Kontantkort i Spania med makspris på data?
Hei
Skal til Spania. Lurer på om noen veit om de tilbyr kontantkort der nede med makspris på datatrafikk pr dag?
Takker for svar :)
Var noen her inne som anbefalte http://www.masmovil.es tidligere, det ser ikke ut til at de har makspris, men de er iallfall en av de rimeligste aktørene på datatrafikk.
  • 3 uker senere...
Hello!
First, Sorry for use english. I'm spanish and I don't know norwegian.
Second, sorry for my poor english.
I was looking for information about Norwegian mobile operators (I will be a Erasmus student the next course at Norway) and I saw your message.
In Spain, for data connections you can use Simyo (www.simyo.es) (500 MB/month for 5 Euro) If you reach 500 Mb, the cost is 9 Cent per Mb. This is the standard tariff.
If you are an intensive user, you can select other tariff: 5Gb for 25Euro per Month.
The calls cost is 8 Cent/min plus 15 Cents for connection, any time, any network. And 0 cents/min plus 15 Cents for connection the first 10 minutes between Simyo's numbers.
Masmovil (www.masmovil.es) is a good option too (better quality than simyo but simyo is cheaper than masmovil). The cost is 3Cent/Mb (if you select the "auto top-up with credit card" option) or 5 Cent/Mb if you don't select the "auto top-up".
With masmovil the calls cost 8 cent/min plus 15cents for connection if you select "auto top-up" if you don't select "auto top-up" the cost is 10cent/min plus 15 cents for connection.
Both Masmovil and Simyo are Virtual Operators and use the Orange Network.
Greetings from Spain. :-)
