde dog vært artig å dumpet ut IDT tabellen for å se hvilke interrupts som kjøres på IRQL 6 og 8. Lenke til kommentar
Effectiv Skrevet 26. mai 2009 Forfatter Del Skrevet 26. mai 2009 Sto en del der ja. Blant annet WMI, Cdrom, Search-profile, volmgr, application error, application hang, MSI installer, Search, eventsystem, eventlog, atirecord, httpevent, vss, distributedCOM og noe annet.. Har tatt memtest inne i windows, ikke som boot. Kan teste vis det er noe forskjell Lenke til kommentar
fenderebest Skrevet 26. mai 2009 Del Skrevet 26. mai 2009 Nei som regel er det vel overoppheting, minne eller harddiskproblemer som er de vanligste på en maskin som har fungert lenge. Men har vanskelig for å si noe konkret uten å ha kunne gjennomgå minnedumpene personlig. Lenke til kommentar
Effectiv Skrevet 26. mai 2009 Forfatter Del Skrevet 26. mai 2009 Det er ikke overopphetning(ligger på 35 grader cpu, gpu 55), tviler på det er minne for den klarer memtest uten feil, og harddiskproblem høres ulogisk ut siden det skjer uansett hva jeg gjør. Det skjer som oftest når jeg starter programmer o.l. Bare firefox går fint en stund. ANER faktisk ikke hva som kan være problemet :/ Lenke til kommentar
fenderebest Skrevet 26. mai 2009 Del Skrevet 26. mai 2009 (endret) Vel det aller siste jeg har å sette en knapp på er da skjermkortet. Grunnen til at jeg mistenker hardwareproblemer er generelt sett pga to ting: 1.Minnedumpene følger intet fast mønster - som regel vil driver relaterte problemer gi lignende minnedumper og kunne trigges av bestemte handlinger. 2.I to av de tre dumpene er IRQL hevet til et nivå over 2. Windows prioriterer avbruddene sine på bestemte nivåer der 0-2 er reservert software avbrudd og 3-31 er resvert hardware. Når IRQL er hevet over 2 betyr det mao at feilen oppsto mens maskinvaren kommuniserte med operativsystemet. Noe mere enn dette er vaskelig å si uten å gjennomgått minnedumpene selv som sagt. Endret 26. mai 2009 av fenderebest Lenke til kommentar
Effectiv Skrevet 26. mai 2009 Forfatter Del Skrevet 26. mai 2009 Mulig for meg å sende de til deg på en måte? Vis du har mulighet/tid til å se over de Lenke til kommentar
fenderebest Skrevet 26. mai 2009 Del Skrevet 26. mai 2009 Jeg trenger isåfall en kjerneminnedump. Avhengig av hvor mye fysisk minne du har ligger de på mellom 200-300mb og kalles MEMORY.DMP. Om du har mulighet for å laste filen opp til en filserver så hadde det vært flott. Lenke til kommentar
Effectiv Skrevet 26. mai 2009 Forfatter Del Skrevet 26. mai 2009 Skal endre til kjerneminnedump og se hva jeg får til Lenke til kommentar
Effectiv Skrevet 26. mai 2009 Forfatter Del Skrevet 26. mai 2009 Nå forstår jeg ingenting :s Klarer ikke å framprovosere noen som helst feil. Har kjørt OCCT-tester siden sist post, spilt left 4 dead (det som klikket hele tiden etter 5 min klikker ikke i det hele tatt :S ) og sett på film. Ingenting gale skjer. Har lagt inn nye skjermkortdrivere, hovedkortdrivere og sånn, og ser kanskje ut som det har virket. Har gjort det før og da virket det ikke :S Kommer med tilbakemelding om det skjer noe igjen takk for mange og gode svar iallefall! Mvh effectiv Lenke til kommentar
Effectiv Skrevet 27. mai 2009 Forfatter Del Skrevet 27. mai 2009 Her er link til memory.dmp http://www.zshare.net/download/605718981f0e1c04/ Du får se om du finner noe Lenke til kommentar
Effectiv Skrevet 27. mai 2009 Forfatter Del Skrevet 27. mai 2009 er ikke 70 grader på cpu alt for mye?! Når jeg kjører OCCT blir core 2 72 grader, mens core 1 ligger på 67. Original AMD athlon x2 6000+ vifte. Men det står at cpu jobber på 2,6 ghz (-12,9% av normal). Alt står på auto i bios.. :S Og ramen (som jeg mener er presis disse https://prisguiden.no/product.php?p...ew=productinfo) skal kjøre på 2.2 volt, men i bios står de på originalt 1.8. Og når jeg setter på 2.2 får jeg melding om farlig høy spenning. Er det dumt å kjøre ramen på 1.8 istedet for 2.2? Vcore er på 1.41 3.3v er på 3.2 5v er på 4.9 12v er på 11.90 noen som ser noe mystisk? Kan det være for lav spenning på noen komponenter som gjør at den fryser/rebooter? Er et antec kabinett med 380w strømforsyning (Earthwatts er merket). Hovedkort er gigabyte ga-ma770-ds3 og gpu er Club 3d 3850. Mvh Effectiv Lenke til kommentar
fenderebest Skrevet 28. mai 2009 Del Skrevet 28. mai 2009 (endret) Feil spenningsstyrke på det fysiske minnet kan gi seg i effekt av såkalt bitflipping der en tilfeldig bit blir snudd (feks 0 blir 1) og dermed ender man opp på en tilfeldig plass i minnet. Dog skal dette gi seg utslags i evt minnetester også. Jeg gikk igjennom minnedumpen og dette er kanskje et skudd i blinde men du kunne ikke prøve å oppdatere nwifi.sys som jeg mistenker er trådløskortdriveren din? Evt deaktivere trådløskortet og se om problemet vedvarer. Dog om jeg så på på den kernel dumpen for seg selv ville jeg ha tenkt skjermkortdriveren da atikmdag.sys er en del av grafikkortdriver pakken til ati. Dog sier du jo at du har oppdatert skjermkortdriveren så jeg vet ikke. Forøvrig kunne du bare lagt ved minidump filene av de andre kræsjene? Endret 28. mai 2009 av fenderebest Lenke til kommentar
