Auto OP
Gjest Slettet-rXRozPkg
Hvis du hadde søkt i hjelpe fila til mIRC hadde du finni:
The /aop command
/aop [-rw] <on|off|nick/address> [#channel1,#channel2,...] [type] [network]
The -r switch indicates that the address is to be removed.
The -w switch makes the auto-op apply to any network.
If you do not specify a type then only the users nickname is used. If you specify a type then the users address is looked up via the server.
The $aop identifier returns $true if auto-op is enabled, and $false if it isn't.
The $aop(address/N) identifier returns any matching address in the list, or the Nth address. The .type property returns the list of channels.
