Tandamram Skrevet 28. april 2009 Del Skrevet 28. april 2009 (endret) Har to RAID-array som sammen former et LVM. Mounter LVM'et i fstab som jeg gjorde i 8.10, men etter at jeg oppgraderte til 9.04, så skjer det noe i oppstarten. For å få det til å fungere må jeg stoppe begge arrayene, gjenoppbygge og scanne pv, vg og lv på nytt for å bygge opp LVM. Har søkt litt rundt, men de fleste bug reports som kan ligne på dette, er de som har problemer med array/LVM som OS-disk. Har kommet så langt at jeg fant det nedenfor i Log Viewer, men ellers er jeg relativt fersk når det gjelder feilsøking på spesifikke problemer i Ubuntu. Apr 19 03:24:56 Base kernel: [ 220.660257] md: bind<sdc5> Apr 19 03:24:56 Base kernel: [ 220.665014] md: bind<sdd5> Apr 19 03:24:56 Base kernel: [ 220.667541] md: raid0 personality registered for level 0 Apr 19 03:24:56 Base kernel: [ 220.671973] md0: setting max_sectors to 128, segment boundary to 32767 Apr 19 03:24:56 Base kernel: [ 220.671979] raid0: looking at sdd5 Apr 19 03:24:56 Base kernel: [ 220.671983] raid0: comparing sdd5(732571904) with sdd5(732571904) Apr 19 03:24:56 Base kernel: [ 220.671987] raid0: END Apr 19 03:24:56 Base kernel: [ 220.671990] raid0: ==> UNIQUE Apr 19 03:24:56 Base kernel: [ 220.671992] raid0: 1 zones Apr 19 03:24:56 Base kernel: [ 220.672018] raid0: looking at sdc5 Apr 19 03:24:56 Base kernel: [ 220.672021] raid0: comparing sdc5(732571904) with sdd5(732571904) Apr 19 03:24:56 Base kernel: [ 220.672025] raid0: EQUAL Apr 19 03:24:56 Base kernel: [ 220.672028] raid0: FINAL 1 zones Apr 19 03:24:56 Base kernel: [ 220.672032] raid0: done. Apr 19 03:24:56 Base kernel: [ 220.672035] raid0 : md_size is 1465143808 blocks. Apr 19 03:24:56 Base kernel: [ 220.672038] raid0 : conf->hash_spacing is 1465143808 blocks. Apr 19 03:24:56 Base kernel: [ 220.672040] raid0 : nb_zone is 1. Apr 19 03:24:56 Base kernel: [ 220.672043] raid0 : Allocating 4 bytes for hash. Apr 19 03:24:56 Base kernel: [ 220.672254] md0: unknown partition table Apr 19 03:25:24 Base kernel: [ 248.489021] md: bind<sdb1> Apr 19 03:25:24 Base kernel: [ 248.491667] md: bind<sde1> Apr 19 03:25:24 Base kernel: [ 248.492881] md1: setting max_sectors to 128, segment boundary to 32767 Apr 19 03:25:24 Base kernel: [ 248.492884] raid0: looking at sde1 Apr 19 03:25:24 Base kernel: [ 248.492886] raid0: comparing sde1(488383936) with sde1(488383936) Apr 19 03:25:24 Base kernel: [ 248.492888] raid0: END Apr 19 03:25:24 Base kernel: [ 248.492889] raid0: ==> UNIQUE Apr 19 03:25:24 Base kernel: [ 248.492890] raid0: 1 zones Apr 19 03:25:24 Base kernel: [ 248.492891] raid0: looking at sdb1 Apr 19 03:25:24 Base kernel: [ 248.492892] raid0: comparing sdb1(488383936) with sde1(488383936) Apr 19 03:25:24 Base kernel: [ 248.492894] raid0: EQUAL Apr 19 03:25:24 Base kernel: [ 248.492895] raid0: FINAL 1 zones Apr 19 03:25:24 Base kernel: [ 248.492898] raid0: done. Apr 19 03:25:24 Base kernel: [ 248.492899] raid0 : md_size is 976767872 blocks. Apr 19 03:25:24 Base kernel: [ 248.492900] raid0 : conf->hash_spacing is 976767872 blocks. Apr 19 03:25:24 Base kernel: [ 248.492901] raid0 : nb_zone is 1. Apr 19 03:25:24 Base kernel: [ 248.492902] raid0 : Allocating 4 bytes for hash. Apr 19 03:25:24 Base kernel: [ 248.493303] md1: unknown partition table Ser at jeg får "Uknown partition table" i loggen. Noen som har en formening om hvordan jeg kan løse dette? /etc/fstab: # <file system> <mount point> <type> <options> <dump> <pass> proc /proc proc defaults 0 0 # / was on /dev/sda1 during installation UUID=659487e0-2a17-4501-8787-6f3ade33179d / ext4 relatime,errors=remount-ro 0 1 # /home was on /dev/sda6 during installation UUID=972b5094-a75a-4148-be20-c5a862fd7c26 /home ext4 relatime 0 2 # swap was on /dev/sda5 during installation UUID=cfbe6b19-2ada-4f8a-b72a-fca8a2c250bb none swap sw 0 0 /dev/scd0 /media/cdrom0 udf,iso9660 user,noauto,exec,utf8 0 0 UUID=00mZ84-Aggg-Z7NQ-D49h-9cU1-1HlK-uIEkyc /mnt/raid0 ext3 defaults,relatime 0 0 Endret 28. april 2009 av WonderStivi Lenke til kommentar
Del Skrevet 29. april 2009 Del Skrevet 29. april 2009 Jeg er litt usikker på hva problemet ditt er. Er det så å forstå at du må bygge på nytt etter hver boot? Når du har bygget er alt tilbake som før med dataene intakt? Her har du et par pekere som du bør titte på: http://linux.die.net/man/5/mdadm.conf http://linux.die.net/man/5/lvm.conf Lenke til kommentar
Tandamram Skrevet 29. april 2009 Forfatter Del Skrevet 29. april 2009 Ja, stemmer. Etter en reboot er raid-arrayene "ødelagt", og må stoppes før de kan bygges på nytt. Når de er gjenoppbygd og LVM er satt opp igjen, er alle data intakt. Har svigerfar og svigerbestemor på besøk et par dager, så får ikke gjort så mye akkurat nå. Skal absolutt sjekke ut linkene dine etterhvert. Ellers takker jeg også for andre innspill som måtte komme. Lenke til kommentar
Tandamram Skrevet 1. mai 2009 Forfatter Del Skrevet 1. mai 2009 (endret) Legger ved dmesg i tilfelle det kan hjelpe noen å hjelpe meg : [ 0.000000] BIOS EBDA/lowmem at: 0009dc00/0009dc00 [ 0.000000] Initializing cgroup subsys cpuset [ 0.000000] Initializing cgroup subsys cpu [ 0.000000] Linux version 2.6.28-11-generic (buildd@palmer) (gcc version 4.3.3 (Ubuntu 4.3.3-5ubuntu4) ) #42-Ubuntu SMP Fri Apr 17 01:57:59 UTC 2009 (Ubuntu 2.6.28-11.42-generic) [ 0.000000] KERNEL supported cpus: [ 0.000000] Intel GenuineIntel [ 0.000000] AMD AuthenticAMD [ 0.000000] NSC Geode by NSC [ 0.000000] Cyrix CyrixInstead [ 0.000000] Centaur CentaurHauls [ 0.000000] Transmeta GenuineTMx86 [ 0.000000] Transmeta TransmetaCPU [ 0.000000] UMC UMC UMC UMC [ 0.000000] BIOS-provided physical RAM map: [ 0.000000] BIOS-e820: 0000000000000000 - 000000000009dc00 (usable) [ 0.000000] BIOS-e820: 000000000009dc00 - 00000000000a0000 (reserved) [ 0.000000] BIOS-e820: 00000000000e4000 - 0000000000100000 (reserved) [ 0.000000] BIOS-e820: 0000000000100000 - 000000007ff70000 (usable) [ 0.000000] BIOS-e820: 000000007ff70000 - 000000007ff7e000 (ACPI data) [ 0.000000] BIOS-e820: 000000007ff7e000 - 000000007ffd0000 (ACPI NVS) [ 0.000000] BIOS-e820: 000000007ffd0000 - 0000000080000000 (reserved) [ 0.000000] BIOS-e820: 00000000fee00000 - 00000000fee01000 (reserved) [ 0.000000] BIOS-e820: 00000000fff00000 - 0000000100000000 (reserved) [ 0.000000] DMI present. [ 0.000000] AMI BIOS detected: BIOS may corrupt low RAM, working it around. [ 0.000000] last_pfn = 0x7ff70 max_arch_pfn = 0x100000 [ 0.000000] Scanning 0 areas for low memory corruption [ 0.000000] modified physical RAM map: [ 0.000000] modified: 0000000000000000 - 0000000000010000 (reserved) [ 0.000000] modified: 0000000000010000 - 000000000009dc00 (usable) [ 0.000000] modified: 000000000009dc00 - 00000000000a0000 (reserved) [ 0.000000] modified: 00000000000e4000 - 0000000000100000 (reserved) [ 0.000000] modified: 0000000000100000 - 000000007ff70000 (usable) [ 0.000000] modified: 000000007ff70000 - 000000007ff7e000 (ACPI data) [ 0.000000] modified: 000000007ff7e000 - 000000007ffd0000 (ACPI NVS) [ 0.000000] modified: 000000007ffd0000 - 0000000080000000 (reserved) [ 0.000000] modified: 00000000fee00000 - 00000000fee01000 (reserved) [ 0.000000] modified: 00000000fff00000 - 0000000100000000 (reserved) [ 0.000000] kernel direct mapping tables up to 373fe000 @ 10000-16000 [ 0.000000] RAMDISK: 37811000 - 37fef8be [ 0.000000] Allocated new RAMDISK: 00881000 - 0105f8be [ 0.000000] Move RAMDISK from 0000000037811000 - 0000000037fef8bd to 00881000 - 0105f8bd [ 0.000000] ACPI: RSDP 000FB460, 0014 (r0 ACPIAM) [ 0.000000] ACPI: RSDT 7FF70000, 0040 (r1 A_M_I_ OEMRSDT 8000820 MSFT 97) [ 0.000000] ACPI: FACP 7FF70200, 0084 (r2 A_M_I_ OEMFACP 8000820 MSFT 97) [ 0.000000] ACPI: DSDT 7FF70440, 964B (r1 A1012 A1012001 1 INTL 20060113) [ 0.000000] ACPI: FACS 7FF7E000, 0040 [ 0.000000] ACPI: APIC 7FF70390, 006C (r1 A_M_I_ OEMAPIC 8000820 MSFT 97) [ 0.000000] ACPI: MCFG 7FF70400, 003C (r1 A_M_I_ OEMMCFG 8000820 MSFT 97) [ 0.000000] ACPI: OEMB 7FF7E040, 0081 (r1 A_M_I_ AMI_OEM 8000820 MSFT 97) [ 0.000000] ACPI: HPET 7FF79A90, 0038 (r1 A_M_I_ OEMHPET 8000820 MSFT 97) [ 0.000000] ACPI: OSFR 7FF79AD0, 00B0 (r1 A_M_I_ OEMOSFR 8000820 MSFT 97) [ 0.000000] ACPI: SSDT 7FF7E5D0, 0A7C (r1 DpgPmm CpuPm 12 INTL 20060113) [ 0.000000] ACPI: Local APIC address 0xfee00000 [ 0.000000] 1163MB HIGHMEM available. [ 0.000000] 883MB LOWMEM available. [ 0.000000] mapped low ram: 0 - 373fe000 [ 0.000000] low ram: 00000000 - 373fe000 [ 0.000000] bootmap 00012000 - 00018e80 [ 0.000000] (9 early reservations) ==> bootmem [0000000000 - 00373fe000] [ 0.000000] #0 [0000000000 - 0000001000] BIOS data page ==> [0000000000 - 0000001000] [ 0.000000] #1 [0000001000 - 0000002000] EX TRAMPOLINE ==> [0000001000 - 0000002000] [ 0.000000] #2 [0000006000 - 0000007000] TRAMPOLINE ==> [0000006000 - 0000007000] [ 0.000000] #3 [0000100000 - 000087c52c] TEXT DATA BSS ==> [0000100000 - 000087c52c] [ 0.000000] #4 [000087d000 - 0000881000] INIT_PG_TABLE ==> [000087d000 - 0000881000] [ 0.000000] #5 [000009dc00 - 0000100000] BIOS reserved ==> [000009dc00 - 0000100000] [ 0.000000] #6 [0000010000 - 0000012000] PGTABLE ==> [0000010000 - 0000012000] [ 0.000000] #7 [0000881000 - 000105f8be] NEW RAMDISK ==> [0000881000 - 000105f8be] [ 0.000000] #8 [0000012000 - 0000019000] BOOTMAP ==> [0000012000 - 0000019000] [ 0.000000] found SMP MP-table at [c00ff780] 000ff780 [ 0.000000] Zone PFN ranges: [ 0.000000] DMA 0x00000010 -> 0x00001000 [ 0.000000] Normal 0x00001000 -> 0x000373fe [ 0.000000] HighMem 0x000373fe -> 0x0007ff70 [ 0.000000] Movable zone start PFN for each node [ 0.000000] early_node_map[2] active PFN ranges [ 0.000000] 0: 0x00000010 -> 0x0000009d [ 0.000000] 0: 0x00000100 -> 0x0007ff70 [ 0.000000] On node 0 totalpages: 524029 [ 0.000000] free_area_init_node: node 0, pgdat c06d0f80, node_mem_map c1060200 [ 0.000000] DMA zone: 32 pages used for memmap [ 0.000000] DMA zone: 0 pages reserved [ 0.000000] DMA zone: 3949 pages, LIFO batch:0 [ 0.000000] Normal zone: 1736 pages used for memmap [ 0.000000] Normal zone: 220470 pages, LIFO batch:31 [ 0.000000] HighMem zone: 2327 pages used for memmap [ 0.000000] HighMem zone: 295515 pages, LIFO batch:31 [ 0.000000] Movable zone: 0 pages used for memmap [ 0.000000] ACPI: PM-Timer IO Port: 0x808 [ 0.000000] ACPI: Local APIC address 0xfee00000 [ 0.000000] ACPI: LAPIC (acpi_id[0x01] lapic_id[0x00] enabled) [ 0.000000] ACPI: LAPIC (acpi_id[0x02] lapic_id[0x01] enabled) [ 0.000000] ACPI: LAPIC (acpi_id[0x03] lapic_id[0x82] disabled) [ 0.000000] ACPI: LAPIC (acpi_id[0x04] lapic_id[0x83] disabled) [ 0.000000] ACPI: IOAPIC (id[0x02] address[0xfec00000] gsi_base[0]) [ 0.000000] IOAPIC[0]: apic_id 2, version 32, address 0xfec00000, GSI 0-23 [ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl) [ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level) [ 0.000000] ACPI: IRQ0 used by override. [ 0.000000] ACPI: IRQ2 used by override. [ 0.000000] ACPI: IRQ9 used by override. [ 0.000000] Enabling APIC mode: Flat. Using 1 I/O APICs [ 0.000000] ACPI: HPET id: 0x8086a301 base: 0xfed00000 [ 0.000000] Using ACPI (MADT) for SMP configuration information [ 0.000000] SMP: Allowing 4 CPUs, 2 hotplug CPUs [ 0.000000] PM: Registered nosave memory: 000000000009d000 - 000000000009e000 [ 0.000000] PM: Registered nosave memory: 000000000009e000 - 00000000000a0000 [ 0.000000] PM: Registered nosave memory: 00000000000a0000 - 00000000000e4000 [ 0.000000] PM: Registered nosave memory: 00000000000e4000 - 0000000000100000 [ 0.000000] Allocating PCI resources starting at 88000000 (gap: 80000000:7ee00000) [ 0.000000] PERCPU: Allocating 45056 bytes of per cpu data [ 0.000000] NR_CPUS: 64, nr_cpu_ids: 4, nr_node_ids 1 [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 519934 [ 0.000000] Kernel command line: root=UUID=659487e0-2a17-4501-8787-6f3ade33179d ro quiet splash rootdelay=90 [ 0.000000] Enabling fast FPU save and restore... done. [ 0.000000] Enabling unmasked SIMD FPU exception support... done. [ 0.000000] Initializing CPU#0 [ 0.000000] PID hash table entries: 4096 (order: 12, 16384 bytes) [ 0.000000] Fast TSC calibration using PIT [ 0.000000] Detected 2500.095 MHz processor. [ 0.004000] Console: colour VGA+ 80x25 [ 0.004000] console [tty0] enabled [ 0.004000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes) [ 0.004000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes) [ 0.004000] allocated 10482560 bytes of page_cgroup [ 0.004000] please try cgroup_disable=memory option if you don't want [ 0.004000] Scanning for low memory corruption every 60 seconds [ 0.004000] Memory: 2051856k/2096576k available (4126k kernel code, 43404k reserved, 2208k data, 532k init, 1191368k highmem) [ 0.004000] virtual kernel memory layout: [ 0.004000] fixmap : 0xffc77000 - 0xfffff000 (3616 kB) [ 0.004000] pkmap : 0xff400000 - 0xff800000 (4096 kB) [ 0.004000] vmalloc : 0xf7bfe000 - 0xff3fe000 ( 120 MB) [ 0.004000] lowmem : 0xc0000000 - 0xf73fe000 ( 883 MB) [ 0.004000] .init : 0xc0737000 - 0xc07bc000 ( 532 kB) [ 0.004000] .data : 0xc0507a6f - 0xc072fe60 (2208 kB) [ 0.004000] .text : 0xc0100000 - 0xc0507a6f (4126 kB) [ 0.004000] Checking if this processor honours the WP bit even in supervisor mode...Ok. [ 0.004000] SLUB: Genslabs=12, HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1 [ 0.004000] hpet clockevent registered [ 0.004000] HPET: 4 timers in total, 0 timers will be used for per-cpu timer [ 0.004000] Calibrating delay loop (skipped), value calculated using timer frequency.. 5000.19 BogoMIPS (lpj=10000380) [ 0.004000] Security Framework initialized [ 0.004000] SELinux: Disabled at boot. [ 0.004000] AppArmor: AppArmor initialized [ 0.004000] Mount-cache hash table entries: 512 [ 0.004000] Initializing cgroup subsys ns [ 0.004000] Initializing cgroup subsys cpuacct [ 0.004000] Initializing cgroup subsys memory [ 0.004000] Initializing cgroup subsys freezer [ 0.004000] CPU: L1 I cache: 32K, L1 D cache: 32K [ 0.004000] CPU: L2 cache: 2048K [ 0.004000] CPU: Physical Processor ID: 0 [ 0.004000] CPU: Processor Core ID: 0 [ 0.004000] using mwait in idle threads. [ 0.004000] Checking 'hlt' instruction... OK. [ 0.018120] ACPI: Core revision 20080926 [ 0.021823] ACPI: Checking initramfs for custom DSDT [ 0.284394] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1 [ 0.325151] CPU0: Intel Pentium® Dual-Core CPU E5200 @ 2.50GHz stepping 06 [ 0.328001] Booting processor 1 APIC 0x1 ip 0x6000 [ 0.004000] Initializing CPU#1 [ 0.004000] Calibrating delay using timer specific routine.. 5000.04 BogoMIPS (lpj=10000083) [ 0.004000] CPU: L1 I cache: 32K, L1 D cache: 32K [ 0.004000] CPU: L2 cache: 2048K [ 0.004000] CPU: Physical Processor ID: 0 [ 0.004000] CPU: Processor Core ID: 1 [ 0.412501] CPU1: Intel Pentium® Dual-Core CPU E5200 @ 2.50GHz stepping 06 [ 0.412515] checking TSC synchronization [CPU#0 -> CPU#1]: passed. [ 0.416034] Brought up 2 CPUs [ 0.416036] Total of 2 processors activated (10000.23 BogoMIPS). [ 0.416082] CPU0 attaching sched-domain: [ 0.416084] domain 0: span 0-1 level MC [ 0.416086] groups: 0 1 [ 0.416091] CPU1 attaching sched-domain: [ 0.416092] domain 0: span 0-1 level MC [ 0.416094] groups: 1 0 [ 0.416153] net_namespace: 776 bytes [ 0.416153] Booting paravirtualized kernel on bare hardware [ 0.416267] Time: 7:47:56 Date: 05/01/09 [ 0.416267] regulator: core version 0.5 [ 0.416267] NET: Registered protocol family 16 [ 0.416267] EISA bus registered [ 0.416267] ACPI: bus type pci registered [ 0.416267] PCI: MCFG configuration 0: base e0000000 segment 0 buses 0 - 255 [ 0.416267] PCI: Not using MMCONFIG. [ 0.416301] PCI: PCI BIOS revision 3.00 entry at 0xf0031, last bus=5 [ 0.416303] PCI: Using configuration type 1 for base access [ 0.416959] ACPI: EC: Look up EC in DSDT [ 0.431536] ACPI: Interpreter enabled [ 0.431541] ACPI: (supports S0 S1 S3 S4 S5) [ 0.431558] ACPI: Using IOAPIC for interrupt routing [ 0.431607] PCI: MCFG configuration 0: base e0000000 segment 0 buses 0 - 255 [ 0.434334] PCI: MCFG area at e0000000 reserved in ACPI motherboard resources [ 0.434336] PCI: Using MMCONFIG for extended config space [ 0.441366] ACPI: No dock devices found. [ 0.441423] ACPI: PCI Root Bridge [PCI0] (0000:00) [ 0.441497] pci 0000:00:01.0: PME# supported from D0 D3hot D3cold [ 0.441499] pci 0000:00:01.0: PME# disabled [ 0.441563] pci 0000:00:1a.0: reg 20 io port: [0xb800-0xb81f] [ 0.441620] pci 0000:00:1a.1: reg 20 io port: [0xb880-0xb89f] [ 0.441677] pci 0000:00:1a.2: reg 20 io port: [0xbc00-0xbc1f] [ 0.441736] pci 0000:00:1a.7: reg 10 32bit mmio: [0xf9fffc00-0xf9ffffff] [ 0.441770] pci 0000:00:1a.7: PME# supported from D0 D3hot D3cold [ 0.441774] pci 0000:00:1a.7: PME# disabled [ 0.441811] pci 0000:00:1b.0: reg 10 64bit mmio: [0xf9ff8000-0xf9ffbfff] [ 0.441837] pci 0000:00:1b.0: PME# supported from D0 D3hot D3cold [ 0.441840] pci 0000:00:1b.0: PME# disabled [ 0.441880] pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold [ 0.441883] pci 0000:00:1c.0: PME# disabled [ 0.441927] pci 0000:00:1c.4: PME# supported from D0 D3hot D3cold [ 0.441930] pci 0000:00:1c.4: PME# disabled [ 0.441972] pci 0000:00:1c.5: PME# supported from D0 D3hot D3cold [ 0.441975] pci 0000:00:1c.5: PME# disabled [ 0.442023] pci 0000:00:1d.0: reg 20 io port: [0xb080-0xb09f] [ 0.442079] pci 0000:00:1d.1: reg 20 io port: [0xb400-0xb41f] [ 0.442135] pci 0000:00:1d.2: reg 20 io port: [0xb480-0xb49f] [ 0.442194] pci 0000:00:1d.7: reg 10 32bit mmio: [0xf9fff800-0xf9fffbff] [ 0.442229] pci 0000:00:1d.7: PME# supported from D0 D3hot D3cold [ 0.442232] pci 0000:00:1d.7: PME# disabled [ 0.442367] pci 0000:00:1f.2: reg 10 io port: [0xa000-0xa007] [ 0.442372] pci 0000:00:1f.2: reg 14 io port: [0x9c00-0x9c03] [ 0.442377] pci 0000:00:1f.2: reg 18 io port: [0x9880-0x9887] [ 0.442382] pci 0000:00:1f.2: reg 1c io port: [0x9800-0x9803] [ 0.442387] pci 0000:00:1f.2: reg 20 io port: [0x9480-0x948f] [ 0.442392] pci 0000:00:1f.2: reg 24 io port: [0x9400-0x940f] [ 0.442423] pci 0000:00:1f.3: reg 10 64bit mmio: [0xf9fff400-0xf9fff4ff] [ 0.442436] pci 0000:00:1f.3: reg 20 io port: [0x400-0x41f] [ 0.442473] pci 0000:00:1f.5: reg 10 io port: [0xb000-0xb007] [ 0.442478] pci 0000:00:1f.5: reg 14 io port: [0xac00-0xac03] [ 0.442482] pci 0000:00:1f.5: reg 18 io port: [0xa880-0xa887] [ 0.442487] pci 0000:00:1f.5: reg 1c io port: [0xa800-0xa803] [ 0.442492] pci 0000:00:1f.5: reg 20 io port: [0xa480-0xa48f] [ 0.442497] pci 0000:00:1f.5: reg 24 io port: [0xa400-0xa40f] [ 0.442540] pci 0000:01:00.0: reg 10 32bit mmio: [0xfd000000-0xfdffffff] [ 0.442549] pci 0000:01:00.0: reg 14 64bit mmio: [0xd0000000-0xdfffffff] [ 0.442557] pci 0000:01:00.0: reg 1c 64bit mmio: [0xfa000000-0xfbffffff] [ 0.442562] pci 0000:01:00.0: reg 24 io port: [0xcc00-0xcc7f] [ 0.442567] pci 0000:01:00.0: reg 30 32bit mmio: [0xfe8e0000-0xfe8fffff] [ 0.442609] pci 0000:00:01.0: bridge io port: [0xc000-0xcfff] [ 0.442612] pci 0000:00:01.0: bridge 32bit mmio: [0xfa000000-0xfe8fffff] [ 0.442616] pci 0000:00:01.0: bridge 64bit mmio pref: [0xd0000000-0xdfffffff] [ 0.442656] pci 0000:00:1c.0: bridge 64bit mmio pref: [0xf8f00000-0xf8ffffff] [ 0.442698] pci 0000:03:00.0: reg 10 io port: [0xec00-0xec07] [ 0.442706] pci 0000:03:00.0: reg 14 io port: [0xe880-0xe883] [ 0.442713] pci 0000:03:00.0: reg 18 io port: [0xe800-0xe807] [ 0.442720] pci 0000:03:00.0: reg 1c io port: [0xe480-0xe483] [ 0.442727] pci 0000:03:00.0: reg 20 io port: [0xe400-0xe40f] [ 0.442735] pci 0000:03:00.0: reg 24 32bit mmio: [0xfeaffc00-0xfeafffff] [ 0.442752] pci 0000:03:00.0: supports D1 [ 0.442754] pci 0000:03:00.0: PME# supported from D0 D1 D3hot [ 0.442758] pci 0000:03:00.0: PME# disabled [ 0.442800] pci 0000:00:1c.4: bridge io port: [0xe000-0xefff] [ 0.442803] pci 0000:00:1c.4: bridge 32bit mmio: [0xfea00000-0xfeafffff] [ 0.442856] pci 0000:02:00.0: reg 10 64bit mmio: [0xfe9c0000-0xfe9fffff] [ 0.442864] pci 0000:02:00.0: reg 18 io port: [0xdc00-0xdc7f] [ 0.442898] pci 0000:02:00.0: PME# supported from D3hot D3cold [ 0.442903] pci 0000:02:00.0: PME# disabled [ 0.442946] pci 0000:00:1c.5: bridge io port: [0xd000-0xdfff] [ 0.442950] pci 0000:00:1c.5: bridge 32bit mmio: [0xfe900000-0xfe9fffff] [ 0.442986] pci 0000:05:03.0: reg 10 32bit mmio: [0xfebff000-0xfebfffff] [ 0.443022] pci 0000:05:03.0: supports D1 D2 [ 0.443023] pci 0000:05:03.0: PME# supported from D0 D1 D2 D3hot [ 0.443027] pci 0000:05:03.0: PME# disabled [ 0.443065] pci 0000:00:1e.0: transparent bridge [ 0.443070] pci 0000:00:1e.0: bridge 32bit mmio: [0xfeb00000-0xfebfffff] [ 0.443092] bus 00 -> node 0 [ 0.443097] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT] [ 0.443325] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.P0P2._PRT] [ 0.443420] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.P0P1._PRT] [ 0.443578] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.P0P8._PRT] [ 0.443673] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.P0P9._PRT] [ 0.443777] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.P0P4._PRT] [ 0.459220] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 6 7 *10 11 12 14 15) [ 0.459337] ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 6 7 10 *11 12 14 15) [ 0.459453] ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 5 6 7 10 11 12 14 *15) [ 0.459568] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 *5 6 7 10 11 12 14 15) [ 0.459683] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 6 7 10 11 12 14 15) *0, disabled. [ 0.459799] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 6 7 10 11 12 *14 15) [ 0.459914] ACPI: PCI Interrupt Link [LNKG] (IRQs *3 4 5 6 7 10 11 12 14 15) [ 0.460038] ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 5 6 *7 10 11 12 14 15) [ 0.460154] ACPI Warning (tbutils-0217): Incorrect checksum in table [OEMB] - 02, should be 01 [20080926] [ 0.460203] ACPI: WMI: Mapper loaded [ 0.460233] SCSI subsystem initialized [ 0.460233] libata version 3.00 loaded. [ 0.460233] usbcore: registered new interface driver usbfs [ 0.460233] usbcore: registered new interface driver hub [ 0.460233] usbcore: registered new device driver usb [ 0.460233] PCI: Using ACPI for IRQ routing [ 0.468013] Bluetooth: Core ver 2.13 [ 0.468034] NET: Registered protocol family 31 [ 0.468034] Bluetooth: HCI device and connection manager initialized [ 0.468034] Bluetooth: HCI socket layer initialized [ 0.468034] NET: Registered protocol family 8 [ 0.468034] NET: Registered protocol family 20 [ 0.468040] NetLabel: Initializing [ 0.468041] NetLabel: domain hash size = 128 [ 0.468043] NetLabel: protocols = UNLABELED CIPSOv4 [ 0.468052] NetLabel: unlabeled traffic allowed by default [ 0.468063] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0, 0 [ 0.468067] hpet0: 4 comparators, 64-bit 14.318180 MHz counter [ 0.472082] AppArmor: AppArmor Filesystem Enabled [ 0.480012] pnp: PnP ACPI init [ 0.480024] ACPI: bus type pnp registered [ 0.482805] pnp: PnP ACPI: found 15 devices [ 0.482807] ACPI: ACPI bus type pnp unregistered [ 0.482810] PnPBIOS: Disabled by ACPI PNP [ 0.482818] system 00:01: iomem range 0xfed14000-0xfed19fff has been reserved [ 0.482823] system 00:06: ioport range 0x290-0x29f has been reserved [ 0.482828] system 00:07: ioport range 0x4d0-0x4d1 has been reserved [ 0.482830] system 00:07: ioport range 0x800-0x87f has been reserved [ 0.482832] system 00:07: ioport range 0x500-0x57f has been reserved [ 0.482834] system 00:07: iomem range 0xfed08000-0xfed08fff has been reserved [ 0.482839] system 00:07: iomem range 0xfed1c000-0xfed1ffff has been reserved [ 0.482841] system 00:07: iomem range 0xfed20000-0xfed3ffff has been reserved [ 0.482843] system 00:07: iomem range 0xfed50000-0xfed8ffff has been reserved [ 0.482848] system 00:0a: iomem range 0xffc00000-0xffefffff has been reserved [ 0.482852] system 00:0c: iomem range 0xfec00000-0xfec00fff has been reserved [ 0.482854] system 00:0c: iomem range 0xfee00000-0xfee00fff has been reserved [ 0.482858] system 00:0d: iomem range 0xe0000000-0xefffffff has been reserved [ 0.482863] system 00:0e: iomem range 0x0-0x9ffff could not be reserved [ 0.482865] system 00:0e: iomem range 0xc0000-0xcffff could not be reserved [ 0.482866] system 00:0e: iomem range 0xe0000-0xfffff could not be reserved [ 0.482868] system 00:0e: iomem range 0x100000-0x7fffffff could not be reserved [ 0.500550] Switched to high resolution mode on CPU 1 [ 0.504002] Switched to high resolution mode on CPU 0 [ 0.517519] pci 0000:00:01.0: PCI bridge, secondary bus 0000:01 [ 0.517521] pci 0000:00:01.0: IO window: 0xc000-0xcfff [ 0.517525] pci 0000:00:01.0: MEM window: 0xfa000000-0xfe8fffff [ 0.517527] pci 0000:00:01.0: PREFETCH window: 0x000000d0000000-0x000000dfffffff [ 0.517531] pci 0000:00:1c.0: PCI bridge, secondary bus 0000:04 [ 0.517532] pci 0000:00:1c.0: IO window: disabled [ 0.517536] pci 0000:00:1c.0: MEM window: disabled [ 0.517540] pci 0000:00:1c.0: PREFETCH window: 0x000000f8f00000-0x000000f8ffffff [ 0.517545] pci 0000:00:1c.4: PCI bridge, secondary bus 0000:03 [ 0.517547] pci 0000:00:1c.4: IO window: 0xe000-0xefff [ 0.517551] pci 0000:00:1c.4: MEM window: 0xfea00000-0xfeafffff [ 0.517555] pci 0000:00:1c.4: PREFETCH window: disabled [ 0.517559] pci 0000:00:1c.5: PCI bridge, secondary bus 0000:02 [ 0.517562] pci 0000:00:1c.5: IO window: 0xd000-0xdfff [ 0.517566] pci 0000:00:1c.5: MEM window: 0xfe900000-0xfe9fffff [ 0.517569] pci 0000:00:1c.5: PREFETCH window: disabled [ 0.517574] pci 0000:00:1e.0: PCI bridge, secondary bus 0000:05 [ 0.517576] pci 0000:00:1e.0: IO window: disabled [ 0.517580] pci 0000:00:1e.0: MEM window: 0xfeb00000-0xfebfffff [ 0.517583] pci 0000:00:1e.0: PREFETCH window: disabled [ 0.517593] pci 0000:00:01.0: PCI INT A -> GSI 16 (level, low) -> IRQ 16 [ 0.517596] pci 0000:00:01.0: setting latency timer to 64 [ 0.517603] pci 0000:00:1c.0: PCI INT A -> GSI 17 (level, low) -> IRQ 17 [ 0.517606] pci 0000:00:1c.0: setting latency timer to 64 [ 0.517612] pci 0000:00:1c.4: PCI INT A -> GSI 17 (level, low) -> IRQ 17 [ 0.517615] pci 0000:00:1c.4: setting latency timer to 64 [ 0.517621] pci 0000:00:1c.5: PCI INT B -> GSI 16 (level, low) -> IRQ 16 [ 0.517624] pci 0000:00:1c.5: setting latency timer to 64 [ 0.517629] pci 0000:00:1e.0: setting latency timer to 64 [ 0.517632] bus: 00 index 0 io port: [0x00-0xffff] [ 0.517634] bus: 00 index 1 mmio: [0x000000-0xffffffff] [ 0.517635] bus: 01 index 0 io port: [0xc000-0xcfff] [ 0.517637] bus: 01 index 1 mmio: [0xfa000000-0xfe8fffff] [ 0.517639] bus: 01 index 2 mmio: [0xd0000000-0xdfffffff] [ 0.517640] bus: 01 index 3 mmio: [0x0-0x0] [ 0.517642] bus: 04 index 0 mmio: [0x0-0x0] [ 0.517643] bus: 04 index 1 mmio: [0x0-0x0] [ 0.517644] bus: 04 index 2 mmio: [0xf8f00000-0xf8ffffff] [ 0.517646] bus: 04 index 3 mmio: [0x0-0x0] [ 0.517647] bus: 03 index 0 io port: [0xe000-0xefff] [ 0.517649] bus: 03 index 1 mmio: [0xfea00000-0xfeafffff] [ 0.517650] bus: 03 index 2 mmio: [0x0-0x0] [ 0.517652] bus: 03 index 3 mmio: [0x0-0x0] [ 0.517653] bus: 02 index 0 io port: [0xd000-0xdfff] [ 0.517655] bus: 02 index 1 mmio: [0xfe900000-0xfe9fffff] [ 0.517656] bus: 02 index 2 mmio: [0x0-0x0] [ 0.517657] bus: 02 index 3 mmio: [0x0-0x0] [ 0.517659] bus: 05 index 0 mmio: [0x0-0x0] [ 0.517660] bus: 05 index 1 mmio: [0xfeb00000-0xfebfffff] [ 0.517662] bus: 05 index 2 mmio: [0x0-0x0] [ 0.517663] bus: 05 index 3 io port: [0x00-0xffff] [ 0.517665] bus: 05 index 4 mmio: [0x000000-0xffffffff] [ 0.517671] NET: Registered protocol family 2 [ 0.532079] IP route cache hash table entries: 32768 (order: 5, 131072 bytes) [ 0.532266] TCP established hash table entries: 131072 (order: 8, 1048576 bytes) [ 0.532567] TCP bind hash table entries: 65536 (order: 7, 524288 bytes) [ 0.532734] TCP: Hash tables configured (established 131072 bind 65536) [ 0.532736] TCP reno registered [ 0.540103] NET: Registered protocol family 1 [ 0.540199] checking if image is initramfs... it is [ 1.065181] Freeing initrd memory: 8058k freed [ 1.065362] cpufreq: No nForce2 chipset. [ 1.065476] audit: initializing netlink socket (disabled) [ 1.065496] type=2000 audit(1241164076.064:1): initialized [ 1.071320] highmem bounce pool size: 64 pages [ 1.071324] HugeTLB registered 4 MB page size, pre-allocated 0 pages [ 1.072320] VFS: Disk quotas dquot_6.5.1 [ 1.072363] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes) [ 1.072825] fuse init (API version 7.10) [ 1.072888] msgmni has been set to 1698 [ 1.073024] alg: No test for stdrng (krng) [ 1.073032] io scheduler noop registered [ 1.073033] io scheduler anticipatory registered [ 1.073035] io scheduler deadline registered [ 1.073045] io scheduler cfq registered (default) [ 1.073179] pci 0000:01:00.0: Boot video device [ 1.075270] pcieport-driver 0000:00:01.0: setting latency timer to 64 [ 1.075298] pcieport-driver 0000:00:01.0: found MSI capability [ 1.075318] pcieport-driver 0000:00:01.0: irq 2303 for MSI/MSI-X [ 1.075325] pci_express 0000:00:01.0:pcie00: allocate port service [ 1.075336] pci_express 0000:00:01.0:pcie03: allocate port service [ 1.075374] pcieport-driver 0000:00:1c.0: setting latency timer to 64 [ 1.075403] pcieport-driver 0000:00:1c.0: found MSI capability [ 1.075423] pcieport-driver 0000:00:1c.0: irq 2302 for MSI/MSI-X [ 1.075432] pci_express 0000:00:1c.0:pcie00: allocate port service [ 1.075442] pci_express 0000:00:1c.0:pcie02: allocate port service [ 1.075451] pci_express 0000:00:1c.0:pcie03: allocate port service [ 1.075499] pcieport-driver 0000:00:1c.4: setting latency timer to 64 [ 1.075528] pcieport-driver 0000:00:1c.4: found MSI capability [ 1.075549] pcieport-driver 0000:00:1c.4: irq 2301 for MSI/MSI-X [ 1.075558] pci_express 0000:00:1c.4:pcie00: allocate port service [ 1.075567] pci_express 0000:00:1c.4:pcie02: allocate port service [ 1.075579] pci_express 0000:00:1c.4:pcie03: allocate port service [ 1.075625] pcieport-driver 0000:00:1c.5: setting latency timer to 64 [ 1.075654] pcieport-driver 0000:00:1c.5: found MSI capability [ 1.075674] pcieport-driver 0000:00:1c.5: irq 2300 for MSI/MSI-X [ 1.075684] pci_express 0000:00:1c.5:pcie00: allocate port service [ 1.075696] pci_express 0000:00:1c.5:pcie02: allocate port service [ 1.075706] pci_express 0000:00:1c.5:pcie03: allocate port service [ 1.075760] pci_hotplug: PCI Hot Plug PCI Core version: 0.5 [ 1.076125] pciehp: PCI Express Hot Plug Controller Driver version: 0.4 [ 1.076239] input: Power Button (FF) as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input0 [ 1.076241] ACPI: Power Button (FF) [PWRF] [ 1.076279] input: Power Button (CM) as /devices/LNXSYSTM:00/device:00/PNP0C0C:00/input/input1 [ 1.076281] ACPI: Power Button (CM) [PWRB] [ 1.076773] ACPI: SSDT 7FF7E0D0, 0277 (r1 DpgPmm P001Ist 11 INTL 20060113) [ 1.077054] processor ACPI_CPU:00: registered as cooling_device0 [ 1.077349] ACPI: SSDT 7FF7E350, 0277 (r1 DpgPmm P002Ist 12 INTL 20060113) [ 1.077618] processor ACPI_CPU:01: registered as cooling_device1 [ 1.079771] isapnp: Scanning for PnP cards... [ 1.432636] isapnp: No Plug & Play device found [ 1.440697] Serial: 8250/16550 driver4 ports, IRQ sharing enabled [ 1.440782] serial8250: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A [ 1.441133] 00:0b: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A [ 1.441696] brd: module loaded [ 1.441925] loop: module loaded [ 1.441976] Fixed MDIO Bus: probed [ 1.441980] PPP generic driver version 2.4.2 [ 1.442022] input: Macintosh mouse button emulation as /devices/virtual/input/input2 [ 1.442043] Driver 'sd' needs updating - please use bus_type methods [ 1.442050] Driver 'sr' needs updating - please use bus_type methods [ 1.442084] ahci 0000:03:00.0: version 3.0 [ 1.442113] ata_piix 0000:00:1f.2: version 2.12 [ 1.442124] ata_piix 0000:00:1f.2: PCI INT B -> GSI 19 (level, low) -> IRQ 19 [ 1.442127] ata_piix 0000:00:1f.2: MAP [ P0 P2 P1 P3 ] [ 1.442163] ata_piix 0000:00:1f.2: setting latency timer to 64 [ 1.442208] scsi0 : ata_piix [ 1.442268] scsi1 : ata_piix [ 1.443475] ata1: SATA max UDMA/133 cmd 0xa000 ctl 0x9c00 bmdma 0x9480 irq 19 [ 1.443480] ata2: SATA max UDMA/133 cmd 0x9880 ctl 0x9800 bmdma 0x9488 irq 19 [ 2.236064] ata1.00: SATA link up 3.0 Gbps (SStatus 123 SControl 300) [ 2.236083] ata1.01: SATA link up 3.0 Gbps (SStatus 123 SControl 300) [ 2.318151] ata1.00: ATA-7: ST380815AS, 4.AAB, max UDMA/133 [ 2.318155] ata1.00: 156301488 sectors, multi 16: LBA48 NCQ (depth 0/32) [ 2.318328] ata1.01: ATA-8: SAMSUNG HD501LJ, CR100-10, max UDMA7 [ 2.318332] ata1.01: 976773168 sectors, multi 16: LBA48 NCQ (depth 0/32) [ 2.384812] ata1.00: configured for UDMA/133 [ 2.392333] ata1.01: configured for UDMA/133 [ 3.188061] ata2.00: SATA link down (SStatus 0 SControl 300) [ 3.188079] ata2.01: SATA link up 3.0 Gbps (SStatus 123 SControl 300) [ 3.220300] ata2.01: ATA-7: SAMSUNG HD753LJ, 1AA01107, max UDMA7 [ 3.220304] ata2.01: 1465149168 sectors, multi 16: LBA48 NCQ (depth 0/32) [ 3.228335] ata2.01: configured for UDMA/133 [ 3.228444] scsi 0:0:0:0: Direct-Access ATA ST380815AS 4.AA PQ: 0 ANSI: 5 [ 3.228521] sd 0:0:0:0: [sda] 156301488 512-byte hardware sectors: (80.0 GB/74.5 GiB) [ 3.228533] sd 0:0:0:0: [sda] Write Protect is off [ 3.228535] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00 [ 3.228554] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA [ 3.228600] sd 0:0:0:0: [sda] 156301488 512-byte hardware sectors: (80.0 GB/74.5 GiB) [ 3.228611] sd 0:0:0:0: [sda] Write Protect is off [ 3.228613] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00 [ 3.228631] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA [ 3.228634] sda: sda1 sda2 < sda5 sda6 > [ 3.273785] sd 0:0:0:0: [sda] Attached SCSI disk [ 3.273816] sd 0:0:0:0: Attached scsi generic sg0 type 0 [ 3.273873] scsi 0:0:1:0: Direct-Access ATA SAMSUNG HD501LJ CR10 PQ: 0 ANSI: 5 [ 3.273936] sd 0:0:1:0: [sdb] 976773168 512-byte hardware sectors: (500 GB/465 GiB) [ 3.273948] sd 0:0:1:0: [sdb] Write Protect is off [ 3.273949] sd 0:0:1:0: [sdb] Mode Sense: 00 3a 00 00 [ 3.273968] sd 0:0:1:0: [sdb] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA [ 3.274006] sd 0:0:1:0: [sdb] 976773168 512-byte hardware sectors: (500 GB/465 GiB) [ 3.274017] sd 0:0:1:0: [sdb] Write Protect is off [ 3.274018] sd 0:0:1:0: [sdb] Mode Sense: 00 3a 00 00 [ 3.274037] sd 0:0:1:0: [sdb] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA [ 3.274039] sdb: sdb1 [ 3.336607] sd 0:0:1:0: [sdb] Attached SCSI disk [ 3.336636] sd 0:0:1:0: Attached scsi generic sg1 type 0 [ 3.336689] scsi 1:0:1:0: Direct-Access ATA SAMSUNG HD753LJ 1AA0 PQ: 0 ANSI: 5 [ 3.336754] sd 1:0:1:0: [sdc] 1465149168 512-byte hardware sectors: (750 GB/698 GiB) [ 3.336765] sd 1:0:1:0: [sdc] Write Protect is off [ 3.336767] sd 1:0:1:0: [sdc] Mode Sense: 00 3a 00 00 [ 3.336785] sd 1:0:1:0: [sdc] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA [ 3.336822] sd 1:0:1:0: [sdc] 1465149168 512-byte hardware sectors: (750 GB/698 GiB) [ 3.336833] sd 1:0:1:0: [sdc] Write Protect is off [ 3.336835] sd 1:0:1:0: [sdc] Mode Sense: 00 3a 00 00 [ 3.336853] sd 1:0:1:0: [sdc] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA [ 3.336856] sdc: sdc1 < sdc5 > [ 3.342921] sd 1:0:1:0: [sdc] Attached SCSI disk [ 3.342948] sd 1:0:1:0: Attached scsi generic sg2 type 0 [ 3.342962] ata_piix 0000:00:1f.5: PCI INT B -> GSI 19 (level, low) -> IRQ 19 [ 3.342965] ata_piix 0000:00:1f.5: MAP [ P0 -- P1 -- ] [ 3.342995] ata_piix 0000:00:1f.5: setting latency timer to 64 [ 3.343028] scsi2 : ata_piix [ 3.343069] scsi3 : ata_piix [ 3.344169] ata3: SATA max UDMA/133 cmd 0xb000 ctl 0xac00 bmdma 0xa480 irq 19 [ 3.344173] ata4: SATA max UDMA/133 cmd 0xa880 ctl 0xa800 bmdma 0xa488 irq 19 [ 3.820047] ata3: SATA link up 3.0 Gbps (SStatus 123 SControl 300) [ 3.828299] ata3.00: ATA-7: SAMSUNG HD753LJ, 1AA01107, max UDMA7 [ 3.828303] ata3.00: 1465149168 sectors, multi 16: LBA48 NCQ (depth 0/32) [ 3.836336] ata3.00: configured for UDMA/133 [ 4.312047] ata4: SATA link up 3.0 Gbps (SStatus 123 SControl 300) [ 4.336306] ata4.00: ATA-8: SAMSUNG HD501LJ, CR100-12, max UDMA7 [ 4.336310] ata4.00: 976773168 sectors, multi 16: LBA48 NCQ (depth 0/32) [ 4.344346] ata4.00: configured for UDMA/133 [ 4.344437] scsi 2:0:0:0: Direct-Access ATA SAMSUNG HD753LJ 1AA0 PQ: 0 ANSI: 5 [ 4.344498] sd 2:0:0:0: [sdd] 1465149168 512-byte hardware sectors: (750 GB/698 GiB) [ 4.344517] sd 2:0:0:0: [sdd] Write Protect is off [ 4.344519] sd 2:0:0:0: [sdd] Mode Sense: 00 3a 00 00 [ 4.344538] sd 2:0:0:0: [sdd] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA [ 4.344576] sd 2:0:0:0: [sdd] 1465149168 512-byte hardware sectors: (750 GB/698 GiB) [ 4.344587] sd 2:0:0:0: [sdd] Write Protect is off [ 4.344588] sd 2:0:0:0: [sdd] Mode Sense: 00 3a 00 00 [ 4.344607] sd 2:0:0:0: [sdd] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA [ 4.344609] sdd: sdd1 < sdd5 > [ 4.348217] sd 2:0:0:0: [sdd] Attached SCSI disk [ 4.348244] sd 2:0:0:0: Attached scsi generic sg3 type 0 [ 4.348296] scsi 3:0:0:0: Direct-Access ATA SAMSUNG HD501LJ CR10 PQ: 0 ANSI: 5 [ 4.348359] sd 3:0:0:0: [sde] 976773168 512-byte hardware sectors: (500 GB/465 GiB) [ 4.348370] sd 3:0:0:0: [sde] Write Protect is off [ 4.348372] sd 3:0:0:0: [sde] Mode Sense: 00 3a 00 00 [ 4.348391] sd 3:0:0:0: [sde] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA [ 4.348428] sd 3:0:0:0: [sde] 976773168 512-byte hardware sectors: (500 GB/465 GiB) [ 4.348439] sd 3:0:0:0: [sde] Write Protect is off [ 4.348441] sd 3:0:0:0: [sde] Mode Sense: 00 3a 00 00 [ 4.348459] sd 3:0:0:0: [sde] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA [ 4.348461] sde: sde1 [ 4.355118] sd 3:0:0:0: [sde] Attached SCSI disk [ 4.355146] sd 3:0:0:0: Attached scsi generic sg4 type 0 [ 4.355466] pata_marvell 0000:03:00.0: PCI INT A -> GSI 16 (level, low) -> IRQ 16 [ 4.355488] pata_marvell 0000:03:00.0: setting latency timer to 64 [ 4.355532] scsi4 : pata_marvell [ 4.355571] scsi5 : pata_marvell [ 4.355597] ata5: PATA max UDMA/100 cmd 0xec00 ctl 0xe880 bmdma 0xe400 irq 16 [ 4.355599] ata6: PATA max UDMA/133 cmd 0xe800 ctl 0xe480 bmdma 0xe408 irq 16 [ 4.516393] ata5.00: ATAPI: Optiarc DVD RW AD-7170A, 1.04, max UDMA/66 [ 4.532408] ata5.00: configured for UDMA/66 [ 4.699998] scsi 4:0:0:0: CD-ROM Optiarc DVD RW AD-7170A 1.04 PQ: 0 ANSI: 5 [ 4.702536] sr0: scsi3-mmc drive: 48x/48x writer dvd-ram cd/rw xa/form2 cdda tray [ 4.702541] Uniform CD-ROM driver Revision: 3.20 [ 4.702639] sr 4:0:0:0: Attached scsi CD-ROM sr0 [ 4.702667] sr 4:0:0:0: Attached scsi generic sg5 type 5 [ 4.702851] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver [ 4.702866] ehci_hcd 0000:00:1a.7: PCI INT C -> GSI 18 (level, low) -> IRQ 18 [ 4.702880] ehci_hcd 0000:00:1a.7: setting latency timer to 64 [ 4.702883] ehci_hcd 0000:00:1a.7: EHCI Host Controller [ 4.702928] ehci_hcd 0000:00:1a.7: new USB bus registered, assigned bus number 1 [ 4.706819] ehci_hcd 0000:00:1a.7: debug port 1 [ 4.706824] ehci_hcd 0000:00:1a.7: cache line size of 32 is not supported [ 4.706834] ehci_hcd 0000:00:1a.7: irq 18, io mem 0xf9fffc00 [ 4.720012] ehci_hcd 0000:00:1a.7: USB 2.0 started, EHCI 1.00 [ 4.720097] usb usb1: configuration #1 chosen from 1 choice [ 4.720119] hub 1-0:1.0: USB hub found [ 4.720125] hub 1-0:1.0: 6 ports detected [ 4.720205] ehci_hcd 0000:00:1d.7: PCI INT A -> GSI 23 (level, low) -> IRQ 23 [ 4.720213] ehci_hcd 0000:00:1d.7: setting latency timer to 64 [ 4.720215] ehci_hcd 0000:00:1d.7: EHCI Host Controller [ 4.720253] ehci_hcd 0000:00:1d.7: new USB bus registered, assigned bus number 2 [ 4.724151] ehci_hcd 0000:00:1d.7: debug port 1 [ 4.724156] ehci_hcd 0000:00:1d.7: cache line size of 32 is not supported [ 4.724165] ehci_hcd 0000:00:1d.7: irq 23, io mem 0xf9fff800 [ 4.736013] ehci_hcd 0000:00:1d.7: USB 2.0 started, EHCI 1.00 [ 4.736099] usb usb2: configuration #1 chosen from 1 choice [ 4.736117] hub 2-0:1.0: USB hub found [ 4.736122] hub 2-0:1.0: 6 ports detected [ 4.736195] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver [ 4.736206] uhci_hcd: USB Universal Host Controller Interface driver [ 4.736221] uhci_hcd 0000:00:1a.0: PCI INT A -> GSI 16 (level, low) -> IRQ 16 [ 4.736226] uhci_hcd 0000:00:1a.0: setting latency timer to 64 [ 4.736228] uhci_hcd 0000:00:1a.0: UHCI Host Controller [ 4.736258] uhci_hcd 0000:00:1a.0: new USB bus registered, assigned bus number 3 [ 4.736277] uhci_hcd 0000:00:1a.0: irq 16, io base 0x0000b800 [ 4.736329] usb usb3: configuration #1 chosen from 1 choice [ 4.736348] hub 3-0:1.0: USB hub found [ 4.736353] hub 3-0:1.0: 2 ports detected [ 4.736414] uhci_hcd 0000:00:1a.1: PCI INT B -> GSI 21 (level, low) -> IRQ 21 [ 4.736418] uhci_hcd 0000:00:1a.1: setting latency timer to 64 [ 4.736421] uhci_hcd 0000:00:1a.1: UHCI Host Controller [ 4.736450] uhci_hcd 0000:00:1a.1: new USB bus registered, assigned bus number 4 [ 4.736475] uhci_hcd 0000:00:1a.1: irq 21, io base 0x0000b880 [ 4.736534] usb usb4: configuration #1 chosen from 1 choice [ 4.736552] hub 4-0:1.0: USB hub found [ 4.736557] hub 4-0:1.0: 2 ports detected [ 4.736617] uhci_hcd 0000:00:1a.2: PCI INT C -> GSI 18 (level, low) -> IRQ 18 [ 4.736621] uhci_hcd 0000:00:1a.2: setting latency timer to 64 [ 4.736624] uhci_hcd 0000:00:1a.2: UHCI Host Controller [ 4.736655] uhci_hcd 0000:00:1a.2: new USB bus registered, assigned bus number 5 [ 4.736673] uhci_hcd 0000:00:1a.2: irq 18, io base 0x0000bc00 [ 4.736724] usb usb5: configuration #1 chosen from 1 choice [ 4.736742] hub 5-0:1.0: USB hub found [ 4.736747] hub 5-0:1.0: 2 ports detected [ 4.736809] uhci_hcd 0000:00:1d.0: PCI INT A -> GSI 23 (level, low) -> IRQ 23 [ 4.736814] uhci_hcd 0000:00:1d.0: setting latency timer to 64 [ 4.736816] uhci_hcd 0000:00:1d.0: UHCI Host Controller [ 4.736846] uhci_hcd 0000:00:1d.0: new USB bus registered, assigned bus number 6 [ 4.736864] uhci_hcd 0000:00:1d.0: irq 23, io base 0x0000b080 [ 4.736918] usb usb6: configuration #1 chosen from 1 choice [ 4.736938] hub 6-0:1.0: USB hub found [ 4.736943] hub 6-0:1.0: 2 ports detected [ 4.737001] uhci_hcd 0000:00:1d.1: PCI INT B -> GSI 19 (level, low) -> IRQ 19 [ 4.737006] uhci_hcd 0000:00:1d.1: setting latency timer to 64 [ 4.737008] uhci_hcd 0000:00:1d.1: UHCI Host Controller [ 4.737042] uhci_hcd 0000:00:1d.1: new USB bus registered, assigned bus number 7 [ 4.737061] uhci_hcd 0000:00:1d.1: irq 19, io base 0x0000b400 [ 4.737114] usb usb7: configuration #1 chosen from 1 choice [ 4.737132] hub 7-0:1.0: USB hub found [ 4.737137] hub 7-0:1.0: 2 ports detected [ 4.737198] uhci_hcd 0000:00:1d.2: PCI INT C -> GSI 18 (level, low) -> IRQ 18 [ 4.737202] uhci_hcd 0000:00:1d.2: setting latency timer to 64 [ 4.737205] uhci_hcd 0000:00:1d.2: UHCI Host Controller [ 4.737239] uhci_hcd 0000:00:1d.2: new USB bus registered, assigned bus number 8 [ 4.737258] uhci_hcd 0000:00:1d.2: irq 18, io base 0x0000b480 [ 4.737309] usb usb8: configuration #1 chosen from 1 choice [ 4.737327] hub 8-0:1.0: USB hub found [ 4.737332] hub 8-0:1.0: 2 ports detected [ 4.737427] usbcore: registered new interface driver libusual [ 4.737450] usbcore: registered new interface driver usbserial [ 4.737458] USB Serial support registered for generic [ 4.737472] usbcore: registered new interface driver usbserial_generic [ 4.737474] usbserial: USB Serial Driver core [ 4.737517] PNP: No PS/2 controller found. Probing ports directly. [ 4.739789] serio: i8042 KBD port at 0x60,0x64 irq 1 [ 4.739793] serio: i8042 AUX port at 0x60,0x64 irq 12 [ 4.740559] mice: PS/2 mouse device common for all mice [ 4.752593] rtc_cmos 00:03: RTC can wake from S4 [ 4.752622] rtc_cmos 00:03: rtc core: registered rtc_cmos as rtc0 [ 4.752644] rtc0: alarms up to one month, y3k, 114 bytes nvram, hpet irqs [ 4.752692] device-mapper: uevent: version 1.0.3 [ 4.752755] device-mapper: ioctl: 4.14.0-ioctl (2008-04-23) initialised: [email protected] [ 4.752807] device-mapper: multipath: version 1.0.5 loaded [ 4.752809] device-mapper: multipath round-robin: version 1.0.0 loaded [ 4.752863] EISA: Probing bus 0 at eisa.0 [ 4.752886] EISA: Detected 0 cards. [ 4.752924] cpuidle: using governor ladder [ 4.752926] cpuidle: using governor menu [ 4.753303] TCP cubic registered [ 4.753375] NET: Registered protocol family 10 [ 4.753699] lo: Disabled Privacy Extensions [ 4.753945] NET: Registered protocol family 17 [ 4.753958] Bluetooth: L2CAP ver 2.11 [ 4.753959] Bluetooth: L2CAP socket layer initialized [ 4.753961] Bluetooth: SCO (Voice Link) ver 0.6 [ 4.753963] Bluetooth: SCO socket layer initialized [ 4.753983] Bluetooth: RFCOMM socket layer initialized [ 4.753987] Bluetooth: RFCOMM TTY layer initialized [ 4.753988] Bluetooth: RFCOMM ver 1.10 [ 4.754505] Using IPI No-Shortcut mode [ 4.754560] registered taskstats version 1 [ 4.754664] Magic number: 9:44:773 [ 4.754670] hub 2-0:1.0: hash matches [ 4.754727] rtc_cmos 00:03: setting system clock to 2009-05-01 07:48:00 UTC (1241164080) [ 4.754729] BIOS EDD facility v0.16 2004-Jun-25, 0 devices found [ 4.754730] EDD information not available. [ 4.754942] Freeing unused kernel memory: 532k freed [ 4.755032] Write protecting the kernel text: 4128k [ 4.755064] Write protecting the kernel read-only data: 1532k [ 4.866491] md: linear personality registered for level -1 [ 4.868147] md: multipath personality registered for level -4 [ 4.869670] md: raid0 personality registered for level 0 [ 4.871993] md: raid1 personality registered for level 1 [ 4.873406] xor: automatically using best checksumming function: pIII_sse [ 4.892502] pIII_sse : 9161.000 MB/sec [ 4.892504] xor: using function: pIII_sse (9161.000 MB/sec) [ 4.893358] async_tx: api initialized (async) [ 4.960561] raid6: int32x1 927 MB/s [ 5.028532] raid6: int32x2 982 MB/s [ 5.096520] raid6: int32x4 745 MB/s [ 5.164573] raid6: int32x8 689 MB/s [ 5.232514] raid6: mmxx1 3117 MB/s [ 5.300504] raid6: mmxx2 3565 MB/s [ 5.368519] raid6: sse1x1 2051 MB/s [ 5.436510] raid6: sse1x2 2707 MB/s [ 5.504516] raid6: sse2x1 3804 MB/s [ 5.572513] raid6: sse2x2 4182 MB/s [ 5.572515] raid6: using algorithm sse2x2 (4182 MB/s) [ 5.572517] md: raid6 personality registered for level 6 [ 5.572519] md: raid5 personality registered for level 5 [ 5.572520] md: raid4 personality registered for level 4 [ 5.593625] md: raid10 personality registered for level 10 [ 5.660883] ATL1E 0000:02:00.0: PCI INT A -> GSI 17 (level, low) -> IRQ 17 [ 5.660895] ATL1E 0000:02:00.0: setting latency timer to 64 [ 5.684504] ohci1394 0000:05:03.0: PCI INT A -> GSI 19 (level, low) -> IRQ 19 [ 5.736230] ohci1394: fw-host0: OHCI-1394 1.0 (PCI): IRQ=[19] MMIO=[febff000-febff7ff] Max Packet=[2048] IR/IT contexts=[8/8] [ 5.924524] usb 8-1: new low speed USB device using uhci_hcd and address 2 [ 6.102345] usb 8-1: configuration #1 chosen from 1 choice [ 6.108235] usbcore: registered new interface driver hiddev [ 6.124120] input: NOVATEK USB Keyboard as /devices/pci0000:00/0000:00:1d.2/usb8/8-1/8-1:1.0/input/input3 [ 6.132591] generic-usb 0003:0603:00F2.0001: input,hidraw0: USB HID v1.10 Keyboard [NOVATEK USB Keyboard] on usb-0000:00:1d.2-1/input0 [ 6.166371] input: NOVATEK USB Keyboard as /devices/pci0000:00/0000:00:1d.2/usb8/8-1/8-1:1.1/input/input4 [ 6.166492] generic-usb 0003:0603:00F2.0002: input,hiddev96,hidraw1: USB HID v1.10 Device [NOVATEK USB Keyboard] on usb-0000:00:1d.2-1/input1 [ 6.166505] usbcore: registered new interface driver usbhid [ 6.166508] usbhid: v2.6:USB HID core driver [ 6.325505] PM: Starting manual resume from disk [ 6.325508] PM: Resume from partition 8:5 [ 6.325509] PM: Checking hibernation image. [ 6.325663] PM: Resume from disk failed. [ 6.344023] usb 8-2: new low speed USB device using uhci_hcd and address 3 [ 6.350175] EXT4-fs: barriers enabled [ 6.362671] kjournald2 starting. Commit interval 5 seconds [ 6.362689] EXT4-fs: delayed allocation enabled [ 6.362690] EXT4-fs: file extents enabled [ 6.363023] EXT4-fs: mballoc enabled [ 6.363026] EXT4-fs: mounted filesystem with ordered data mode. [ 6.522384] usb 8-2: configuration #1 chosen from 1 choice [ 6.540513] input: Microsoft Comfort Optical Mouse 1000 as /devices/pci0000:00/0000:00:1d.2/usb8/8-2/8-2:1.0/input/input5 [ 6.544568] generic-usb 0003:045E:00F6.0003: input,hidraw2: USB HID v1.11 Mouse [Microsoft Comfort Optical Mouse 1000] on usb-0000:00:1d.2-2/input0 [ 7.016130] ieee1394: Host added: ID:BUS[0-00:1023] GUID[001e8c00018d9080] [ 9.835004] udev: starting version 141 [ 9.964167] Linux agpgart interface v0.103 [ 10.182834] iTCO_vendor_support: vendor-support=0 [ 10.340559] nvidia: module license 'NVIDIA' taints kernel. [ 10.592963] nvidia 0000:01:00.0: PCI INT A -> GSI 16 (level, low) -> IRQ 16 [ 10.592971] nvidia 0000:01:00.0: setting latency timer to 64 [ 10.593800] NVRM: loading NVIDIA UNIX x86 Kernel Module 180.44 Mon Mar 23 14:59:10 PST 2009 [ 10.618386] input: PC Speaker as /devices/platform/pcspkr/input/input6 [ 10.816673] iTCO_wdt: Intel TCO WatchDog Timer Driver v1.05 [ 10.816797] iTCO_wdt: Found a ICH10R TCO device (Version=2, TCOBASE=0x0860) [ 10.816868] iTCO_wdt: initialized. heartbeat=30 sec (nowayout=0) [ 10.841567] md: bind<sde1> [ 10.860164] md: bind<sdd5> [ 11.025655] HDA Intel 0000:00:1b.0: PCI INT A -> GSI 22 (level, low) -> IRQ 22 [ 11.025714] HDA Intel 0000:00:1b.0: setting latency timer to 64 [ 11.206142] lp: driver loaded but no devices found [ 11.283296] Adding 2048248k swap on /dev/sda5. Priority:-1 extents:1 across:2048248k [ 11.814558] EXT4 FS on sda1, internal journal on sda1:8 [ 12.528344] EXT4-fs: barriers enabled [ 12.547107] kjournald2 starting. Commit interval 5 seconds [ 12.547337] EXT4 FS on sda6, internal journal on sda6:8 [ 12.547340] EXT4-fs: delayed allocation enabled [ 12.547342] EXT4-fs: file extents enabled [ 12.550002] EXT4-fs: mballoc enabled [ 12.550005] EXT4-fs: mounted filesystem with ordered data mode. [ 12.818144] type=1505 audit(1241164088.561:2): operation="profile_load" name="/usr/share/gdm/guest-session/Xsession" name2="default" pid=2295 [ 12.852474] type=1505 audit(1241164088.593:3): operation="profile_load" name="/sbin/dhclient-script" name2="default" pid=2299 [ 12.852559] type=1505 audit(1241164088.597:4): operation="profile_load" name="/sbin/dhclient3" name2="default" pid=2299 [ 12.852592] type=1505 audit(1241164088.597:5): operation="profile_load" name="/usr/lib/NetworkManager/nm-dhcp-client.action" name2="default" pid=2299 [ 12.852620] type=1505 audit(1241164088.597:6): operation="profile_load" name="/usr/lib/connman/scripts/dhclient-script" name2="default" pid=2299 [ 12.947944] type=1505 audit(1241164088.689:7): operation="profile_load" name="/usr/lib/cups/backend/cups-pdf" name2="default" pid=2304 [ 12.948092] type=1505 audit(1241164088.689:8): operation="profile_load" name="/usr/sbin/cupsd" name2="default" pid=2304 [ 12.968418] type=1505 audit(1241164088.709:9): operation="profile_load" name="/usr/sbin/tcpdump" name2="default" pid=2308 [ 13.235245] RPC: Registered udp transport module. [ 13.235248] RPC: Registered tcp transport module. [ 13.340610] Installing knfsd (copyright © 1996 [email protected]). [ 14.810944] NFSD: Using /var/lib/nfs/v4recovery as the NFSv4 state recovery directory [ 14.815545] NFSD: starting 90-second grace period [ 15.745959] Bluetooth: BNEP (Ethernet Emulation) ver 1.3 [ 15.745962] Bluetooth: BNEP filters: protocol multicast [ 15.768646] Bridge firewalling registered [ 17.041884] ppdev: user-space parallel port driver [ 21.255540] ATL1E 0000:02:00.0: irq 2299 for MSI/MSI-X [ 21.255696] ATL1E 0000:02:00.0: ATL1E: eth0 NIC Link is Up<1000 Mbps Full Duplex> [ 21.255771] ADDRCONF(NETDEV_UP): eth0: link is not ready [ 21.255927] ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready [ 31.976010] eth0: no IPv6 routers present [ 81.604640] md: md_d0 stopped. [ 81.604657] md: unbind<sdd5> [ 81.608752] md: export_rdev(sdd5) [ 81.609452] md: md_d1 stopped. [ 81.609466] md: unbind<sde1> [ 81.610556] md: export_rdev(sde1) [ 185.816890] md: bind<sdc5> [ 185.819419] md: bind<sdd5> [ 185.840265] md0: setting max_sectors to 128, segment boundary to 32767 [ 185.840272] raid0: looking at sdd5 [ 185.840275] raid0: comparing sdd5(732571904) with sdd5(732571904) [ 185.840279] raid0: END [ 185.840281] raid0: ==> UNIQUE [ 185.840283] raid0: 1 zones [ 185.840286] raid0: looking at sdc5 [ 185.840289] raid0: comparing sdc5(732571904) with sdd5(732571904) [ 185.840292] raid0: EQUAL [ 185.840294] raid0: FINAL 1 zones [ 185.840298] raid0: done. [ 185.840301] raid0 : md_size is 1465143808 blocks. [ 185.840303] raid0 : conf->hash_spacing is 1465143808 blocks. [ 185.840306] raid0 : nb_zone is 1. [ 185.840308] raid0 : Allocating 4 bytes for hash. [ 185.842606] md0: unknown partition table [ 203.104873] md: bind<sdb1> [ 203.108050] md: bind<sde1> [ 203.116130] md1: setting max_sectors to 128, segment boundary to 32767 [ 203.116137] raid0: looking at sde1 [ 203.116140] raid0: comparing sde1(488383936) with sde1(488383936) [ 203.116144] raid0: END [ 203.116146] raid0: ==> UNIQUE [ 203.116149] raid0: 1 zones [ 203.116151] raid0: looking at sdb1 [ 203.116154] raid0: comparing sdb1(488383936) with sde1(488383936) [ 203.116158] raid0: EQUAL [ 203.116160] raid0: FINAL 1 zones [ 203.116164] raid0: done. [ 203.116166] raid0 : md_size is 976767872 blocks. [ 203.116169] raid0 : conf->hash_spacing is 976767872 blocks. [ 203.116172] raid0 : nb_zone is 1. [ 203.116174] raid0 : Allocating 4 bytes for hash. [ 203.116318] md1: detected capacity change from 0 to 1000210300928 [ 203.116323] md1: unknown partition table [ 228.868195] kjournald starting. Commit interval 5 seconds [ 228.869919] EXT3 FS on dm-0, internal journal [ 228.869927] EXT3-fs: mounted filesystem with ordered data mode. Endret 1. mai 2009 av WonderStivi Lenke til kommentar
Tandamram Skrevet 1. mai 2009 Forfatter Del Skrevet 1. mai 2009 Gjorde en mdadm --examine --scan --config=mdadm.conf >> /etc/mdadm/mdadm.conf og array'ene er nå oppe og går etter reboot, men må fremdeles "bygge opp" LVM med manuelle kommandoer. Lenke til kommentar
HawP Skrevet 1. mai 2009 Del Skrevet 1. mai 2009 (endret) Virker som et snodig problem. Hva er output av følgende kommandoer (som root/med sudo), gjerne både rett etter reboot, etter gjenoppbygging av raid og helt til slutt... cat /proc/mdstat pvs vgs lvs Endret 1. mai 2009 av HawP Lenke til kommentar
Tandamram Skrevet 1. mai 2009 Forfatter Del Skrevet 1. mai 2009 (endret) Som sagt, etter kommandoen ovenfor så bygges RAID-arrayene korrekt, men LVM ser ikke ut til å "starte". Output som du spurte etter: stian@Base:~$ cat /proc/mdstat Personalities : [linear] [multipath] [raid0] [raid1] [raid6] [raid5] [raid4] [raid10] md0 : active raid0 sdc5[0] sdd5[1] 1465143808 blocks 64k chunks md1 : active raid0 sdb1[0] sde1[1] 976767872 blocks 64k chunks unused devices: <none> stian@Base:~$ sudo pvscan [sudo] password for stian: PV /dev/md1 VG lvmg lvm2 [931.52 GB / 0 free] PV /dev/md0 VG lvmg lvm2 [1.36 TB / 0 free] Total: 2 [2.27 TB] / in use: 2 [2.27 TB] / in no VG: 0 [0 ] stian@Base:~$ sudo vgscan Reading all physical volumes. This may take a while... Found volume group "lvmg" using metadata type lvm2 stian@Base:~$ sudo lvscan ACTIVE '/dev/lvmg/storage' [2.27 TB] inherit stian@Base:~$ Dette posta jeg på launchpad tidligere, rett etter reboot. Edit, eh, pvs, vgs og lvs er vel samme som pvscan, vgscan og lvscan? Edit2: Ikke helt samme, nei. Her er output: stian@Base:~$ sudo pvs [sudo] password for stian: PV VG Fmt Attr PSize PFree /dev/md0 lvmg lvm2 a- 1.36T 0 /dev/md1 lvmg lvm2 a- 931.52G 0 stian@Base:~$ sudo vgs VG #PV #LV #SN Attr VSize VFree lvmg 2 1 0 wz--n- 2.27T 0 stian@Base:~$ sudo lvs LV VG Attr LSize Origin Snap% Move Log Copy% Convert storage lvmg -wi-ao 2.27T stian@Base:~$ Edit 3: Håper jeg har funnet feilen her. Venter på at en DVD skal brenne ferdig før jeg rebooter... md_component_detection (em If set to 1, LVM2 will ignore devices used as components of software RAID (md) devices by looking for md superblocks. This doesn't always work satisfactorily e.g. if a device has been reused without wiping the md superblocks first. Har forandra i /etc/lvm/lvm.conf slik: # By default, LVM2 will ignore devices used as components of # software RAID (md) devices by looking for md superblocks. # 1 enables; 0 disables. md_component_detection = 0 Endret 1. mai 2009 av WonderStivi Lenke til kommentar
Tandamram Skrevet 1. mai 2009 Forfatter Del Skrevet 1. mai 2009 Oh yeah, fikk ordna det Gjorde tre ting, og jeg tror alle tre hadde sin funksjon. 1. Oppdaterte /etc/mdadm/mdadm.conf: mdadm --examine --scan --config=mdadm.conf >> /etc/mdadm/mdadm.conf 2. Redigerte /etc/lvm/lvm.conf: # By default, LVM2 will ignore devices used as components of # software RAID (md) devices by looking for md superblocks. # 1 enables; 0 disables. md_component_detection = 0 3. Endret fstab til å mounte /dev/lvmg/storage istedet for ved UUID. Nå funker det Lenke til kommentar
