Problemer med å installere VMWare i SuSE 8.2
Prøver å installere VMware Workstation 4.0.0 build-4460 for Linux under SuSE 8.2, men jeg får det ikke helt til.
Problemet oppstår når jeg skal kjøre vmware-config.pl etter installasjonen. Feilmeldingen jeg får er:
Trying to find a suitable vmmon module for your running kernel.
None of VMware Workstation's pre-built vmmon modules is suitable for your
running kernel. Do you want this program to try to build the vmmon module for
your system (you need to have a C compiler installed on your system)? [yes]
Using compiler "/usr/bin/gcc". Use environment variable CC to override.
What is the location of the directory of C header files that match your running
kernel? [/usr/src/linux/include] /usr/include
The directory of kernel headers (version 2.4.20) does not match your running
kernel (version 2.4.20-4GB). Even if the module were to compile successfully,
it would not load into the running kernel.
Hva må jeg gjøre får å få VMWare til å fungere?
På forhånd takk for hjelpen!
Arild
