Zoney Skrevet 22. januar 2002 Del Skrevet 22. januar 2002 [version] signature="$CHICAGO$" [DefaultInstall] AddReg=PortSample [DefaultUnInstall] ; This section included for ease of removing any maps added in. ; To uninstall, type the following line: ; ; rundll.exe setupx.dll,InstallHinfSection DefaultUnInstall 0 ; BATTLECOMMAP DelReg=PORT_SAMPLE_DEL_REG [PortSample] ; MYMAPNAME should be replaced with a friendly ; descriptive name that is unique. ; ; This data points to the computer that is running the service. ; 0.0.0.0 represents the computer running the ICS services. This ; can alternatively contain the IP address of one of the ICS client ; computers. HKLM,%ICSACTIVE%,BATTLECOMMAP,,"0.0.0.0" HKLM,%ICSINSTALLED%BATTLECOMMAP ; "My Friendly Name" should be replaced with something short and ; descriptive such as the name of the program that needs these ports ; open. HKLM,%ICSINSTALLED%BATTLECOMMAP,Name,,"PORTS REQUIRED FOR BATTLECOM TO WORK WITH ICS" ; Options is a DWORD value and is currently always set to 00,00,00,00 HKLM,%ICSINSTALLED%BATTLECOMMAP,Options,1,00,00,00,00 ; The next four lines describe the specific ports that need to be open ; or mapped. The first port is always 0000, each additional port is ; incremented (the second port to open would be listed as 0001, ; the third would be 0002, and so on). This information is strictly ; dependent on what is needed by the program. If you do not know what ; ports your program requires or are unsure, you need to contact the ; manufacturer of the program to get this information. ; ; The four lines need to be re-created for each port. ; ; On the second line, valid entries for type are "TCP" or "UDP." ; ; The third line contains the actual port or port range needed by the ; program. ; ; The entry below demonstrates a port range. If the program only needs ; a single port, the last part of the line below would read ,Port,,"5678" ; ; Note that you can only use a port range when the translation type is ; NORMAL or BLOCK. ; ; If Translation is set to anything else, you must list each port ; individually. ; ; Valid types of translation are NORMAL, BLOCK, CUSEEME, DPLAY, FTP, ; H323, PPTP, and QUAKE HKLM,%ICSINSTALLED%BATTLECOMMAP000 HKLM,%ICSINSTALLED%BATTLECOMMAP000,Type,,"TCP" HKLM,%ICSINSTALLED%BATTLECOMMAP000,Port,,"47624" HKLM,%ICSINSTALLED%BATTLECOMMAP000,Translation,,"NORMAL" HKLM,%ICSINSTALLED%BATTLECOMMAP001 HKLM,%ICSINSTALLED%BATTLECOMMAP001,Type,,"TCP" HKLM,%ICSINSTALLED%BATTLECOMMAP001,Port,,"2300-2400" HKLM,%ICSINSTALLED%BATTLECOMMAP001,Translation,,"NORMAL" HKLM,%ICSINSTALLED%BATTLECOMMAP002 HKLM,%ICSINSTALLED%BATTLECOMMAP002,Type,,"UDP" HKLM,%ICSINSTALLED%BATTLECOMMAP002,Port,,"2300-2400" HKLM,%ICSINSTALLED%BATTLECOMMAP002,Translation,,"NORMAL" HKLM,%ICSINSTALLED%BATTLECOMMAP003 HKLM,%ICSINSTALLED%BATTLECOMMAP003,Type,,"TCP" HKLM,%ICSINSTALLED%BATTLECOMMAP003,Port,,"2300-2400" HKLM,%ICSINSTALLED%BATTLECOMMAP003,Translation,,"DPLAY" HKLM,%ICSINSTALLED%BATTLECOMMAP004 HKLM,%ICSINSTALLED%BATTLECOMMAP004,Type,,"UDP" HKLM,%ICSINSTALLED%BATTLECOMMAP004,Port,,"2300-2400" HKLM,%ICSINSTALLED%BATTLECOMMAP004,Translation,,"DPLAY" [PORT_SAMPLE_DEL_REG] HKLM,%ICSINSTALLED%BATTLECOMMAP HKLM,%ICSACTIVE%,BATTLECOMMAP [strings] ICSINSTALLED="SystemCurrentControlSetServicesICSharingMappingsInstalled" ICSACTIVE="SystemCurrentControlSetServicesICSharingMappingsActive" Jeg vil gjerne "oversette" denne til Windows XP, det står at den bare funker til ME og 98, og jeg kjører XP..... Denne fila *.inf, åpner portene slik at jeg kan bruke et program som heter BattleCom. Noen som gidder oversette den for meg? takk :smile: Lenke til kommentar
b-real Skrevet 23. januar 2002 Del Skrevet 23. januar 2002 Prøv å velge det alternatvet som gjør at du kan kjøre programmer som om de bare kunne kjøres i NT/95/98SE osv??? Lenke til kommentar
MartinGM Skrevet 23. januar 2002 Del Skrevet 23. januar 2002 Ingen kunst. Du går bare inn på properties på nettverkskortet, velger advanced fanen og settings knappen nede i hjørnet. Så bare adder du portene, henholdsvis TCP og UDP akkurat som det står i fila di. Lenke til kommentar
Zoney Skrevet 25. januar 2002 Forfatter Del Skrevet 25. januar 2002 Men det er over 100 porter, og jeg vil ikke adde en etter en... Men alle på en gang. Lenke til kommentar
Pirken Skrevet 7. mars 2002 Del Skrevet 7. mars 2002 Last ned http://www.gamevoice.com isteden.. er mye bedre og funker med XP.. Lenke til kommentar
