[Løst]BIOS instillinger på Hovedkort.
elwapo
Onboard VGA Memory Size or VGA Shared Memory Size: In computer equipped with onboard video and using UMA architecture (Unified Memory Architecture) the motherboard chipset uses part of the RAM Memory as video memory. In this option you will set how much RAM memory will be assigned to video functions. The more memory you set the worse as you will be losing memory for applications execution.
http://www.hardwaresecrets.com/article/6/13
