Lionel_Luthor Skrevet 25. mai 2009 Del Skrevet 25. mai 2009 (endret) Tenkte det kunne være kjekt og lage en tråd om N900, i følge diverse sider vil dette bli litt av en mobiltelefon. Det sies at denne skal komme til Europa i oktober. Skal bli spennende og se om det er noe i disse ryktene, for i så fall kan det jo være ett alternativ og vente med og kjøpe N97 og heller gå for denne. Hardware Specs: * Update: A few comments inquired about GPS. Our source has since verified that the N900 does indeed have GPS, along with an accelerometer. * Dimensions: 59.7mmx111mmx18.2mm * Weight: 180g * 3.5″ 800×480 (WVGA) touchscreen * OMAP3430 500/600 Mhz processor (Fun Trivia: Same CPU as the Palm Pre) * Bands: GSM Quad-Band 850, 900, 1800, 1900. WCDMA 900, 1700/2100, 2100 * 5 megapixel Carl Zeiss camera with dual-LED flash, autofocus, and sliding cover * Though the renders we’ve seen show two lens-like circles near the screen, we’ve got no word on what’s behind them. However, we feel safe in assuming that its a proximity sensor and a front-facing camera. * 1GB total virtual runtime memory (256MB physical RAM, 768MB virtual memory) * Wi-Fi, HSPA * 32GB internal storage, expandable up to 48GB via external memory * Keyboard variants: English, Scandinavian, French, German, South European, Italian, Russia * In the box: Connectivity cable, headset, charger, battery (1320 mAh), Video-out cable, microUSB adaptor, cleaning cloth Some of the mentioned software features: * In all of the renders we’ve seen, it appears to be running Maemo 5. * Multitasking: “Run all of your favorite applications simultaneously” * Live Dashboard allows all open tasks and unread messages to be displayed in one view * Browser: Firefox 3 with support for Flash 9.4 * Built-in automatic update software * Contacts has some sort of status sharing built in, allowing you to share your status, location, and mood. Support for Contacts on Ovi and Google Talk. * All SMS and IMs accessible from one view * Cellular voice or VOIP both supported * Captures video at 800×480 in AVC/H.264 * Image tagging and geo-tagging support * Nokia intends to have at least a dozen add-on apps available at launch, including a game called “Bounce”, a Jaiku/Twitter app called “Mauku”, and a few widgets. Kilde: http://www.mobilecrunch.com/2009/05/24/exc...as-next-tablet/ EDIT: Se det ja, Amobil hadde en artikkel klar om saken: http://www.amobil.no/artikler/nokias_nye_s...ermer_seg/69928 Endret 25. mai 2009 av Lionel_Luthor Lenke til kommentar
