Lurer på litt med overklokking......
Her er litt mere info-----
Lurer på om jeg må øke spenningen til CPU'en:)
SiSoftware Sandra
System Mainboard
MP Support : 1 CPU(s)
MPS Version : 1.40
Model : i845G-ITE8712
BIOS ID : 11/01/2002-i845G-ITE8712-JT69VC0CC-00
System Memory Controller
Error Correction Capability : None
Number of Memory Slots : 2
Maximum Installable Memory : 2GB
Bank0/1 - A0 : DIMM Synchronous SDRAM 512MB/64
Bank2/3 - A1 : DIMM Synchronous SDRAM 512MB/64
System Chipset
Model : Intel Corporation 82845PE Brookdale Host-Hub Interface Bridge (B0-step)
Bus(es) : ISA AGP PCI IMB USB FireWire/1394 SMBus/i2c
Front Side Bus Speed : 4x 162MHz (648MHz data rate)
Max FSB Speed / Max Memory Speed : 4x 133MHz / 2x 166MHz
In Order Queue Depth : 8 req(s)
Chipset Hub Interface
Type : HubInterface
Version : 1.50
No. Ports : 1
Width : 8-bit
Full Duplex : Yes
Multiplier : 1x
APIC 1
Version : 2.00
Multiplier : 1/2x
Max Interrupts : 24
IRQ Handler Engaged : Yes
Enhanced Support : No
Logical/Chipset Memory Banks
Bank 0 Setting : 256MB DDR-SDRAM 8-1-1-1R 6-1-1-1W 2.5-3-3CL
Bank 1 Setting : 256MB DDR-SDRAM 8-1-1-1R 6-1-1-1W 2.5-3-3CL
Bank 2 Setting : 256MB DDR-SDRAM 8-1-1-1R 6-1-1-1W 2.5-3-3CL
Bank 3 Setting : 256MB DDR-SDRAM 8-1-1-1R 6-1-1-1W 2.5-3-3CL
Speed : 2x 203MHz (406MHz data rate)
Multiplier : 1.25x
Refresh Rate : 15.60µs
Power Down Mode : No
Fixed Hole Present : No
Memory Module(s)
Memory Module 1 : 512MB 16x(32Mx8) DDR-SDRAM PC2700U-2533-700 (CL2.5 upto 167MHz) (CL2 upto 133MHz)
Memory Module 2 : 512MB 16x(32Mx8) DDR-SDRAM PC2700U-2533-700 (CL2.5 upto 167MHz) (CL2 upto 133MHz)
Environment Monitor 1
Model : ITE IT8705/12 ISA
Mainboard Specific Support : No
Temperature Sensor(s)
Board Temperature : 40.0°C / 104.0°F
CPU Temperature : 42.0°C / 107.6°F td
Power / Aux Temperature : 127.0°C / 260.6°F
Cooling Device(s)
Auto Fan Speed Control : No
CPU Fan Speed : 2519rpm
Voltage Sensor(s)
CPU Core Voltage : 1.49V
Aux Voltage : 1.52V
+3.3V Voltage : 3.31V
+5V Voltage : 5.13V
+12V Voltage : 11.73V
-12V Voltage : -12.77V
-5V Voltage : -0.83V
Standby Voltage : 4.81V
Battery Voltage : 3.30V
