Espen3 Skrevet 24. april 2009 Del Skrevet 24. april 2009 (endret) Tenkte det kunne være lurt å få en tråd opp om disse 2, er vel mange som er interessert (fant ikke noen tråder fra før). Clevo D900F Phantom (kommer mest sannsynlig i mai, verdens første bærbare PC med i7 prosessor, også enkelt (mest sannsynlig ikke SLI, står det i teksten nedenfor, men mye rykter om at det ikke går) GTX 280M etc): http://www.idg.no/pcworld/article119844.ece Fra http://www.eurocom.com/newsroom/press/show_press.cfm?id=176 : Mobile workstations feature the most advanced computer technology, such as: - High-performance Processors: Intel Core i7 Extreme Edition or XEON processors - 64-bit hardware and multiple operating systems support (Windows Pro 64, Vista64, Server2008, Red Hat) - 16 GB of high performance memory, - up to 1.5GB of storage with multiple high performance SATA-300 hard - RAID 0/1/5 for extra performance, data redundancy or automatic backups - High performance VGA graphics including NVIDIA's SLI GTX 280M - Up to 1GB of video and the fastest graphics with OpenGL nVidia Quadro FX3700 - Large displays (17" or 18.4") in a portable form factor - Blu Ray and DVD Burning-on the-Go - High Performance 1 Gigabit LAN on-board and support for 2nd 1Gigabit LAN interface - 102-key desktop-like full size keyboards with separate numeric keypad - Multiple I/O Ports: 4 or 5 USB 2.0 ports, FireWire ports, serial and parallel ports, DVI ports for multiple external monitors, S-Video In ports for digital video cameras, media card readers, Optical digital and analog audio I/O, built-in microphone and stereo speakers - Excellent Wireless: internal up to 450Mbps WLAN 802.11a/b/g/n and Bluetooth 2.0 - Internal battery allows uninterrupted operation in case of power failure. - Excellent Surround Sound System with SRS WOW technology - Optional internal TV Tuner for Digital and/or Analog Video Input Clevo M980NU (ikke noen fast dato enda, rykter om mai/juni, blir mest sannsynlig verdens første laptop med SLI GTX 280M): http://www.notebookcheck.net/Hands-On-Clev...ok.14554.0.html Nyheter fra CeBIT 2009: http://forum.notebookreview.com/showthread.php?t=358804 Blir spennende å se ytelsen mellom SLI GTX 280M vs Crossfire HD4870. Endret 24. april 2009 av Espen3 Lenke til kommentar
