[Løst]Knapp reagerer ikke
Holder på å lage en log in form, det meste funker, men når jeg skal trykke på "Login" så skjer det ingen ting :(
Da skal det egentlig komme: You have succesfully logged in as "user"
Scriptet:
<?php
session_start();
include "./global.php";
if (isset($_SESSION['uid'])){
echo "You are already logged in, if you wish to log out, please <a href\"./logout.php\">click here</a>! \n";
}else{
if (!isset($_POST['Submit']) || ($_POST['Submit'] != 'Login')) {
	echo "<table border=\"0\" cellspacing=\"3\" cellpadding=\"3\">\n";
	echo "<form method=\"post\" action=\"./login.php\">\n";
	echo "<tr><td>Username</td><td><input type=\"text\" name=\"username\"></td></tr>\n";
	echo "<tr><td>Password</td><td><input type=\"password\" name=\"password\"></td></tr>\n";
	echo "<tr><td colspan=\"2\" align=\"right\"><input type=\"submit\" name=\"submit\" value=\"Login\"></td></tr>\n";
	echo "</form></table>";
else{
	$user = mss(isset($_POST['username']));
	$pass = (isset($_POST['password']));
		if($user && $pass){
			$sql = "SELECT id FROM `users1` WHERE `username`='".$user."'";
			$res = mysql_query($sql) or die (mysql_error());
				if(mysql_num_rows($res) > 0){
					$sql2 = "SELECT id FROM `users1` WHERE `username`='".$user."' AND `password`='".md5($pass)."'";
					$res2 = mysql_query($sql2) or die (mysql_error());
					if(mysql_num_rows($res2) > 0){
						$row = mysql_fetch_assoc($res2);
						$_SESSION['uid'] = $row['id'];
						echo "You have succesfully logged in as " .$user;
					}else{
						echo "Username and password combination is incorrect!\n";
				}else{
					echo "The username you supplied does not exsist!\n";
		}else{
			echo "You must supply both the usename and password field!\n";
Noen som har en anelse om hva som kan være feil?
Natrich
Endret av Natrich
