mulig å kombinere to "ulike" kort i SLI?
Har allerede et XFX 8800GTS 640mb ddr3 kort i maskienen. Er det mulig å kombinere dette med et XFX Geforce 8800GTS med 512mb ram? eneste jeg ser som er ulikt er minnemengden. Hva vil eventuelt konsekvensen av å kjøre begge to samtidig være?
ps: jeg vet egentlig ikke om disse kortene kan kjøres i SLi, men mener å ha lest om det et eller annet sted.. :whistle:
edit: hovedkortet er forresten et MSI K9N NEO Nvidia nForce 550..
Endret av mihcaoj
Finner det meste du trenger å vite her:
http://www.slizone.com/page/slizone_faq.html#c3
Can I mix and match graphics cards?
In order to provide optimal symmetric scaling, SLI technology requires the NVIDIA GPUs to match. For example, a GeForce 7800 GTX must be paired with another GeForce 7800 GTX. Likewise, a GeForce 6600 GT must be paired with another GeForce 6600 GT. However, using the latest Release 80 or later graphics drivers, NVIDIA GPUs sold by different manufacturers can be used together in an SLI configuration. For example, a GeForce 7800 GT from vendor ABC can be matched with a GeForce 7800 GT from vendor XYZ.
Can I mix and match graphics cards is one of them is overclocked by the manufacturer?
Yes. A GeForce 7800 GTX that is overclocked (for example BFG GeForce 7800 GTX OC) can be mixed with a standard clocked GeForce 7800 GTX.
Can I mix and match graphics cards with different sizes of memory?
While it is not recommended, NVIDIA does offer this flexibility using Coolbits. When purchasing a second graphics card, you should try to match the memory size so that you are ensured full value and performance from your purchase. For example, if your first card is a GeForce 6600 GT with 128MB of memory, you should purchase a second GeForce 6600 GT with 128MB of memory. However, using Coolbits (value set to 18), you can force both of the cards to use the lower of the two memory sizes and operate together in SLI mode. When dissimilar memory sizes are enabled to work together using Coolbits, the effective memory size for each card becomes the smaller of the two memory sizes.
Så iflg nVidia er det mulig, men ikke anbefalt.
Men 8800GTS med 512MB er vel et helt annet kort enn 8800GTS med 320/640MB. Den nyere modellen (512'en) er bygd på G92 (samme som 8800GT) så vidt jeg vet, og det er ikke de eldre typene (320 og 640).
Endret av FrodeA
