Samsung SpinPoint F2 "EcoGreen"
Samsung har kommet med en ny serie 3.5" harddisker, nærmere bestemt sin F2 "EcoGreen" serie.
Spesifikasjoner:
Klikk for å se/fjerne spoilerteksten nedenfor
Drive Configurations
Capacity 500 GB / 1 TB / 1.5 TB
Interface Serial ATA 3.0Gbps
Buffer DRAM Size 16 / 32 MB
Byte per Sector 512 bytes
Performance Specifications
Average Seek time(typical) 8.9 ms
Average Latency 5.52 ms
Data Transfer Rate / Media to/from Buffer(Max.) 166 MB/sec
Data Transfer Rate / Buffer to/from Host(Max.) 300 MB/sec
Drive Ready Time(typical) 12 sec
Reliability Specifications
Non-recoverable Read Error 1 sector in 10^15 bits
Start/Stop Cycles 50,000
Acoustics
Idle 2.50 Bel
Performance Seek 2.80 Bel
Environmental Specifications
Temperature / Operating 0 ~ 60 °C
Temperature / Non-operating -40 ~ 70 °C
Humidity(non-condensing) / Operating 5 ~ 90 %
Humidity(non-condensing) / Non-operating 5 ~ 95 %
Liner Shock(1/2 sine pulse) / Operating 70 G
Liner Shock(1/2 sine pulse) / Non-operating 300 G
Altitude(relative to sea level) / Operating 300 to 3,000 m
Altitude(relative to sea level) / Non-operating 300 to 12,000 m
Power Requirements
Voltage +5V±5%, +12V±10%
Spin-up Current (Max.) 2.0A
Seek (typical) 5.2W
Read/Write (typical) 5.6W
Idle (typical) 4.4W
Standby (typical) 1W
Sleep (typical) 1W
Physical Dimension
Height (Max.) 26.1 mm
Width 101.5 mm
Length 147.0 mm
Weight (avg.) 610 g
PDF
Features:
• Formatted capacity : 500 GB / 1 TB / 1.5 TB
• Environment friendly product with RoHS compliance
• Serial ATA 3.0 Gbps Interface Support
• Improved performance with dual-ARM based firmware
• Improved recording stability over temperature with PMR
• ATA S.M.A.R.T. Compliant
• Advanced dynamic FOD control for best data integrity
• ATA Automatic Acoustic Management Feature
• Intelligent compensation of external disturbance
• ATA 48-bit Address Feature
• SATA Native Command Queuing Feature
• ATA Device Configuration Overlay Feature
• Device Initiated SATA Power Management
• NoiseGuard™
• Rotational vibration sensor
• SilentSeek™
Modeller:
Veldig spennende disker, som har veldig gode spesifikasjoner når det kommer til ytelse, samtidig som de bare kjører 5400RPM og bruker lite strøm, virker som en drøm for de av oss som ønsker mye lagring, samtidig som det ikke skal bråke eller sluke strøm.. Uten at det skal gå på bekostning av ytelsen!
Endret av RamGuy
</div> </div>
Var det ikke 5900? :hmm:
Forøvrig spennende saker, selv om jeg foretrekker WD sine - som skifter mellom 5400 og 7200 etter behov.
Samsung EcoGreen F2 1.5TB HDD Tested Korean silicon giant Samsung is ready with its 1.5TB high-capacity desktop hard drive, under the EcoGreen F2 series. The drive is labeled HD154UI. With this drive Samsung looks to focus on storage rather than performance, giving this drive a spindle speed of 5400 rpm, aided by a 32MB cache. This is where the company gets to brandish energy-efficiency, thus living up to its EcoGreen brand name.
Despite these specifications, the drive manages a decent set of scores on the HD Tune benchmark, churning out read/write speeds of around 105 MB/s sequential, and around 48/72 MB/s random access. It has a rated average seek-time of 8.9ms. This Samsung drive comes in the standard 3.5" form-factor. It uses the standard SATA II interface. The drive features some proprietary acoustic management features such as SilentSeek and NoiseGuard. It will be available in Japan later this week at a price of ¥11,580 (around US $130).
Ser ut til å være 5400RPM? Men en aksess tid på 25ms er jo intet mindre enn horribelt? Skal være 17ms på 1TB utgaven, men dog? Duger vell kanskje som ren lagringsmedium?
Tror nok disse diskene er raskere enn bare ren lagringsmedium. Fant en test (1.5 TB versjonen) mot WD 2TB og Barracuda 1.5 TB (7200.11) her. http://www.pcgameshardware.com/aid,679981/...viewed/Reviews/
Er ikke fan av Pixmania, men de er vel de eneste med disse på lager til en pris som ikke ligger langt over Barracudaen. Tok sjansen og bestilte i går til 1140 kr. Aldri hatt problemer med en Samsung disk, så satser på at det holder mål (Pixmania :scared::)
